Old 03-30-2004, 12:38 AM   #7726
johnbull's Avatar
Hi friends. Greetings from Malta.
STEVE.
You have a valid point of course. For guys that have been using one ways then they stand to gain only.
In Europe people seem to use one ways to a lesser degree. I have run a spool on my SD and love the way it handles - a bit like a front wheel drive real car.
The IRS spool is delicate indeed. What one needs to do is ensure that the cushions / blades - call them what you like, are always in good order. I have one fitted on my son's TC3 which has run a full season of mod racing with 8 turn motors. We have had no problems and the spool is still like new, but we did away with the IRS pin cushions and used Corally Assassin blades instead. After 12 meetings and at least that again in practice the spool is still like new.
MATT.
Interesting set up. I run a very similar set up myself - 30 oil and 2 degrees rear toe, and more droop (smaller figures - 5 front, 3 rear). Your gearing of 104 x 28 is just what I run with 9 turn motors too. I'm going to try running it without roll bars today.
Regards
Joe from sunny Malta.
johnbull is offline   Reply With Quote
Old 03-30-2004, 05:42 AM   #7727
Trader Rating: 35 (100%+)
Default 1st TC race in 2 years!!!
It's been a while, but our first asphalt race is scheduled for this Saturday (weather permitting).
I'm attaching a photo of my 95% completed chassis. I still need to paint my body and build my batteries.
I need help though, my two biggest concerns are proper gearing, and combatting over steer.
What gearing should I use for a large, medium grip asphalt surface with only few short turns and a long (100') straight away ending with a sweeper? (It will be a fast track, not very technical) This would be for a stock motor and a 19T motor. Also, what is the gear ratio for the SD?
Last, if I experience oversteer where should I begin trying to fix it on the SD? My last TC experience was with my MR-4TC which ran great. However, when I first started racing it eliminatig the oversteer was very frustrating.
Geppetto is offline   Reply With Quote
Old 03-30-2004, 07:15 AM   #7728
John Fontaine's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to John Fontaine
Originally posted by wcoyote
John Fontaine,
Get some plumbers putty and fill in the holes. Then remark and redrill, and sand it smooth after it has dried. It's a great quick fix for graphite and composite chassis. I used it on my graphite chassied YZ-10 when I made and error on cutting the holes for my adjustable wheelbase chassis mod. One years worth of runs, no breaks or cracks there again.
Thanks, I'll try it out. Right now it's holding pretty solidly due to the extra diameter of the washer. If I have any problems I will try this method out. I was thinking about something like this the seconds after my mistake! Thanks for the tip.
John
Xray and Serpent....very dusty!
John Fontaine is offline   Reply With Quote
Old 03-30-2004, 08:06 AM   #7729
STLNLST's Avatar
Trader Rating: 21 (100%+)
Originally posted by Matt Howard
Yeah, I'm racing the first race of the NORCAL TC Challenge down in Gilroy this weekend. You should come down too, unless you don't want to represent all your sponsors in the biggest racing series in northern california
My sponsors know that I'm testing spool set up's for the Reedy Race so a carpet trip isn't in my plans anytime soon. Besides.....I don't wish to buy foams for one day of club racing. Good luck and don't forget to promote BN RACING
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 03-30-2004, 09:34 AM   #7730
John,
You're welcome. I'm glad the washers are working for you. I don't know how I came up with the putty idea to begin with. I think I just had some lying around and the light bulb went on in my head. I guess I figured at the worst, I was going to have to buy a new chassis anyway.
wcoyote is offline   Reply With Quote
Old 03-30-2004, 04:17 PM   #7731
JimmyMac's Avatar
Geppetto, you have PM back.... Also, depends where your oversteer is. Is it oversteering goin in off power? Or is it oversteering coming out on power? If goin in, then try to either raise and/or lengthen the camber link. And you can also try adjusted the droop in the rear by raising up the arms (less droop). If it's coming out you can adjust droop up front so that you have more droop in the front. And you can also shorten or lower the front camber link. Plus you have springs and swaybars to mess with as well.
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
JimmyMac is offline   Reply With Quote
Old 03-31-2004, 04:17 AM   #7732
IH
IH's Avatar
Default CGM ans Rayspeed shock towers
Hi,
I just had the idea of using the Rayspeed shock towers with my CGM, because the rear shock tower looks very similar to the RS one.... has anyone tried that, yet?
Greetings,
IH
IH is offline   Reply With Quote
Old 03-31-2004, 04:22 AM   #7733
Tommy Bergfeldt's Avatar
Send a message via ICQ to Tommy Bergfeldt
I'm running Rayspeed towers on my SSG with no problems. I think the rayspeedtowers is much better that the original CGM and SSG towers because the shock holes is in one row and not in random positions as the SSG and CGM, with the shock setup i run on my CGM for the moent i can use 3 holes in rear and 2 holes in front. With Rayspeed towers i can use all 6 in front and rear
i'm thinking of swap the composite towers on my CGM to the Rayspeed towers because of this (they're lighter too )
JMI Motorsport / Red Bull Racing
HB Cyclone TC - Schumacher CAT SX & Cougar SV
Advanced Electronics - Autopartner.se - Sav÷x - NorthTQ
Tommy Bergfeldt is offline   Reply With Quote
Old 03-31-2004, 06:06 AM   #7734
KilRuf: Thanks for the reply. I haven't actually run the car yet. I've been working on finishing everything when I have spare time in the evenings. So when I throw the car on the track this Saturday, it will be the first time it has been run. I'm just trying to anticipate the kind of handling issues that would cause me problems finishing a heat.
Old 03-31-2004, 11:22 PM   #7735
lee82gx's Avatar
anyone knows the part number for the ride height/droop gauge?
lee82gx is offline   Reply With Quote
Old 04-01-2004, 01:06 AM   #7736
johnbull's Avatar
GEPPETTO. Good to see you back. Are you running on asphalt or carpet?
I ran my car yesterday. Hadn't run it for a while. To say I surprised myself is an understatement. It's always so good, especially since I cut this thick chassis which has completely eliminated tweek.
I started off badly, the car spinning out as soon as I power out of corners. It was both sides so I checked out all the measurements and angles, found nothing, and replaced the rear diff, and suddenly it was absolutely dialled.
I tried running the front one way but found I was loosing about a second a lap with it so put the spool back in.
Regards
Old 04-01-2004, 05:38 AM   #7737
Johnbull: I'll be racing on medium-high grip smooth asphalt, approx. 125'x90'.
Good news: The mail man delivered my Square Ti front and rear input shafts. It's increible how heavy the stock shafts are compared to these Ti units. The stock rear input shaft is actually heavier than both the front and rear Ti shafts (I should state that this is based on feel, and not a real scale).
Oh, I bought the Square parts from www.precisionrc.com and it took about 6 days for the parts to arrive.
Old 04-01-2004, 12:25 PM   #7738
acutts's Avatar
Are most people running the Graphite driveshaft or the std aluminium one?
acutts is offline   Reply With Quote
Old 04-01-2004, 05:04 PM   #7739
JimmyMac's Avatar
I run the Tobee Craft aluminium main shaft.
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
Old 04-01-2004, 08:03 PM   #7740
Matt Howard's Avatar
I have the Tobee one in both my cars. Stay away from the graphite shaft, it will twist with anything faster than a stock motor.
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
