Old 04-08-2004, 08:22 AM   #7816
Default black bevel vs white bevel
Hi,
Any difference between black bevel gear and the uncolored
ones ?
ongbenghui is offline   Reply With Quote
Old 04-08-2004, 08:26 AM   #7817
Regional Moderator
daniz24's Avatar
I have a problem with Mo's Interactive sheet..
It seems that the fonts are not sit properly (way too high). Anybody can help me?
daniz24 is offline   Reply With Quote
Old 04-08-2004, 10:19 AM   #7818
Horatio's Avatar
Default Re: black bevel vs white bevel
Originally posted by ongbenghui
Hi,
ones ?
Matt Howard may correct me on this, but I think the only difference is the dye - the actual material is the same.
So take your pick
Horatio is offline   Reply With Quote
Old 04-08-2004, 12:15 PM   #7819
Mo's setup sheets look okay to me. You might try upgrading your version or Adobe Acrobat reader.
Headbanger is offline   Reply With Quote
Old 04-08-2004, 12:35 PM   #7820
Matt Howard's Avatar
Default Re: Re: black bevel vs white bevel
So take your pick
I think your right, we were told by yokomo that the only difference is the color of the plastic. I haven't been able to tell any difference in the durability or smoothness of either so it seems they're right.
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 04-08-2004, 12:39 PM   #7821
Hey everyone. Last Tuesday, I won the C main at trackside. Whats cool is that my time was less than 4 seconds slower than the last place guy in the A main. I do have 2 main questions: My lhs dosn't have a minimun weight limit so I want the lightset car possible, right now, its 3.5lbs. I know what to get for the drivetrain, but how much lighter is the shooter light weight motor mount compared to the stock one. And my second question is that I run rubber on carpet and the car handles great, would I be wasting my money to buy the cgm conversion kit and the light weight chassis. Any insight would be greatly appriciated.
magerz24 is offline   Reply With Quote
Old 04-08-2004, 03:35 PM   #7822
Registered User
2Tenths's Avatar
Matt: I was looking at a picture of Tosolini's CGM from the Cleveland race, and I noticed he used a longer turnbuckle from the servo to the bellcrank. Instead of linking the servo to the center of the rack, like in the instructions, he attached it to the battery side of the rack. Do you have any idea what this does handling-wise?
Also: On the Yokomo distributer site, there are CGM setups from Masami and Suzuki. Does anyone know where I might find them in English? Thanks
2Tenths is offline   Reply With Quote
Old 04-08-2004, 05:03 PM   #7823
All you gotta do is like print out that sheet and hold it next to an english version and line everything up. It should work ok.
shortygy is offline   Reply With Quote
Old 04-08-2004, 05:21 PM   #7824
I did the same thing with my CGM, I put a turnbuckle inbetween the two bellcranks instead of the molded link as well so I can play with ackerman adjustments. It's just another setting you can play with if you want, right now I'm still running the stock lengths, when I get my spool setup where I want I'll play with this.
RCTech #361
Old 04-08-2004, 09:28 PM   #7825
question
will the harden universals front and rear for the mr4tc fit on the sd?
thanks
eklips is offline   Reply With Quote
Old 04-08-2004, 09:42 PM   #7826
Trader Rating: 21 (100%+)
The universals will work. You have to grind part of the ball down on them so the suspension can compress. I have run the fronts for about 8 months and still are like new. I tried pretty much everything else out there, and there would be slop in them after a couple of runs. Also put the rears in about a month ago and I won't run anything else in my car.
Thanks to pops
TLR, Fantom, Horizon, Spektrum, Trackside
Brian L is offline   Reply With Quote
Old 04-09-2004, 09:45 AM   #7827
lem2's Avatar
Default My CGM
still in the final stage of assembly. Saving enough money for a new 302f Rx, painting a body.
the mods that I did is the NTC3 RPM bumper and the cut out battery retainer, still getting ideas from this thread so keep it coming!
I used Tamiya Ti Hex Screws and almost 100% full Ti screws! I am also using SQUARE Ti input shafts, cvd's and hinge pin screws. Rayspeed shock retainers and springs, the rest are Yokomo!
Have not set up the car poperly, like toe-in/out, camber and so on! just excited to show it! It's my first Yokomo Car!
lem2 is offline   Reply With Quote
Old 04-09-2004, 10:49 AM   #7828
Registered User
I just weight my SD without tires. Only 1346g. Loaded everything with 3300 battery.
Aku-Man is offline   Reply With Quote
Old 04-09-2004, 11:02 AM   #7829
Default NTC3 Bumper Mod
Hey Lem2,
Can you provide pics or a summary of what you had to do to fit the NTC3 bumper to the CGM chassis?
Jeff
TKG 27 is offline   Reply With Quote
Old 04-09-2004, 11:50 AM   #7830
Registered User
2Tenths's Avatar
Matt: Thanks for the info. That's a cool idea, I have not been able to mess with the ackerman settings yet. Is the spool you're testing from WA by any chance? I know a guy who machined steel spools up here for the SD as well as the Barracuda and Evo III. He said he was sending them down to CA for testing.
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
