Old 03-08-2004, 06:22 AM   #7396
Tommy Bergfeldt's Avatar
Send a message via ICQ to Tommy Bergfeldt
I started building my SSG to CGM status today. When I had mounted the steering together i was going to put my servo in and realized there is no "small" servo holder in the CGM-Box, is it included in a parts tree in the SSG kit or what?
The "regular" servoholder is no probs because i already have two or three..
JMI Motorsport / Red Bull Racing
HB Cyclone TC - Schumacher CAT SX & Cougar SV
Advanced Electronics - Autopartner.se - Sav÷x - NorthTQ
Tommy Bergfeldt is offline   Reply With Quote
Old 03-08-2004, 06:34 AM   #7397
Horatio's Avatar
Default Re: Transmission Binding
Originally posted by Geppetto
Help!!! I built my SD black over the weekend. I took my time, and found it quite enjoyable.
Problem: When I tighten the transmission case on the back of the car, everything seems to bind??? If I loosen the screws on the back cover, everything moves freely.
I've narrowed down the problem to the rear transmission, but I'm not sure what I could possibly do to change things. I've reduced the number of shims to 2, but its still not free!
Help!!!
The screws on both front and rear transmission housings should only be screwed in hard enough to JUST hold the cases together -any tighter than this is un-necessary and will cause the cases to both distort (causing incorrect mesh) and pinch the diff bearings. The screws used here never vibrate loose unlike metal to metal contact, so go easy on the torque.
Hope this helps.
Horatio is offline   Reply With Quote
Old 03-08-2004, 06:44 AM   #7398
Trader Rating: 35 (100%+)
Thanks. I actually only tightened the screws enough to seal the case. The only way my transmission spins freely at all is if I leave a gap of about .5mm around the transmission housing cover.
My diffs spin freely
If I open the case comletely there's no binding
Maybe I'll just take the entire transmission apart (down to the last screw) and rebuild it to see if I get better results.
Geppetto is offline   Reply With Quote
Old 03-08-2004, 06:46 AM   #7399
Sleighty's Avatar
I know your problem and it was the same one i had when i first built my SD, its just the fact that your rear input drive just needs pushing into the transmission case a little bit futher. If you look carefully it will stick ever so slightly futher out than the front.
Losen it off the spur gear adaptor and make sure that the input drive pushed all they way into the case. Also check the bearing is pushed all the way in also. I think this happens because the transmission cases are new coming out of the mould and they are possibly a tiny bit tight.
Sleighty
A1-RC.com
Team Scream
Xray
Sleighty is offline   Reply With Quote
Old 03-08-2004, 06:47 AM   #7400
pheyhoe's Avatar
R/C Tech Charter Subscriber
twagger
[SIZE=1][COLOR=navy]Paul Heyhoe[/COLOR][/SIZE]
pheyhoe is offline   Reply With Quote
Old 03-08-2004, 06:52 AM   #7401
Horatio's Avatar
Yep! That will be it!
With a gap all the way round the tranny case, something aint right
Getting the drive bevel, pin and shaft wrong would result in that sort of problem.
Old 03-08-2004, 06:53 AM   #7402
Sleighty: Thanks. I'll take a closer look at that as a possible cause.
Old 03-08-2004, 06:54 AM   #7403
Horatio's Avatar
Originally posted by pheyhoe
twagger
Twagger? WTF?
Old 03-08-2004, 06:56 AM   #7404
Sleighty's Avatar
I think that should be it my friend, thats what was wrong with mine anyway.
Horatio: I just had a go at him for posting instead of giving me a pm please excuse his ignorance
sleighty
A1-RC.com
Team Scream
Xray
Old 03-08-2004, 07:02 AM   #7405
Thumbs up Building/maintaining the SD
I've owned driven Yokomo cars since 1996 (about 5 different variants), and I have to say that in terms of building and anticipated maintainence, this kit has to be the best.
On my belt driven Yokomo kits, I used to avoid rebuilding the diffs because it was such a chore to get to it. With the SD kit, I'll probably rebuild the diffs between heats just for the fun of it!
I also love the idea that suspension arms and transmission housings are the same front/rear. Everything is just so simple. There can't be an easier car to work on???
Old 03-08-2004, 07:09 AM   #7406
Horatio's Avatar
sleighty
Old 03-08-2004, 07:15 AM   #7407
Horatio's Avatar
Default Re: Building/maintaining the SD
You're absolutely right. I've been racing model cars for 20 years and the SD is without a doubt the easiest car to work on. It's very cleverly designed so that no job takes longer than a few minutes. Awesome.
Old 03-08-2004, 07:50 AM   #7408
pheyhoe's Avatar
lol sorry bout that, was just wonderin why he was postin here when he was meant to be at skool
please excuse my ignorance, hmmm ok i like bein ignorant
Old 03-08-2004, 08:07 AM   #7409
sosidge's Avatar
Horatio - what I've described is an H carrier. I could show you another carrier that does not have those mould lines in it, that came with the car originally, one of the first batch of cars into the UK.
It would seem there is a further update on the H carrier that hasn't necessitated a change in part number, if you have them that are thick in the other axis as well.
Old 03-08-2004, 08:46 AM   #7410
lem2's Avatar
Default CGM question
if i place an upper deck in the CGM will it help a little in not stripping the one way gears in a frontal impact?
lem2 is offline   Reply With Quote
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
