Old 02-08-2004, 11:37 AM   #6691
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Originally posted by Matt Howard
You might as well have weighed your car with rims on it then LOL throw some rubbers on there and weigh it for us
I dont have a scale, I only checked the weight there just to see what it would be, never really worry about it at the tracks down here...
Old 02-08-2004, 03:06 PM   #6692
Horatio's Avatar
Originally posted by DOTMAN
I use mineral spirits (You can get a gallon for a few bucks) and I've never had a problem either
Cheers
Horatio is offline   Reply With Quote
Old 02-08-2004, 03:08 PM   #6693
Horatio's Avatar
Originally posted by Lonestar
I'm currently cleaning new bearings with mine, right now... yes it does work, but it doesnt do any miracles. The vibrations are anything but "ultrasonic", I'd say under 100Hz. if you have carpet dust IN the bearings, it will not remove it. As I said, it does "clean" but nothing "fabulous". No magic!
I use either thinner or substitutes, or 90deg alcohol to clean stuff. the plastic doesn't melt.
Still a nice gizmo to clean metal parts, like 8th scale axles, or similar stuff.
Later,
Paul
Sounds well worth the money - I'm gonna get one soon!
Old 02-08-2004, 03:19 PM   #6694
Horatio's Avatar
Originally posted by AWOLsoldier
Hmm, i'll try this today... seeing how i've got nothing better to do.
AWOLsoldier:
So....how did it go with the bearing polishing? Did you notice an improvement?
Old 02-08-2004, 03:31 PM   #6695
JusBox's Avatar
Originally posted by Horatio
AWOLsoldier:
I didn't really see a vast improvement. I'd say it's not worth the effort.
JusBox is offline   Reply With Quote
Old 02-08-2004, 03:34 PM   #6696
Horatio's Avatar
Default 2.5 internal ratio
Just as an exapmle, running a 28 tooth pinion on kit spur and internal ratio (2.353) produces overall ratio of 1:5.8825
Doing the same thing on 2.5 conversion produces an overall ratio of 1:6.2500 - the equivalent of going down 2 teeth on the pinion using the kit set-up to 1:6.34.
I can't see how it would be better? - just different ie slightly lower overall ratio.
Perhaps the motor was cooler because the brushes had bedded in better - or because the overall ratio attained was better suited for that particular motor/track. I'd like to know how the same car/motor/cells/speedo/driver/track would do if used on the stock 2.353 but with a pinion 2 teeth smaller............my bet is that there would be no difference. Only the pain in the wallet
Old 02-08-2004, 03:38 PM   #6697
Send a message via ICQ to Cobra81li200
Horatio, we're talking for the SAME overall ratio. MO did say he used his usual overall ratio.
Cobra81li200 is offline   Reply With Quote
Old 02-08-2004, 03:41 PM   #6698
Horatio's Avatar
But you did see some improvement....
Maybe if you race 27t stock - every bit helps. Thanks for letting us know.
I've got to prep my son's TC3 this week - he's leading the Junior stock championship and is in the running for winning a RC10 B4 (yeh, I know its not a Yok - but still!! ) so long as he keeps his points advantage. Perhaps freeing up his bearings just might clinch it for him. Fingers crossed!
Old 02-08-2004, 03:47 PM   #6699
Horatio's Avatar
Well it just doesn't add up then does it? It can't be anything to do with the internal ratio. There must be some other factor - perhaps the gears are more precisely manufactured with the 2.5 conversion?
If someone can explain why it's better, I'd be happy to listen. Until then, I don't believe it.
Old 02-08-2004, 03:58 PM   #6700
Neither do I ! For me there is nothing better, even the energy required to make the car go at the same speed is higher. Needless to say the weight of the alloy gears is higher...
Old 02-08-2004, 04:03 PM   #6701
Horatio's Avatar
Valid points. Maybe we'll never know why it's 'better'....
Old 02-08-2004, 04:54 PM   #6702
mo
mo's Avatar
You guys are over analizing everything! Theories, numbers and what it's "supposed to do" don't mean anything compared to track testing. I ran the car with both a 10x1 and a stock motor. I haven't run stock in a really long time so it all feels slow to me. I had another guy at the track, that runs a Yokomo in stock all the time, put his motor and batteries in my car with as close to the same overall gear ratio as we could get. He said it was a little punchier and the motor was cooler to the touch.
I don't care what theories you can quote, track testing tells me it's good.
TLR, Spektrum, Tekin, SMC, MO-GRIP, www.factory-rc.com https://www.shapeways.com/shops/MPP
mo is offline   Reply With Quote
Old 02-08-2004, 08:25 PM   #6703
Fire's Avatar
that's where it counts
does it shows significant or unusual wear on the gears?
Fire is offline   Reply With Quote
Old 02-08-2004, 08:42 PM   #6704
Amen Mo.
Old 02-08-2004, 08:51 PM   #6705
mo
mo's Avatar
I've only run the car 1 race day so there isn't any wear.
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
