Old 04-16-2004, 06:29 PM   #7906
Hey pops, did you try calling me the other day? i got a missed call from a 916 area code.
James Nguyen is offline   Reply With Quote
Old 04-16-2004, 06:43 PM   #7907
No, it wasn't me.
pops is offline   Reply With Quote
Old 04-17-2004, 02:52 PM   #7908
Fire's Avatar
are the yokomo precision rims prone to cracking without big impacts?
it would suck big time if the rims crack with 3 runs on the new tires
Fire is offline   Reply With Quote
Old 04-17-2004, 04:56 PM   #7909
Registered User
Yes the in side lip cracks very easy and after the wheels arnt the car sems slower.
GraphiteMilitia is offline   Reply With Quote
Old 04-17-2004, 06:38 PM   #7910
Fire's Avatar
i see, damn
Old 04-17-2004, 07:04 PM   #7911
alch's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to alch
Yokomo has a new prototype carbon centre shaft for the SD.. Unfortunately i forgot to get some pictures of it.. I believe it is a bit thicker than the current one they have, only had a quick look at it though..
Since most of the Yokomo drivers here in Japan use the Team bomber shaft, Yokomo decided to develop a new one to compete with it.
alch is offline   Reply With Quote
Old 04-17-2004, 07:12 PM   #7912
alch's Avatar
The guy that is testing the shaft, also had a different lightweight chassis, not sure if they are going to be producing it or not.. Wasn't too much diffferent from the current lightweight chassis, just professionally milled in a few areas..
Old 04-17-2004, 09:39 PM   #7913
asimo's Avatar
yo bud!
time for me to try a new shaft!
I'll get my list soon.
asimo is offline   Reply With Quote
Old 04-17-2004, 09:59 PM   #7914
Fire's Avatar
speaking of shaft, do i need to ditch the yoke graphite shaft if i run a 10T?
also which brands of rims are more durable?
Old 04-18-2004, 02:15 AM   #7915
johnbull's Avatar
The Yokomo graphite shaft will not stand 10 turns for long. We've tried. I don't know about the new one.
I have found 2 types of wheels that don't crack - Orion JB and Pro Line.
Regards
Joe from sunny Malta.
johnbull is offline   Reply With Quote
Old 04-18-2004, 03:28 AM   #7916
Yokomo Aust's Avatar
Default Drive shaft cups
I seem to be going through a number of the plastic main drive shaft cups (Part number SD-501). On the last one i tried heat shrink but no luck. I dont have big crashes just stock racing stuff. Is there a way to make the plastic parts stronger or should i just buy the Aluminium Team Suzuki parts if i can find them. Is there any other companies that make these parts in Ti or Aluminium.
Yokomo Aust is offline   Reply With Quote
Old 04-18-2004, 05:39 AM   #7917
Tommy Bergfeldt's Avatar
Send a message via ICQ to Tommy Bergfeldt
Is it the rear Drive cup that breaks the most? Try and insert one O-Ring in both cups, standard is 1 in the rear cup i think.
I had the same problem in 12t before i put a O-ring in the front also.
Remember, if you put Suzuki Alu. cups you probably will break diff gears instead, and it takes longer time to replace them instead og the cups.
You have to see the positive in the negative
I hope you get rid of the problem!
JMI Motorsport / Red Bull Racing
HB Cyclone TC - Schumacher CAT SX & Cougar SV
Advanced Electronics - Autopartner.se - Sav÷x - NorthTQ
Tommy Bergfeldt is offline   Reply With Quote
Old 04-18-2004, 06:01 AM   #7918
Send a message via ICQ to Cobra81li200
You must have another problem, never broke a gear on that car, never knew of anyone breaking them aswell. Make sure your spacers are in the right place (3 behind the central bevel gear, two on the left side of the one way diff).
Cobra81li200 is offline   Reply With Quote
Old 04-18-2004, 07:31 AM   #7919
NightKidZ's Avatar
Send a message via ICQ to NightKidZ
Hi alch,
Any idea if the new shaft uses a woven carbon tube? I would imagine that would make it stronger.
Cheers
NightKidZ is offline   Reply With Quote
Old 04-18-2004, 07:54 AM   #7920
alch's Avatar
Originally posted by NightKidZ
Hi alch,
Cheers
Not too sure, i only had a quick look at it.. Was going to take some pictures and have a closer look, but i was too busy racing.
Going on holidays for a few weeks at the end of the week too, so won't be visiting the track for about a month.. I will update when i get back.
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
