Old 04-23-2004, 07:35 AM   #7966
Jeff Werner's Avatar
Trader Rating: 15 (100%+)
Send a message via Yahoo to Jeff Werner
I am running the hardend uni's from the Mr4 car. Would you think these would hold up well to the spool? Also does the speedtech part come with the gear or do I need to have one to put on it?
Jeff
Jeff Werner is offline   Reply With Quote
Old 04-23-2004, 12:38 PM   #7967
Matt Howard's Avatar
Jeff
I've been using the hardened universals on my car with a spool for the past couple of weeks and they're fine, I've actually been running them pretty much since I got the SD a year ago. They're the best thing you can do to the front of the car IMO.
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 04-23-2004, 02:49 PM   #7968
hey, does anyone know the exact weight difference of the cgm chassis compared to the light weight cgm chassis.
magerz24 is offline   Reply With Quote
Old 04-23-2004, 04:03 PM   #7969
Originally posted by glide 1
Hi all,
My SSG turns a year old this month and i have been more than happy with it the past year of racing. I really do not have any major complaints except for a few things.
I run both front and rear diffs, and ever since ive had this kit i noticed that i regularly snap the long screw that tightens the diffs. I double check and make sure that i build them correctly every time, also making sure that it is well lubed and set not too tight or too loose but still i snap them. Can anyone recommend me a replacement part that is more durable? or are there any tips you recommend to avoid this from happening?
Also, i know the king pin issue (working its way loose) has been adressed on here. Do you recommend using alum carriers or do they bend and wear easy, creating play. Any tips i could try out to make them stay on? thanks in advance.
glide 1
Best thing you can do about the diff screw breaking is not to over tighten it. Everytime I've seen a broken diff screw there are way too many treads on the other side of the nut. Be careful, if you run it too loose you can melt the plastic diff half.
We have been running the new lightweight kingpins and they fit very nicely, also they have not been coming loose at all. Perhaps you could use just a very small drop of lock-tight on the kingpins to secure them better.
pops is offline   Reply With Quote
Old 04-23-2004, 04:32 PM   #7970
pheyhoe's Avatar
R/C Tech Charter Subscriber
Hi, last week i raced on carpet once again after about a 2 month break, i raced on polished wood for the two months.
i put the car down and on the first corner!!!!! Snap! hub carrier smashed and uj welded tight again
i thought i got rid of this problem months ago, ( i have previousley posted about it)
just to let you know i was rather peed off about that.
later......
[SIZE=1][COLOR=navy]Paul Heyhoe[/COLOR][/SIZE]
pheyhoe is offline   Reply With Quote
Old 04-23-2004, 04:59 PM   #7971
Tek Nickal's Avatar
8 Grams. Not much, but some.
Tek Nickal is offline   Reply With Quote
Old 04-23-2004, 07:06 PM   #7972
Chris Tosilini's Carpet nats setup is now posted on my site.
http://www.yokomo.tk
shortygy is offline   Reply With Quote
Old 04-23-2004, 07:30 PM   #7973
I saw Chris's cleveland setup on your site but I didn't see his nat's setup.
RCTech #361
Old 04-23-2004, 08:33 PM   #7974
STLNLST's Avatar
Trader Rating: 21 (100%+)
where are you guys racing at this weekend?
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 04-23-2004, 10:03 PM   #7975
Tek Nickal's Avatar
Just to make sure, can a 122t 64p gear fit on the SD? Oh yea, its a Kimbrough one.
Old 04-23-2004, 10:25 PM   #7976
Default becareful with thread lock
Becareful with thread lock. Some thread lock will melt plastic.
Read instruction on the thread lock before use.
ongbenghui is offline   Reply With Quote
Old 04-23-2004, 10:52 PM   #7977
sorry sumthing is going on with my web hosting. I just got a new host so Ill try it tonight.
Old 04-23-2004, 11:21 PM   #7978
Alright I got a new host. I think I have everything running. Go check my site for Tosilini's carpet nats setup.
Old 04-24-2004, 12:15 AM   #7979
Suspended
Trader Rating: 28 (100%+)
why the 122 tony mac?
racenut123 is offline   Reply With Quote
Old 04-24-2004, 04:42 AM   #7980
I think that's a little too big. I don't remember exactly what the biggest spur gear size you can fit on the car is but I "think" it was between 110-115
RCTech #361
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
