Old 02-07-2004, 04:36 PM   #6661
Send a message via Yahoo to nitro_tacklebox
I just picked up a Yok SD-SSG and the Rayspeed ultimate conversion. I should have gotten the CGM but woulda shoulda Coulda huh...
Anyway
Does anybody have any building tips to pass down?
And does anyone know where to pick up the Team Suzuki front steering knuckles? I know Speedtech has them listed, but they have been out of stock forever...I am looking to get the fronts and rears....
Thanks!
John
nitro_tacklebox is offline   Reply With Quote
Old 02-07-2004, 04:39 PM   #6662
danjoy25's Avatar
R/C Tech Charter Subscriber
Trader Rating: 37 (100%+)
Default SD Diff gears
Would a TC3 diff gear fit an SD? I am having problems with the front one way gear stripping after a few runs. How can I solve this problem?
Awesomatix A800 & A800X/ Mugen MTX-5 / 3 Racing F113 / Kyosho RB5 / Kyosho Mini-Z
danjoy25 is offline   Reply With Quote
Old 02-07-2004, 05:32 PM   #6663
mo
mo's Avatar
danjoy, the TC3 gears will not fit. If you are running a 1way, you are stripping gears either because the spacing is wrong or most likely because of hitting boards. I did this a lot before I added the buds front bumper. Anytime I would rub a board with the front wheels it would chip a tooth.
eklips, here is a picture of the bumper installation. It is a buds front bumper for a TC3 with only slight modifications. It takes about 5 min to install and really saves a lot of front end parts.
Randman, so far I am liking the 2.5 gear reduction. It only effected the puch a little but the motor temp and run time were much better. In practice, I ran the same 10x1 I ran in the main at the 2 day race in Stockton, without cutting it, and it ran for 6:15 and I could hold on to the motor without burning myself.
The car was definately better than the Rayspeed chassis car I have been running. It didn't bogg down in the middle of the corners and was very consistant. It didn't tweak at all after any impacts either. I will put the setups I ran today up on my website in a little while.
TLR, Spektrum, Tekin, SMC, MO-GRIP, www.factory-rc.com https://www.shapeways.com/shops/MPP
mo is offline   Reply With Quote
Old 02-07-2004, 06:01 PM   #6664
Matt Howard's Avatar
Originally posted by kaizen
Oh.
Hey Matt, I have been meaning to ask you if you are still running the Tobee aluminum shaft in your SD? And if so, if you would recommend it for Stock AS WELL AS 19T (the CAPS are due to my using the Yok. Graphite shaft for 19T --- for about 3 minutes! -- SNAP!).
Cheers.
I've been running the tobee center shaft and input shafts since the summer in mod and 19T with no problems, they're highly recommended if your looking lighten your drivetrain
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 02-07-2004, 06:35 PM   #6665
Registered User
2Tenths's Avatar
Randman- have you weighed your CGM yet? I won't be able to use the track scale until next Saturday or Sunday. Also, how did you get your original SD to be so light? Mine was a little bit under the weight limit, but not a ton.
2Tenths is offline   Reply With Quote
Old 02-07-2004, 06:44 PM   #6666
Randy Caster's Avatar
Trader Rating: 46 (100%+)
I'm honestly fairly surprized that you found any use of the gear reduction, I didn't think it would have any benefits, but if you're getting better runtime, I might have to try a pair for myself, where did you get them?
Old 02-07-2004, 06:47 PM   #6667
I havent weighed in the CGM, I honestly dont care about the weight of the car because none of the tracks I race at seem to have weight requirements. I dont do anything special to the cars to get them underweight, the one that was 1360 grams with the body on even had a double upper deck...
Old 02-07-2004, 06:50 PM   #6668
tcdrvr's Avatar
Default This car needs a diet
I had my yokomo weighed at snowbirds and it weighs almost 56 oz. w/ 3300 cells, it's really heavy and the suspension is still very weak
tcdrvr is offline   Reply With Quote
Old 02-07-2004, 06:54 PM   #6669
Default Re: This car needs a diet
What is the minimum weight in oz? I only know grams.
Old 02-07-2004, 06:57 PM   #6670
tcdrvr's Avatar
Default Minimum Weight
Snowbirds minimum weight was 51 oz.
Old 02-07-2004, 07:33 PM   #6671
mo
mo's Avatar
Randman, I got it at rcmodel.com.hk
Old 02-07-2004, 09:12 PM   #6672
Thanks Mo, I'll give em a look.
Old 02-07-2004, 09:15 PM   #6673
Do they happen to have an english site?
Old 02-07-2004, 10:36 PM   #6674
Fire's Avatar
they do have english in their page
i would suggest you email them to see if the parts are in stock b4 you place the order
Fire is offline   Reply With Quote
Old 02-07-2004, 10:57 PM   #6675
mo
mo's Avatar
Here is a link to the english shopping site. http://shopping.rcmodel.com.hk/index...da11579920c84f
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
