Old 03-08-2004, 12:53 PM   #7426
Tommy Bergfeldt's Avatar
Send a message via ICQ to Tommy Bergfeldt
Originally posted by Randman
Wow, I was never able to find that thing, I just ended up cutting the top off of the regular servo mount...
Actually i had the Dremel connected with cutoff wheel ready to cut off a regular mount when i found the right holder
Realized i nearly have one complete car in spare parts besides 3 A-armaxles, some screws and stuff.. Will order these small parts and i will have one SSG and one CGM
JMI Motorsport / Red Bull Racing
HB Cyclone TC - Schumacher CAT SX & Cougar SV
Advanced Electronics - Autopartner.se - Sav÷x - NorthTQ
Tommy Bergfeldt is offline   Reply With Quote
Old 03-08-2004, 01:08 PM   #7427
EricF's Avatar
Originally posted by Horatio
Take what?
I don't recall you having anything constructive to say on the subject at all.
You're right, there's nothing to take. Thus the big smiley face.
I just find it amusing how on the edge things can get when you write something in stead of saying it out loud face to face.
Eric
AE 12R5.2 & R6(x2) - TC7.1 convert, F6 - M05 - M05V2R
People who don't have to wait for the latest item, should not tell those that do, that "It's worth the wait"
EricF is offline   Reply With Quote
Old 03-08-2004, 01:48 PM   #7428
Horatio's Avatar
Eric
Nearly as amusing as the stuff that gets said on the rostrum - only too close to the edge in that scenario usually reults in a nasty fall ....
Rctech is comparitively far safer
Regards
Horatio
Horatio is offline   Reply With Quote
Old 03-08-2004, 06:24 PM   #7429
Registered User
2Tenths's Avatar
Graphite Hub Carriers
Has anyone else noticed that the left graphite hub carrier has some slop when you use the top of the two mounting positions (for the arm)? I've tried using different hubs and arms, but the slop just won't go away. The right side carrier is perfect, so I thought maybe it was a problem with the mould It seems like the hole for the outer suspension pin is too large. Any thoughts on what the problem is?
One other thing: I was talking to the one other driver at our track who runs the CGM and he says that the motor mount is made of magnesium. This really suprised me, but then I noticed that the metal seems lighter than aluminum, (and magnesium is). Any ideas on what the mount is made of?
2Tenths is offline   Reply With Quote
Old 03-08-2004, 06:29 PM   #7430
I had a problem with slop in one of my carriers, but after closer inspection it had a hair line crack right along the hinge pin hole. Changed the block and that was it.
I think the motor mount is like cast aluminum or sumthing
shortygy is offline   Reply With Quote
Old 03-08-2004, 06:30 PM   #7431
JusBox's Avatar
Default Re: Graphite Hub Carriers
Isn't magnesium a relatively brittle metal? I don't see that as a good thing in a rc car.... i dunno though, just thinking out loud.
JusBox is offline   Reply With Quote
Old 03-08-2004, 07:35 PM   #7432
lee82gx's Avatar
magnesium by itself is brittle and has low strength characteristics.
What we get is an alloy off magnesium and aluminum.but to call it magnesium is much more cool.
It's just the same as some titanium we have.Not pure either.
lee82gx is offline   Reply With Quote
Old 03-08-2004, 11:06 PM   #7433
NightKidZ's Avatar
Send a message via ICQ to NightKidZ
Default Re: Re: Graphite Hub Carriers
I believe AE used to make a magnesium alloy rear pod for the RC12. I really dun think it's that brittle an alloy since they do make forged mag rims for full sized competition cars and bikes.
Cheers
NightKidZ is offline   Reply With Quote
Old 03-09-2004, 01:55 AM   #7434
johnbull's Avatar
Hi guys. Greetings from Malta.
Haven't been on for 24 hourts and there's alot to answer, so here goes.
Formula 1.
Yes Ilmor build the Mercedes engine. Built in UK but financed by Mercedes. The logo on the car says Mercedes. The name says Mercedes. It's Mercedes that look lousy with it's performance.
The fact still remains that the speed of the Ferrari is a real embarrasement. As for fastest engine. BMW claimed that last year. I doubt they have the guts to claim that again this year, after last Sunday's disaster.
