Old 03-08-2004, 09:08 AM   #7411
Horatio's Avatar
Originally posted by sosidge
Horatio - what I've described is an H carrier. I could show you another carrier that does not have those mould lines in it, that came with the car originally, one of the first batch of cars into the UK.
It would seem there is a further update on the H carrier that hasn't necessitated a change in part number, if you have them that are thick in the other axis as well.
What you described maybe an H carrier - as we've already established, both 4134 and 4134H have the lines that you mention. Unfortunately, my original carriers I had with the kit are in the bin where they belong.
There may well be revisions of the H versions also and the original carriers may have been discontinued by now. Either way, you cannot rely on these lines to ascertain whether a carrier is a 4134 OR a 4134H - what you describe could actually be either!!
If it's 5mm thick - it's an H, if it's 3.5mm thick, it's not!! Forget the lines... - but this is assuming that they haven't revised the H version and are making it thinner again but with a stronger material....who knows? Just so long as they are stronger I'll be happy.
Horatio is offline   Reply With Quote
Old 03-08-2004, 09:14 AM   #7412
Default Re: CGM question
Originally posted by lem2
if i place an upper deck in the CGM will it help a little in not stripping the one way gears in a frontal impact?
No, but a bigger bumper will help. Make a larger bumper reinforcement for your car, or wait a little for the large bumper for the SD to come out.
pops is offline   Reply With Quote
Old 03-08-2004, 09:25 AM   #7413
Originally posted by Sparx
I started building my SSG to CGM status today. When I had mounted the steering together i was going to put my servo in and realized there is no "small" servo holder in the CGM-Box, is it included in a parts tree in the SSG kit or what?
The "regular" servoholder is no probs because i already have two or three..
That part came with the orginal SD kit, and is located on the parts tree of part# SD-203.
Old 03-08-2004, 09:27 AM   #7414
lem2's Avatar
Default Re: Re: CGM question
Thanks! Will just probably use the NTC3 RPM bumper!
Peace and Happy Racing!
lem2 is offline   Reply With Quote
Old 03-08-2004, 09:29 AM   #7415
Tommy Bergfeldt's Avatar
Send a message via ICQ to Tommy Bergfeldt
Searched like a bat outa hell for the Servoholder and finally found it in the tree pops described
This is how long i've came now.. will move over the suspension and gearboxes from the SSG tomorrow
JMI Motorsport / Red Bull Racing
HB Cyclone TC - Schumacher CAT SX & Cougar SV
Advanced Electronics - Autopartner.se - Sav÷x - NorthTQ
Tommy Bergfeldt is offline   Reply With Quote
Old 03-08-2004, 10:16 AM   #7416
sosidge's Avatar
Why do you always have to be so argumentative?
You have in your possesion a pack that is labelled "H" and fits my description - yet you say this isn't an H!
I think Yokomo know what they are packaging. Certainly I'd have more faith in them than in you.
Perhaps there should be a special "Horatio" edition of the SD - one made of "toy" plastic, with specially mis-dimensioned parts, and parts labels that lie about what's inside!
In honour of your endless bitching about the SD.
Old 03-08-2004, 10:24 AM   #7417
EricF's Avatar
TAKE THAT!!!
AE 12R5.2 & R6(x2) - TC7.1 convert, F6 - M05 - M05V2R
People who don't have to wait for the latest item, should not tell those that do, that "It's worth the wait"
EricF is offline   Reply With Quote
Old 03-08-2004, 11:03 AM   #7418
Horatio's Avatar
Now that I'd love to see
And instead of burying your head in the sand with an 'I'm alright Jack' attitude, why don't you see the pictures I have taken, clearly showing an actual H version which is 5 mm thick, next to parts that are packaged as H parts but are only actually 3.5mm thick? Are you saying that there are 2 versions of H spec? My last order of 4134 (note that this is a different part number - you were keen to point this out a while back) look EXACTLY the same as the H versions in the bag I pictured. What does this mean? From everything you have said (despite your low opinion of me, I actually listen to you;o) I conclude that there are indeed 2 versions of 4134H - ACTUAL H versions, and standard revised items (different to the original parts, but thinner than H) put into 4134H labelled bags. Given the choice, I'd rather have the thicker ones as both types appear to made out of exactly the same material with very little fibre, if any at all.
My 'bitching' is very specific and justified regarding certain areas of the SD, areas that needed sorting out. Evidently, Yokomo thought so too and brought out revised parts fairly rapidly, whilst others were keen to say I was talking shite.
Bitching about me bitching aint going to make you right either, nor is dodging the issue. You can trust Yokomo as much as you like, but that doesn't meaning I'm sh#tting you. It doesn't solve why there are 2 different parts coming out of the same bag. NOR does it mean that looking at the moulding lines is reliable, as you say, seeing as all the CURRENT parts have them
Old 03-08-2004, 11:07 AM   #7419
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Wow, I was never able to find that thing, I just ended up cutting the top off of the regular servo mount...
Old 03-08-2004, 11:09 AM   #7420
Horatio's Avatar
Originally posted by Fike
TAKE THAT!!!
Take what?
I don't recall you having anything constructive to say on the subject at all.
Old 03-08-2004, 11:11 AM   #7421
Man, this sure got to be a war thread in a hurry.
Old 03-08-2004, 11:27 AM   #7422
sosidge's Avatar
I would say YES, there are two versions of the H.
We have now identified three different styles of carrier. I've had the original, with no reinforcements (first UK kits), and an H, with reinforcements around the driveshaft hole.
You seem to have had another H, which is thicker all-round.
Old 03-08-2004, 11:59 AM   #7423
Horatio's Avatar
Agreed.
War over and not a single flame!
See guys - even me and Sosidge can agree on things eventually! Well, sort of
BTW - am I really argumentative? I thought I was just a little stubborn
Regards
Horatio
Old 03-08-2004, 12:12 PM   #7424
Agreed.
Regards
Horatio
hey I don't know what the problem is but months ago yok came out with the graffite front hub and it is a lot beefier.. later
Chris Tosolini is offline   Reply With Quote
Old 03-08-2004, 12:21 PM   #7425
Horatio's Avatar
Yeah, I know - I'm still wanting to try them but as yet they are not available in the UK or Europe.
When I next need to make a decent size order, I'll import some to try. Until then, I have to make do with the variants - all 3 of them - OR mod my car some more to fit alloy mr4 items using rose joints, as Johnbull described.
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
