Old 04-11-2003, 08:14 AM   #661
utieh's Avatar
i have a novak racer on mine which is pretty big (same case as an HPC, Hammer, Dually...) and it is still possible to tape an xxl (on its side) between it and the servo, I didn't do it cos i thought perhaps there would be to close
(afraid of glitches .)
utieh is offline   Reply With Quote
Old 04-11-2003, 08:25 AM   #662
Regional Moderator
Darkseid's Avatar
Originally posted by mo
I prefer 64 pitch. A 94 tooth spur is just a tiny bit smaller than the 70 and a 95 is just a tiny bit bigger than the 70.
mo: how close to the bottom of the chassis does your 95tooth spur come? I prefer to run RW spurs whenever I can, but the smallest size I could find was 96tooth, will this still fit the car without extending past the bottom?
Thanx
BTW: even after looking at the downloaded directions, I still don't get how they pulled off the spur gear changes without removing the upper deck, think you can explain it? If its too hard to explain with words don't worry about it.
TLR 22...Tamiya F104...
Old 04-11-2003, 08:44 AM   #663
utieh's Avatar
Default changing spur gear
you just have to remove the 4 screws of the motor mount, then you have an access to the spur gear screws .
Old 04-11-2003, 10:17 AM   #664
mo
mo's Avatar
Spur gear changing: remove the rear diff case (2 screws), pull out the diff, push out the pins for the shaft drive cup and spur gear hub, pull out rear pinion gear/shaft from rear and lift spur gear/hub up through the top brace. This sounds a little weird, but it really only takes about 1 min. to do. You can probably fit up to a 100t 64 pitch spur, but you will not be able to lift the spur up through the top deck if you go bigger than a 95 or 96.
Darkseid: If you like the RW gears, I know you will like the Xenon Perfect gears. They are just like the RW's, but you can get them in just about any size you want, in single tooth increments. Speedworld Raceway should have all the sizes in stock.
TLR, Spektrum, Tekin, SMC, MO-GRIP, www.factory-rc.com https://www.shapeways.com/shops/MPP
mo is offline   Reply With Quote
Old 04-11-2003, 10:23 AM   #665
johnbull's Avatar
Darkseid.
I use RW spur gears in 64dp. They make anything from 86 up.
Regards
Joe.
johnbull is offline   Reply With Quote
Old 04-11-2003, 01:11 PM   #666
Regional Moderator
Darkseid's Avatar
Johnbull: I was looking at them on SchumacherUSA's website(the only U.S. importer of RW gears) and the lowest 64 pitch gear I saw was 96tooth, so thats what I had my local shop order. That and a 70tooth 48pitch gear(for racing on not so clean tracks ). I really don't have to have a 95 tooth, I just wanted to make sure that the 96tooth would fit. So, since it does, I'm all good in the gearing department now.
mo: thanks for the answer on both topics. I'm sure I would like the Xenon gears, but I figure, why switch from something that I know works well and like. Especially since the RW gears are carried by some of my local shops and are cheaper than Robison's or Kimbrough. Those RW gears are the best I've ever used, so I'll stick with them.
Old 04-11-2003, 04:11 PM   #667
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
I belive that the Smallest Xenon 64p Spur is 95T...but on the 48p side they go all the way down to 66T Spurs
-Dave
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽ
B5m ◊ T5m ◊SC5m ◊ B64deez nutz
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 04-11-2003, 04:36 PM   #668
rc-zombies's Avatar
-Dave
Possibly the largest you can go is 64p 107T spur. / 47pinion
Just saw a setup on the Rayspeed website with that gearing for 23t stock.
Old 04-11-2003, 04:42 PM   #669
Thumbs down
I normally run a 69 Spur for Stock with My 23T's it seems to be the best overall size for stock and modifed on my "CUDA"..but the Yoke' SD seems to have a close final drive to that of the Cuda' 2.35(SD)2.44(CUDA)
-Dave
Old 04-11-2003, 05:01 PM   #670
STLNLST's Avatar
Trader Rating: 21 (100%+)
-Dave
87 is the smallest 64P
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 04-11-2003, 05:14 PM   #671
Man that's a Small Spur
-Dave
Old 04-11-2003, 09:14 PM   #672
JimmyMac's Avatar
MO the steering wasn't even hooked up in that picture. It was just hanging there looking like it was hooked to the other side of the horn. But thanks for looking out! I didn't want to install the horn/ball stud til I had the servo centered.
Dark, I have the electronics mounted. I'll post pictures tomorrow night. I have room with my small Futaba Receiver and LRP Competition ESC. Kinda like on my EVO3 but with alittle less room.
Jimmy Mac
JimmyMac is offline   Reply With Quote
Old 04-11-2003, 10:13 PM   #673
Kyew's Avatar
it is rumoured that the ssg SD might really be a limited edition as it is time consuming and expensive to manufacture (hence the delay). so for those who might want to wait and see, you have been warned! we will most likely see the bathtub chassis version pretty soon.
Kyew is offline   Reply With Quote
Old 04-11-2003, 10:45 PM   #674
Matt Howard's Avatar
I've been told by Yokomo USA that the SD SSG car will not be a limited edition kit and the bathtub chassis version will probably be out mid to late summer.
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 04-11-2003, 11:29 PM   #675
NightKidZ's Avatar
Send a message via ICQ to NightKidZ
Guys, FYI
link to the ENGLISH VERSION of the SD manual
http://www.teamyokomo.com/japan/manu...1_manual_e.pdf
Enjoy
NightKidZ is offline   Reply With Quote
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