But back to Yokes.
Geppetto. Hopefully you have solved your diff case problem by now. In case you haven't, I suspect it could be the big bearing that is not seated properly on the diff pinion. I had this when I first built my first SD. You need to press the bearing right in. Same with the outer of the bearing in the diff case.
Both my diff cases now fit well, both diffs are nice and loose, and both covers are screwed tight. Just built another CGM and no problems there either.
Went down testing with my son Josh (TC3) yesterday evening. He ended up running regular laps half a second faster than his own lap record from last year. Only differences, 8 turn motors and 3300 cells. Last year we used 10 turns and 3000s.
Should be interesting on Sunday!
Regards
Joe from sunny Malta.
johnbull is offline   Reply With Quote
Old 03-09-2004, 02:22 AM   #7435
Horatio's Avatar
Yokomo used to use Magnesium alloy on their top of the range off road cars years ago. It's extremely light, but not as strong as Titanium.
Old 03-09-2004, 05:08 AM   #7436
Sleighty's Avatar
Formula 1.
But back to Yokes.
Regards
As far as f1 goes i think you incorrect. BMW have the fastest engine and i dont think that they claim that they do, it was obvious on the rev counter graphic during the race that they do. The fact that ferrari beat them has nothing to do with engine power its the car/tyres. In fact it was more the cold tempertatures and i think that we shall see a more true picture in malaysia in 2 weeks time. I think everybody should stop going on about how Ferrari are going to dominate the championship as they wont, the season is 18 races long, not 1 race! We shall see what happens in Malaysia! Australia has always suited the Bridgestones due to the high speed corners, when we get to slower tighter tracks with higher temperatures i think things will change. Dont forget Ferrari were lapped by Renault last year
A1-RC.com
Team Scream
Xray
Sleighty is offline   Reply With Quote
Old 03-09-2004, 05:35 AM   #7437
Trader Rating: 35 (100%+)
Default As the Transmission turns :)
Well last night I removed and reassembled my rear transmission housing. I wasn't able to identify what was causing the binding, but when rebuilding I did make sure that everything was properly seated. My drivetrain is now turning freely.
As I reinstalled the transmission housing, I constantly checked for any binding as I installed screw after screw. Believe it or not, as soon as I installed the 2 bottom screws (closest to the spur) that hold the transmission case in place the transmission began to bind again??? All I was doing is snugging the screws in place, not cranking down on them.
I continued checking the movement of the transmission as I installed the rest of the screws, and I noticed that it would bind slightly dependent on which screw I was securing and how tight I made the screw.
Anyway, I found a balance and everything is working fine. I had no idea that these plastic parts deform when screws are installed.
Thanks for all the help guys.
Geppetto is offline   Reply With Quote
Old 03-09-2004, 05:36 AM   #7438
Horatio's Avatar
Regardless of engines and whose is fastest, F1 lately always turns into a bit of a one horse race, especially since Ferrari got their act together. Ironic really cos I remember when it was always Williams and people said 'wouldn't it be nice to see a Ferrari win again'.
Personally I'd be suprised if the results were much different to last seasons, but as you said - it's very early days yet.
The fact remains - to watch and enjoy F1 these days you have to be a pretty hardcore fan, unlike other forms of motorsport which are generally far more 'easy going' to watch. It's strange that it should be like that, when you consider that F1 is the pinnicle of all motor sport.
Old 03-09-2004, 05:41 AM   #7439
Horatio's Avatar
Default Re: As the Transmission turns :)
You are right to do this - as we have discussed many times before, not all mouldings are equal, so you have to use caution when applying torque to the screws on the cases. So long as the cases are together and the diff isn't going anywhere, don't worry. The most important thing is that your tranny runs free and that your main diff bearings aren't getting pinched - I have a feeling this is what you are experiencing. 'Blue printed' diff cases are available on the tc3 for precisely the same reasons.
Regards
Horatio
Old 03-09-2004, 06:29 AM   #7440
lee82gx's Avatar
i just blew a coupla hundred bucks in hop-ups today..and man it feels good to overspend.
Question for those who have the CGM conversion:
Does the set come with graphite arms,spindles/knuckles,carriers?
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
