Old 02-19-2004, 05:51 PM   #6976
alch's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to alch
Originally posted by ROBORAT
thanks for the info. one more thin, does it also come equiped with a front one way already? i sure hope so.
Yes it does!
alch is offline   Reply With Quote
Old 02-19-2004, 06:00 PM   #6977
If it is in the US it does not come with a one-way.
pops is offline   Reply With Quote
Old 02-19-2004, 06:36 PM   #6978
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Originally posted by rc-zombies
put the cap on top...I had mine tied to the Diode.
http://groups.msn.com/RCZOMBIES/nova...to&PhotoID=257
Still just too bulky for me, I'll just wait for the new one.
Old 02-19-2004, 06:43 PM   #6979
edseb's Avatar
Thumbs up
O kay, well I ordered the rings "just in case." They're a pain in the ass to put on, so I wanted to see if there was a functional reason other than popping off, and it sounds like there is. Thanks for the feedback.
edseb is offline   Reply With Quote
Old 02-19-2004, 06:49 PM   #6980
The only time I take the rings off is when I rebuild the diff. Best way for the rear when taking a universal off is to remove the hinge pin for the carrier. Then you can remove the universal much easier. I could never get the ring on once the universal was in the diff.
Old 02-19-2004, 06:50 PM   #6981
Jeff Werner's Avatar
Trader Rating: 15 (100%+)
Send a message via Yahoo to Jeff Werner
I have found that is you squeeze the outdrive together a slight amount when putting the Blue Ring on that they go on much easier (with no driveshaft in the outdrive).
Jeff
Jeff Werner is offline   Reply With Quote
Old 02-19-2004, 06:52 PM   #6982
Not in the US.
Old 02-19-2004, 06:55 PM   #6983
OSherman's Avatar
Exclamation
yeah, it is hard to get the rings on (especially when the universal and diff is installed) because of the fact that you actually have to squeeze the out drive 'prongs' together while sliding the ring on...
•KO Propo America
•EXOTEK
OSherman is offline   Reply With Quote
Old 02-19-2004, 08:25 PM   #6984
Fire's Avatar
you may try a zip tie as a quick fix so you can run your car b4 the rings come in
Fire is offline   Reply With Quote
Old 02-19-2004, 10:09 PM   #6985
Tek Nickal's Avatar
The zip ties sound like a good idea.
Tek Nickal is offline   Reply With Quote
Old 02-19-2004, 10:10 PM   #6986
Tek Nickal's Avatar
Yep, thats what I do.
Old 02-20-2004, 06:05 AM   #6987
alch's Avatar
Originally posted by Randman
Not in the US.
Strange.. They do here in Japan.
Old 02-20-2004, 06:37 AM   #6988
Horatio's Avatar
Leave the rings on when removing the driveshafts from the diff outdrives. The knack is to angle the driveshafts as far as possible, then pull them out. As Pops said, to do this you'll need to slide the pin out of the carriers to enable the freedom of movement and also removing the shocks helps too.
A labour saving trick here is to file a flat on the screws that hold the pins in place. These screws tend to be on the tight side and strip rather easily. If you put a flat on them, you only ever need to turn them 90 degrees to remove the pins It saves alot of time. You'll only need to take the the screws out when you replace the wishbones.
If your blue alloy diff out rings still give you grief, file some small notches on opposite sides, then line these 'notches' up with the diffout slots when it's time to remove your driveshafts.
Taking the diffs out on the SD is a 5 minute job, quicker than any other shaft car I know of, thanks to some clever design features.
Hope this helps
Horatio is offline   Reply With Quote
Old 02-20-2004, 06:50 AM   #6989
Looking for some info from my fellow SD drivers...this is a ROAR question that affects the Nats in Portland this summer. I see they are offering Stock, 19t and Mod sedan at the nats...will a person be able to race more then one class of sedan and if so which combo...I wanted to ask here because I thought someone would know.
Thanks for any info.
Jeff
Old 02-20-2004, 07:01 AM   #6990
lee82gx's Avatar
quick question:
Is there any difference physically between the black SD and the SSG SD??besides the black carbon and the silver , that is...
lee82gx is offline   Reply With Quote
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
