Old 03-25-2004, 05:25 PM   #7681
Registered User
The site is under maintenance.
Aku-Man is offline   Reply With Quote
Old 03-25-2004, 06:25 PM   #7682
DickemDown's Avatar
Default Re: Re: Help
Originally posted by Hi-LowBrow
Yes,I had the problem.
what I did is shaved the servo box where is part of touching the turnbuckle.
I hope it helps.
i also had the same problem, and i did the same thing. i took my dremel and sanded it down. my ko has since died. rip. went back to my old airtronics servo.
DickemDown is offline   Reply With Quote
Old 03-25-2004, 07:06 PM   #7683
lee82gx's Avatar
Originally posted by lonestar1127
wat brand is Niki's?? any webby?
Niki is a shop/dealer from Hong Kong.
no webby but maybe you can ask for a picture
[email protected]
BTW this guys is the best in terms of price,flexibility,response and speed.He has everything under the sun ,literally.
lee82gx is offline   Reply With Quote
Old 03-26-2004, 12:00 AM   #7684
Registered User
Default spur gear
What is the biggest sizes of 48p & 64p spur gear can put in Rayspeed and CGM?
Old 03-26-2004, 01:26 AM   #7685
I think it all depends on how big of a pinion you are running. but as for max probably a 115-130.
shortygy is offline   Reply With Quote
Old 03-26-2004, 01:45 AM   #7686
Lonestar's Avatar
Originally posted by Aku-Man
I was thinking to do that, but I don't like to cut or shave servo.
remove the silent blocks on the servo mounts. Use a different ball link (shorter ball). Use standard parts
Paul
When the flag drops, the BS stops.
The train stops at the train station. The bus stops at the bus station. In my office I have a workstation.
Lonestar is offline   Reply With Quote
Old 03-26-2004, 08:18 AM   #7687
IH
IH's Avatar
I just have noticed that you canīt reach the droop set screw of the front a-arms properly when using certain camber link positions...that sucks
IH is offline   Reply With Quote
Old 03-26-2004, 08:23 AM   #7688
Joel Lagace's Avatar
gee what a terrible car! LOL
Never had that problem on my car. TRy using a hex with a ball end then you can go at it from an angle
"Without Rules its just Backyard Bashing!"
www.rcottawa.com
Joel Lagace is offline   Reply With Quote
Old 03-26-2004, 12:08 PM   #7689
IH
IH's Avatar
Btw, I am refering to the CGM
Old 03-26-2004, 01:38 PM   #7690
Techart27's Avatar
Im running a 18T (48P) pinion for my Trinity 13x2. Plannin to switch to stock motor later. What size pinions are you guys running? (21?) BTW im running the the stock size spur.
Techart27 is offline   Reply With Quote
Old 03-26-2004, 06:21 PM   #7691
Registered User
Default What went wrong???
I followed Shinnosuke Adachi's setting sheet from Rayspeed Manual. The problem I have is the rear setting. The shocks are not long enough for 5mm droop with that mounting shock position. What is the problem???
Old 03-26-2004, 07:28 PM   #7692
Use the long shock ends. Problem should be solved, even with the long RS springs.
Arclight is offline   Reply With Quote
Old 03-26-2004, 07:36 PM   #7693
Regional Moderator
daniz24's Avatar
Or you should use the SS shock body...
daniz24 is offline   Reply With Quote
Old 03-26-2004, 07:38 PM   #7694
Registered User
I used long shock body and short end as Adachi's setting sheet.
Old 03-26-2004, 07:40 PM   #7695
Registered User
Why they don't work? Is it miss printed?
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
