Old 02-24-2004, 12:17 AM   #7096
JohnnyRingo's Avatar
should of put two and two together. It kept throwing the pin out. I wasn't seating that pin up into the spur gear adapter.
Thanks guys!
JohnnyRingo is offline   Reply With Quote
Old 02-24-2004, 12:19 AM   #7097
OSherman's Avatar
also (when installing the bevel gear and shims) the shims will like to get caught between the gear and bearing...keeping the bevel gear from installing fully...
•KO Propo America
•EXOTEK
OSherman is offline   Reply With Quote
Old 02-24-2004, 12:20 AM   #7098
OSherman's Avatar
Thanks guys!
yea...tha will do it too...
•KO Propo America
•EXOTEK
Old 02-24-2004, 10:39 AM   #7099
Randy Caster's Avatar
Trader Rating: 46 (100%+)
I'm off to SoCal today, got some things I want to try out on the CGM, Ive had a mild understeer, but I think I'll have the problem solved today
Old 02-24-2004, 11:10 AM   #7100
Horatio's Avatar
good luck - keep us all updated! The RS chassis is now through customs, so I can expect it to arrive either tomorrow (Wednesday) or Thursday at the latest - not bad!
Regards
Horatio
Horatio is offline   Reply With Quote
Old 02-24-2004, 11:34 AM   #7101
Regards
Horatio
Cool, I'm glad that customs didn't hold it up, didn't take long at all to get to you.
Old 02-24-2004, 04:17 PM   #7102
hogdaddy77's Avatar
Default MR4-Tc to SD conversion
Can a belt drive mr4 be converted to a SD?
hogdaddy77 is offline   Reply With Quote
Old 02-24-2004, 04:18 PM   #7103
pheyhoe's Avatar
R/C Tech Charter Subscriber
very much doubt it
[SIZE=1][COLOR=navy]Paul Heyhoe[/COLOR][/SIZE]
pheyhoe is offline   Reply With Quote
Old 02-24-2004, 04:42 PM   #7104
Fire's Avatar
Default Re: MR4-Tc to SD conversion
sure
you can buy a SD kit and you get yourself a SD
just need some $$ for the conversion
Fire is offline   Reply With Quote
Old 02-24-2004, 04:48 PM   #7105
pheyhoe's Avatar
lol, yeah thats the easiest way...
Old 02-24-2004, 05:17 PM   #7106
Matt Howard's Avatar
The SD is a completely new car, the only carry overs are the shocks. So to answer your question, no it cannot
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 02-24-2004, 06:49 PM   #7107
Fire's Avatar
with the stock setting, my SD is having excessive tire wear up front, is there anyway i can fix that??
tires are sorex 28 with normal yokomo medium insert
Old 02-25-2004, 04:10 AM   #7108
Horatio's Avatar
Randman:
It arrived It took only 6 days, but bearing in mind the weekend it really only took 4 working days - awesome!
The chassis is super stiff and very 'burly'. A huge improvement. I need to undo the screws and re-tighten them on a flat surface - something heavy must have been placed on top during shipping, but it's not a problem. I'll also have to find some countersunk screws where the topdeck attaches to the gearboxes.
So far I'm impressed. I like the milled out bits on the chassis where the gearboxes and motor mount sit - very tidy
The double topdeck is well bonded. In fact I've got to hand it to you - it's a good job all round.
I'll let you know how I get on with it - it's first race will be on Sunday.
Many Thanks
Horatio
Old 02-25-2004, 11:16 AM   #7109
Horatio's Avatar
Randman:
One more thing -
The way you have the servo savers installed, sort of upside down with the tie rods underneath (it's a great idea but I'm having problems getting it to work!) - the tie rods foul the anti-roll bar balls on the front wishbones and also the wishbone pivot/hinge pin mounts.
Did you just snip the balls off the wishbones?
How did you get round the other problem?
Cheers
Horatio
Old 02-25-2004, 12:26 PM   #7110
Randman:
One more thing -
Cheers
Horatio
Im having a hard time visualizing your problem. I did have to cut the top off of the ball cup so that it wouldn't rub on the front arm pivot block, but I didn't have any other rubbing issues besides that.
Glad you like everything, that chassis should hold up on some pretty high traction tracks.
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
