Old 04-01-2004, 11:58 PM   #7741
acutts's Avatar
Thanks for the info guys. I was running the graphite took it out and went back to the Standard alu one and found the car better... not sure why but did. I do run stock though.
Is the Tobee lighter than the kit one?
acutts is offline   Reply With Quote
Old 04-02-2004, 12:40 AM   #7742
johnbull's Avatar
Hi friends. Greetings from Malta.
GEPPETTO. I agree about weight of titanium half shafts. I have had them on my car quite a while without any problems, and yes they are very light.
ACUTTS. The factory graphite shaft is OK for stock but not for modified. I twisted mine in about a week with 10 turn motors.
I have now fitted a shortened TC3 graphite shaft and have run it for the last 6 months with 8 turn motors and lots of grip and have had no problems at all. And it's the lightest one of the lot too!
I have a Tobee one and it looks efficient and light. Haven't needed to use it yet. On my son's TC3 we have been using as Bomber graphite shaft. With 8 turn motors it is still Ok after months of running. I must get one of these for the SD.
Regards
Joe from sunny Malta.
johnbull is offline   Reply With Quote
Old 04-02-2004, 01:37 AM   #7743
how did u shorten the tc3 shaft...??? can u explain
shortygy is offline   Reply With Quote
Old 04-02-2004, 01:38 AM   #7744
Lonestar's Avatar
I run the stock alum one... I suspect that unless you're a very seasoned stock racer, you will not notice the difference.
Later
Paul
When the flag drops, the BS stops.
The train stops at the train station. The bus stops at the bus station. In my office I have a workstation.
Lonestar is offline   Reply With Quote
Old 04-02-2004, 04:39 AM   #7745
johnbull's Avatar
Just remove one end. The ends are glued on. If you put it on a lathe and machine about 1mm near the end, the dog end will come apart. Clean it up. Shorten the shaft to required length and re-glue the end in.
Like I said, ours has worked a treat, even with 8 turn motors and drag racing.
Regards
Old 04-02-2004, 07:33 AM   #7746
Stock SD shaft is 14g, Tobee is 9g, TC3 graphite shaft is 7g.
caveman is offline   Reply With Quote
Old 04-02-2004, 08:08 AM   #7747
Trader Rating: 35 (100%+)
Default TC3 graphite shaft
Any idea what the part number is for this part? Know of any shops that have it in stock? I can't find it.
Geppetto is offline   Reply With Quote
Old 04-02-2004, 10:17 AM   #7748
Tommy Bergfeldt's Avatar
Send a message via ICQ to Tommy Bergfeldt
I just got a Shooter Graphite shaft i will try, a friend has used it in 12 motor mod in about 4 months now with no twisting, it's stiff as hell also.
To make your Yokomo graphite shaft more non-flexy you can add some shrinking tube to the hole graphite length, i did it to mine and it lasted for 8 races or so before i snapped one end in a practice run
A original graphite one from Yokomo twisted about 3/4 of a whole revolution before it snapped after probably 40 packs of running with Sorex 28 and 12 turn.
JMI Motorsport / Red Bull Racing
HB Cyclone TC - Schumacher CAT SX & Cougar SV
Advanced Electronics - Autopartner.se - Sav÷x - NorthTQ
Tommy Bergfeldt is offline   Reply With Quote
Old 04-02-2004, 10:41 AM   #7749
Somebody please import the Bomber shaft!
pops is offline   Reply With Quote
Old 04-02-2004, 08:22 PM   #7750
Tek Nickal's Avatar
Regards
What did you use to glue it back on? Epoxy or CA?
Tek Nickal is offline   Reply With Quote
Old 04-02-2004, 09:07 PM   #7751
glide 1's Avatar
Default shooter shaft
i agree with Sparx, i've had this shaft for a while now running 23t, 19t, and 10t mod... still going strong and looks good too!!
I still want to do the tc3 shaft mod though, should be even more lighter than the shooter
glide 1 is offline   Reply With Quote
Old 04-02-2004, 11:43 PM   #7752
KID TRF's Avatar
Default Help
Hi everyone,
Can you guys please help me. I have a TRF414MII i am getting ride of in place of a Yokomo CGM kit. What i want to know is what are the must have Hop Ups for this car. I will be running in stock class with a Putnam Monster. Weight limit is 1500gm minimum excluding transponder. I was looking at the light weight CGM chassis and also Acer bearings. But what else will be a great benefit and who makes the parts ei. Shooter, Square, Tobee etc.
Look forward to your replies.
KID TRF is offline   Reply With Quote
Old 04-03-2004, 12:37 AM   #7753
Registered User
Hi-LowBrow's Avatar
Send a message via Yahoo to Hi-LowBrow
No, unfortunately the Shooter's shaft break easily.... I broke 2 shooter's shaft.
but, the Bomber's shaft never break.
Hi-LowBrow is offline   Reply With Quote
Old 04-03-2004, 02:30 AM   #7754
i dont know if you guys have seen this already, but here goes:
Loos like some sort of wider bumper or something?
Trevor is offline   Reply With Quote
Old 04-03-2004, 02:55 AM   #7755
NightKidZ's Avatar
Send a message via ICQ to NightKidZ
It IS the wide bumper kit, the plastic part fits under the foam to support it.
Cheers
NightKidZ is offline   Reply With Quote
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
