Old 04-19-2004, 09:29 AM   #7936
SpeedTech's Avatar
Originally posted by GraphiteMilitia
Why do people run the tub chassi at so cal and not the all carbon fiber ??
Also, I've been told by the local SoCal drivers that they like the new CGM steering geometry better for the tight SoCal track
Steve Wang
>>>www.SpeedtechHobbies.com<<<
SpeedTech is offline   Reply With Quote
Old 04-19-2004, 10:19 AM   #7937
lem2's Avatar
Default Graphite/Plastic
I would like to stock up on parts that break easily on my CGM.
Question: What is the difference betwen Graphite Arms (which cost double) over the plastic arms?
Are there any performance gains by using Graphite over Plastic arms, that are noticeable by a Novice Driver like me?
Thanks! Lem
lem2 is offline   Reply With Quote
Old 04-19-2004, 10:28 AM   #7938
utieh's Avatar
As a beginner too, i've broken several plastic arms, 2 or 3 i think, never broke any graphite parts. and they are lighter!
utieh is offline   Reply With Quote
Old 04-19-2004, 08:11 PM   #7939
Registered User
ritchie's Avatar
help me out guys, can't go back and read over 7900 posts
question,, has anyone figured out the actual spring rates for the yok springs, if so please list them here. thanks
ritchie is offline   Reply With Quote
Old 04-19-2004, 08:59 PM   #7940
Matt Howard's Avatar
Yokomo
Spring Rating [lb/in]
Orange 18.87
Green 16.06
Pink 14.93
Yellow 14.71
White 12.94
Blue 12.12
Rayspeed
Gray 19.90
Red 18.26
White 17.17
Yellow 14.87
Blue 14.29
Green 13.20
Associated
White 40.00
Yellow 31.91
Purple 30.30
Copper 23.26
Red 23.08
Gold 18.35
Blue 16.53
Silver 13.89
Green 11.43
Tamiya
Purple 22.72
Gray 20.91
White Short 17.24
Blue Short 15.27
White 14.82
Blue 14.08
Yellow 13.33
Red Short 13.24
Yellow Short 12.90
Red 11.86
Courtesy of Ling Kang Tong, Mechanical Engineer
ALZA Macroflux Development
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 04-20-2004, 02:55 AM   #7941
question
Matt,
On your spool setup... do u run rayspeed green springs or yokomo springs? also how do you keep the spool from loosening? mine seems to loosen after each run.
thanks in advance
eklips is offline   Reply With Quote
Old 04-20-2004, 05:42 AM   #7942
Default Good Setup SSG
HI Guys,
Appreciate some help here, I hv been looking for a good setup
on asphalt, flat regular traction and tight layout.
I 've been experimenting but couldnt find anything perfect.
Im running a SSG version and current setup is stock except for
front black and back copper roll bars...........
any Suggestions?? Thanks
gonna cheat a little on my friends now hee hee
marzin is offline   Reply With Quote
Old 04-20-2004, 06:52 AM   #7943
Default Re: question
Originally posted by eklips
Matt,
thanks in advance
They're the yokomo greens on my setup. You might want to replace the locknut in your diff. I haven't had to tighten mine at all after a couple weekends of racing on my spool
RCTech #361
Old 04-20-2004, 07:26 AM   #7944
ark
what rating are the silver springs thatcome standard on the sd?
ark is offline   Reply With Quote
Old 04-20-2004, 08:59 AM   #7945
Registered User
ritchie's Avatar
matt, thanks for the spring rating,
Old 04-20-2004, 11:11 AM   #7946
yodace's Avatar
R/C Tech Charter Subscriber
Could anybody give me the part #, for Yokomo conversion to the CG chassis?
yodace is offline   Reply With Quote
Old 04-20-2004, 12:16 PM   #7947
Part# SD-CGM (List Price $145.00)
CGM Conversion Set
CGM conversion for the MR-4TC SD SSG and BLACK chassis kits.
Street price is around $90
Headbanger is offline   Reply With Quote
Old 04-20-2004, 05:32 PM   #7948
Tek Nickal's Avatar
Those are an mystery, there is no "stainless" on the spring chart . . . my guess would to test the spring rating and compare with all the other springs and if they are close, then it should be around there. . . . but I haven't ever seen a spring dyno.
Tek Nickal is offline   Reply With Quote
Old 04-21-2004, 06:03 AM   #7949
sosidge's Avatar
They are between the Yellow 1460 and Green 1455 in hardness.
Old 04-21-2004, 12:05 PM   #7950
glide 1's Avatar
Hi all,
My SSG turns a year old this month and i have been more than happy with it the past year of racing. I really do not have any major complaints except for a few things.
I run both front and rear diffs, and ever since ive had this kit i noticed that i regularly snap the long screw that tightens the diffs. I double check and make sure that i build them correctly every time, also making sure that it is well lubed and set not too tight or too loose but still i snap them. Can anyone recommend me a replacement part that is more durable? or are there any tips you recommend to avoid this from happening?
Also, i know the king pin issue (working its way loose) has been adressed on here. Do you recommend using alum carriers or do they bend and wear easy, creating play. Any tips i could try out to make them stay on? thanks in advance.
glide 1
glide 1 is offline   Reply With Quote
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
