Old 04-07-2004, 05:54 AM   #7801
Anyone know if the suspension arms and drive shafts off the MR4TC mini will fit on to an SD ?
I want to build a 1/12th scale SD to compete with the T1M.
I can get a shorter chassis and porp shaft made but will need the arms and driveshafts.
Bob The Builder is offline   Reply With Quote
Old 04-07-2004, 07:00 AM   #7802
danjoy25's Avatar
R/C Tech Charter Subscriber
Trader Rating: 37 (100%+)
Default CGM w/ BL set-up
Pic of my new CGM with a Beat 70/twist 47 Brushless set-up.
Awesomatix A800 & A800X/ Mugen MTX-5 / 3 Racing F113 / Kyosho RB5 / Kyosho Mini-Z
danjoy25 is offline   Reply With Quote
Old 04-07-2004, 07:06 AM   #7803
Yokomo Aust's Avatar
Default Look out
man looks like it will fly. Are you cutting it loose next meet.
Yokomo Aust is offline   Reply With Quote
Old 04-07-2004, 08:57 AM   #7804
sosidge's Avatar
It won't be a straight fit.
The SD mounts its wishbones in a different way to the belt-drive cars (hinge pin held in place at the outside, compared to held in place at the inside).
The width between the wishbone mountings is different too, so the track and maybe also the driveshaft/outdrive coupling will be affected.
Not beyond the realm of possibilty though.
I would have thought that the 12th scale belt Yoke would be a match for the X-ray though...
Old 04-07-2004, 06:23 PM   #7805
Regional Moderator
daniz24's Avatar
Picture of my SD SSG...
daniz24 is offline   Reply With Quote
Old 04-07-2004, 06:26 PM   #7806
Regional Moderator
daniz24's Avatar
My servo modification
Old 04-07-2004, 06:27 PM   #7807
just a question... why do you have all of those farad things or w/e they are called on ur wires. Does it stop gltiching or sumthing.?
shortygy is offline   Reply With Quote
Old 04-07-2004, 06:39 PM   #7808
Registered User
That is also called noise killer. It should prevent glitching. I don't have glitching problem, but I still put them on mine. Just for safe.
Aku-Man is offline   Reply With Quote
Old 04-07-2004, 10:39 PM   #7809
Regional Moderator
daniz24's Avatar
Yes, it is a noise killer from Yokomo/Much More and it's also supposed to prevent glitches. Just for safety...
Old 04-07-2004, 11:23 PM   #7810
Alright guys since MO switched to team Schumacher and will be deleting the yokomo setup sheets off of his site soon, I made a site for everyone. It has all of the setups that MO has on his site and I will add setups as I get them. The address is
http://www.yokomo.tk
Old 04-08-2004, 02:13 AM   #7811
lem2's Avatar
Default CGM Question
In placing the Motor mount on the chassis, the instruction only says place screws on the middle part/holes and leave the outer hole alone.
Why is this? And will something bad happen if I placed a screw there?
Peace and Happy Racing!
Thanks!!!
lem2 is offline   Reply With Quote
Old 04-08-2004, 04:46 AM   #7812
Sleighty's Avatar
Good man!!
A1-RC.com
Team Scream
Xray
Sleighty is offline   Reply With Quote
Old 04-08-2004, 05:04 AM   #7813
What grease or lubricant you guys use on the bevel gears, any good recommendations.
caveman is offline   Reply With Quote
Old 04-08-2004, 06:29 AM   #7814
Horatio's Avatar
Nylon is self-lubricationg, so there's no real need to add lube. However, I've used ZX1 (available form Schumacher) that is a very thin oil that impregnates the surfaces in question. Any surplus is thrown off by the gears as they rotate.
If you use grease, the grease will make the car quieter - BUT because it is far thicker, will add to the rolling resistance and bind up the gears slightly.
Horatio is offline   Reply With Quote
Old 04-08-2004, 06:53 AM   #7815
Matt Howard's Avatar
Default Re: CGM Question
Thanks!!!
I'm guessing that not putting the screw on the outside of the motor mount will keep the bracing the same from left to right, eliminating any chance for the chassis to take a tweek. It's funny, every time someone looks at my car for the first time that all say, "you know you're missing a screw on the bottom of your chassis"
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
