Old 02-26-2004, 10:51 AM   #7141
lee82gx's Avatar
Originally posted by forty6
Here, scroll towards the middle.
http://www.rctech.net/forum/showthre...pagenumber=234
can u provide some instructions please?
U drilled holes on the chassis??
how do you countersink the holes?
thanks
lee82gx is offline   Reply With Quote
Old 02-26-2004, 11:04 AM   #7142
Send a message via ICQ to Cobra81li200
Originally posted by rc-zombies
I bet that's just minor compared what happen to my 3mo old Odyssee... it happened just last Tuesday 24th... and What a day to spend my Birthday...
luckily no one was injured..especially my wife and my precious 2yo son.
the driver just rammed into the rear end without breaking.... he was driving a F250 service van... something must of been up...police hand-cuffed him and hauled his ass to jail....
Insurance will fully replace the van...
Seems like we have the same bday
Cobra81li200 is offline   Reply With Quote
Old 02-26-2004, 11:13 AM   #7143
rc-zombies's Avatar
I bet your birthday turned out better than mine...
Old 02-26-2004, 02:13 PM   #7144
Horatio's Avatar
thanks
If you built the SD from new, you should have have the part you need to do this simple mod. The servo is rotated 90 degrees from it's normal position and this brings the weight of it further forward and closer to the centre of the car.
To do it , you'll need to either remove the middle deck of the chassis OR trim off the mounting lugs on one side of your servo.
Remove both the steering bellcranks form the car. On the standard setup, the saver is on the right side of the car. What you'll be doing is putting it back on the left side of the car AND you'll also need to substitute servo saver PART D for PART C - you should still have this left over in your box. Attach the ball stud. This puts the servo saver arm at 180 degrees instead of 90 degrees like the standard set-up. You'll still be using the existing horn and link from the servo. The link will connect to the bellcrank OVER the propshaft.
Put the servo on the chassis in the correct position (and away from the very edge of the chassis), ensuring the horn is in-line with the ballstud on the servo saver. You'll need to very carefully mark the chassis where the 2 holes need to go for the servo mount M3 counter sunk screws. To counter sink the holes properly, you'll need to use a proper counter sink bit. OR you can just very carefully make you own countersink hole using a large drill bit OR just use a dremmel and use some 'artistic' flair. Remember though it's your chassis - don't blame anyone else if you put a dirty great hole in it
Use the pictures as a guide - it's a very simple mod, but just be careful drilling your holes - you'll only want to drill them once else your chassis will start to look a mess.
Horatio is offline   Reply With Quote
Old 02-26-2004, 02:23 PM   #7145
Horatio's Avatar
Since I've just rebuilt the car, I thought I'd check the ride height etc.
I got the ride height to 5mm all round to start off with. Now on my SSG, to acheive this I had to have considerably more pre-load on the left side of the car.
On the RS chassis, the pre-load is much closer to even both sides.
Why is this?
Old 02-26-2004, 04:45 PM   #7146
[i]
[/B]
Instead of drilling holes in your chassis, you can shoe-goo the servo in place.
Headbanger is offline   Reply With Quote
Old 02-26-2004, 08:51 PM   #7147
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Originally posted by Horatio
And the steering arrangement:
Damn that looks familiar
Old 02-26-2004, 08:56 PM   #7148
Why is this?
Dont know, but I built that car on a flat surface, and made sure the countersunk holes on the top deck were perfectly aligned when I glued the decks together
Old 02-26-2004, 08:59 PM   #7149
Ya with my servo mod I just used servo tape to hold the servo down then ran a bead of shoe goo around the servo, Worked awesome.
shortygy is offline   Reply With Quote
Old 02-26-2004, 09:34 PM   #7150
Ive ejected a servo by mounting it with shoe goo, I recommend drilling and countersinking some holes.
Old 02-26-2004, 09:49 PM   #7151
Techart27's Avatar
Default TOBEE CRAFT
I wonder if you guys can give me some opinion about the Tobee Craft products for the SD. LMK thanks
Techart27 is offline   Reply With Quote
Old 02-26-2004, 10:00 PM   #7152
Default Re: TOBEE CRAFT
From what I've seen, they are pretty good quality, very lightweight, good way to shave some grams off your car and kill some rotating mass.
Old 02-26-2004, 10:06 PM   #7153
Techart27's Avatar
Is the color the same as the aluminum from yokomo? cuz in many pictures, it seems a shade lighter (almost like teal and blue mixed)
Old 02-26-2004, 10:09 PM   #7154
The color match is not exactly the same.
Old 02-26-2004, 10:10 PM   #7155
forty6's Avatar
Yep, they are lighter. I think it matches Tamiya blue ano more.
forty6 is offline   Reply With Quote
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
