Old 02-19-2004, 09:47 AM   #6961
yodace's Avatar
R/C Tech Charter Subscriber
Do your remember want shock/oil springs you ran at Mike's? Can't remember.
yodace is offline   Reply With Quote
Old 02-19-2004, 09:50 AM   #6962
sosidge's Avatar
The Pro-Trak tray takes the cells down to almost 0v.
I have one, but prefer my Robitronics tray.
Old 02-19-2004, 09:52 AM   #6963
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Originally posted by Fire
oh man, i still haven't really ran my GT7, and new esc is on its way
any idea when will the novak discharger hits the street?
Novak will put them into production the end of this month, and they will most likely be avalible to the public mid march from what I've been told.
Old 02-19-2004, 09:53 AM   #6964
Originally posted by Jeff Werner
Any time frame for the release of the new products? I am going to be needing a new esc for my CGM...smaller then a quantom sounds like a nice fit...
Any info is great!
Jeff
I'll ask on that, not sure though. I'll propably go back to Novak when the new ESC is released. Bob Novak is always a very friendly guy at the track, I definately want to support them, but the GT7 + cap is just too big.
Old 02-19-2004, 09:58 AM   #6965
rc-zombies's Avatar
put the cap on top...I had mine tied to the Diode.
http://groups.msn.com/RCZOMBIES/nova...to&PhotoID=257
Old 02-19-2004, 10:15 AM   #6966
Jeff Werner's Avatar
Trader Rating: 15 (100%+)
Send a message via Yahoo to Jeff Werner
Yodace- I ran #3 pistons with 40wt oil at Mikes. I ran AE blue springs front and AE silver rear. Rest of the setup was close to box stock for that track. I ran mod that night with a 10turn KR and it was nice.
Jeff
Jeff Werner is offline   Reply With Quote
Old 02-19-2004, 12:23 PM   #6967
Registered User
2Tenths's Avatar
Originally posted by nitro_tacklebox
I have a question regarding the Rayspeed chassis VS the stock SSG chassis. I will be running the car mainly on carpet tracks, and as far as a more "carpet friendly" chassis which is the recommended chassis to go with?
Thanks!
The CGM will probably be the best chassis overall for carpet, but of those two, I would definently go with the SSG. The Rayspeed chassis has better battery and servo placement, but flexs too much for carpet racing, with foams at least. With rubber tires the story might be different, but I have not run the RS chassis with rubber tires. The two of us here at Rain that tried the RS with foams basically just gave up on eventually. I switched back to my black chassis, which is similar to the SSG, and now have switched again to the CGM. This is just my experience, but I believe others have had more success.
2Tenths is offline   Reply With Quote
Old 02-19-2004, 01:06 PM   #6968
IH
IH's Avatar
Randman: YGPM
IH is offline   Reply With Quote
Old 02-19-2004, 01:17 PM   #6969
JusBox's Avatar
yah i did this mod too, works great!
JusBox is offline   Reply With Quote
Old 02-19-2004, 03:57 PM   #6970
edseb's Avatar
O kay I have a question for you SD guys and specifically the CGM I just got. I'm sure they're the same for this part too. Anyway, on the rear where the Diff meets the CVDs, there is an Aluminum Joint ring (blue) that looks like it helps retain the drive (part# SD-501R). My question is, is it really necessary? It seams the CVD goes plenty far in to it, so popping a CVD out shouldn't be a problem, and they're a hassle to put on (I lost one when putting my car together and don't think I should have to order this small part). I left the front ones one, but is there a real functional reason to using these other than helping to keep the CVD from popping off? $3 part, plus shipping seams like a waste.
edseb is offline   Reply With Quote
Old 02-19-2004, 04:55 PM   #6971
snopro31's Avatar
Trader Rating: 36 (100%+)
As far as i found its not there to help it from poping out but to help the outdrive from breaking .
snopro31 is offline   Reply With Quote
Old 02-19-2004, 05:14 PM   #6972
mo
mo's Avatar
Yeah, it's mainly to keep the outdrive from breaking and they are more important in the front than the rear. You should be OK without them in the rear.
TLR, Spektrum, Tekin, SMC, MO-GRIP, www.factory-rc.com https://www.shapeways.com/shops/MPP
mo is offline   Reply With Quote
Old 02-19-2004, 05:14 PM   #6973
OSherman's Avatar
Exclamation
this ^^ is the real reason for the ring...
before these rings existed back in 'the day' (and when the first plastic oudrives were introduced to Touring cars) a lot of the outdrives were breaking from hard frontal inpacts of the cars... also at high speeds the outdrives were 'flaring-out' and warping... this ring was then introduced to basically 'hold the open-end of the outdrive together' during these extreme cituations...or something like that....
•KO Propo America
•EXOTEK
OSherman is offline   Reply With Quote
Old 02-19-2004, 05:14 PM   #6974
Fire's Avatar
yeah, without the ring the diff outdrives will spread and the life span will be much shorter
Fire is offline   Reply With Quote
Old 02-19-2004, 05:48 PM   #6975
ROBORAT's Avatar
Send a message via Yahoo to ROBORAT
Originally posted by Matt Howard
The CGM kit also includes all the regular plastic parts in graphite, as well as the threaded shocks and Ti turnbuckles, etc.
thanks for the info. one more thin, does it also come equiped with a front one way already? i sure hope so.
[YOKOMO BD7][REEDY RACING][TEAM ORION]
[Sanwa][LRP][Protoform]
http://www.hobbyhaven.com.my/
ROBORAT is offline   Reply With Quote
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
