Old 04-12-2004, 10:59 AM   #7876
Tek Nickal's Avatar
Default Geppetto
Try making the roll camber link longer and higher.
Tek Nickal is offline   Reply With Quote
Old 04-12-2004, 11:12 AM   #7877
lem2's Avatar
Default Re: Geppetto
what would this do? is this both for the front and rear?
lem2 is offline   Reply With Quote
Old 04-12-2004, 11:32 AM   #7878
John Fontaine's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to John Fontaine
I have a Yok SD for sale in the for sale forum. It's the black chassis with a lot of hop ups. The drive train is all tobee craft with graphite suspension and stock spares. Need to sell. Take a look if you're interested. Only been raced 10 minutes.
Thanks,
John
Xray and Serpent....very dusty!
John Fontaine is offline   Reply With Quote
Old 04-12-2004, 12:50 PM   #7879
Tek Nickal's Avatar
Default Re: Re: Geppetto
I did it for the front only and it helped.
Old 04-12-2004, 08:22 PM   #7880
Matts speedworld setup is now on my site http://www.yokomo.tk
shortygy is offline   Reply With Quote
Old 04-13-2004, 09:52 AM   #7881
pheyhoe's Avatar
In the SD manual, On page 19 it shows you how to assemble the lower suspension arms. On the left hand side of the page it says the following.
2 Types of spacers are included.
Unkeyed shim = for height adjustments.
Keyed Shim = for skid angle adjustments.
Could someone please explain this to me and what each does and where exactly to put them.
[SIZE=1][COLOR=navy]Paul Heyhoe[/COLOR][/SIZE]
pheyhoe is offline   Reply With Quote
Old 04-13-2004, 10:00 AM   #7882
Registered User
They put under suspension mount. Unkeyed shim is for height and keyed for kick-up or anti-squat.
Aku-Man is offline   Reply With Quote
Old 04-13-2004, 10:23 AM   #7883
Sleighty's Avatar
Yes but why would you raise the height of the suspension mount? what would it do exactly and how would it alter the cars handling? For the keyed for kick up or anti-squat what do you do to alter these ? when you add them, where abouts do you add them exactly and what effect does it have?
A1-RC.com
Team Scream
Xray
Sleighty is offline   Reply With Quote
Old 04-13-2004, 10:25 AM   #7884
Registered User
http://ebiz.netopia.com/competitionx...ationdatabase/
This might help you.
Old 04-13-2004, 12:58 PM   #7885
SpeedTech's Avatar
Hi Guys,
The Speed Tech R/C Yokomo MR-4TCSD Spools are in stock now and available online. Look for Yokomo factory drivers running our spools at large events this year
Steve Wang
>>>www.SpeedtechHobbies.com<<<
SpeedTech is offline   Reply With Quote
Old 04-13-2004, 01:12 PM   #7886
Tek Nickal's Avatar
If you adjust the height, the lower it is the better it is for low traction surfaces. . . .
Old 04-13-2004, 04:24 PM   #7887
sosidge's Avatar
Raising/lowering the suspension arm mounts can affect both roll centre and kick-up/anti-squat.
Roll-centre - raising the inner mounts will raise the roll centre. This usually encourages less body roll - I find that up front it's a good way of smoothing the steering response, with slightly less grip. At the rear it can make the car a bit looser. There is also an effect on the camber change - more negative camber under compression, which adds more complexity to the equation...
Kick-Up - used to refer to a greater angle between the front wishbones and the chassis. More kick-up will give a better ride, and a slightly softer behaving front end under braking. More kick-up may also make the car slower to react while steering under braking. Less kick-up will affect the ride, but also make the front end a bit more responsive while steering under braking. As standard, the SD has 1 degree of front kick-up. More kick-up will also increase caster, all other adjustments remaining equal.
Anti-Squat - used to refer to the angle between the rear wishbones and the chassis. Works like kick-up, partially in reverse. More anti-squat will give a better ride, and also make the back end more responsive to throttle changes, with a shade less grip. Less will have the opposite effect. The SD has 0 degrees of anti-squat as standard - I would never go negative with the anti-squat (i.e. raising the rear of the wishbone above the front).
Old 04-14-2004, 12:37 PM   #7888
Matt Howard's Avatar
TTT BTW, anyone know if Korea is big into r/c racing? I'm moving there the end of june for a year.
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 04-14-2004, 01:13 PM   #7889
linger's Avatar
Matt, say it ain't so! At least everyone gets to move up one spot on the grid.
There are hobby shops in Korea...so there's gotta be racing right?
http://www.kimshobby.co.kr/main.asp?siteid=kimshobby
linger is offline   Reply With Quote
Old 04-14-2004, 01:29 PM   #7890
Taz_S's Avatar
shoot we going to have to get a going away party for you then.
Jake's Performance Hobbies http://www.jphracing.com/
https://www.facebook.com/groups/757500284356171 Facebook Group for Pro 10
Taz_S is offline   Reply With Quote
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
