Old 02-06-2004, 08:46 AM   #6631
mo
mo's Avatar
My CGM car is almost done. Just have to do the shocks and mount the electronics. The chassis is very stiff. I love the new steering rack. I didn't have any problem with it binding. I'll be running it for the first time tomorrow in Stockton. I may not be able to run mod though. Just about the whole mod class went to the Snowbirds and most of the ones who didn't are taking a break. LOL We'll see what happens though. I'll at least practice with mod. I'll just have to bring a couple sets of shocks so I can quickly switch to a rubber tire setup to run 19 turn if I have to.
TLR, Spektrum, Tekin, SMC, MO-GRIP, www.factory-rc.com https://www.shapeways.com/shops/MPP
mo is offline   Reply With Quote
Old 02-06-2004, 09:26 AM   #6632
Randy Caster's Avatar
Trader Rating: 46 (100%+)
I'll be interested to hear how the car does at Stockton. I've already got the weekend off so I'll be up there for the ROAR race in march.
Old 02-06-2004, 10:38 AM   #6633
OSherman's Avatar
Randman.. where exactly was this 'binding' issue located.. and what was the fix?... just curious..
•KO Propo America
•EXOTEK
OSherman is offline   Reply With Quote
Old 02-06-2004, 11:01 AM   #6634
JusBox's Avatar
Originally posted by Horatio
Does anyone here polish their bearings? I recall one racer who removes the seals, cleans the bearing, apples some sort of metal polish, spins the bearing on a dremmel, then cleans away the polish and then re-lubes the bearing ready fo use.
Has anyone here tried this?
Hmm, i'll try this today... seeing how i've got nothing better to do.
JusBox is offline   Reply With Quote
Old 02-06-2004, 11:45 AM   #6635
On the left steering post, I see a potential for binding. On mine, the top of the steering arms barely clears the bottom of the cover plate. The bearings were a tight fit, but I pushed them all the way in. I imagine if they were not fully inserted, that would make the arm higher on the post causing it to rub on the cover when turned full right.
Headbanger is offline   Reply With Quote
Old 02-06-2004, 01:09 PM   #6636
Can anyone tell me were to get ss shock bodies for my rayspeed ?
thanks
mark turner is offline   Reply With Quote
Old 02-06-2004, 01:17 PM   #6637
Francis M.'s Avatar
try speedtechrc.com they carry alot of yokomo parts.
If you want to save some money you could just order
the shockbody.
TQ-racing Yokomo BD7 Airtronics
Francis M. is offline   Reply With Quote
Old 02-06-2004, 01:29 PM   #6638
Basically the top bearing in the left bellcrank wouldn't push in deep enough. When you put the top brace on, the molded in shim would put stress in the inner race of the bearing causing it to bind. Fix - I used an XActo to take material out of the inside of the bellcrank off of where the bearing sits, pushed the bearing in about .3mm deeper than stock and it's bind free.
Old 02-06-2004, 01:32 PM   #6639
thanks
Actually I used the SSS bodies on my Rayspeed with short shock ends. I believe the length was 62mm long in front, and 64mm long in rear.
Old 02-06-2004, 04:22 PM   #6640
Randman could you get the right ride height using the short shock ends?
Old 02-06-2004, 04:34 PM   #6641
Yes, without any problem actually. Just use the shock lengths I gave you and you should be able to get plenty of droop as well.
Old 02-06-2004, 05:20 PM   #6642
You can use any motor spray or w/e in the integy cleaner. Its made from some decent plastci and i have had motor spary in it for long periods of time and have had the machine for about 2 years, and its still fine.
shortygy is offline   Reply With Quote
Old 02-06-2004, 05:26 PM   #6643
I use mineral spirits (You can get a gallon for a few bucks) and I've never had a problem either
DOTMAN is offline   Reply With Quote
Old 02-06-2004, 05:32 PM   #6644
http://www.rctech.net/forum/showthre...threadid=32855
Old 02-06-2004, 05:38 PM   #6645
Registered User
2Tenths's Avatar
I've almost finished my CGM (just need to do the shocks and electronics), and had the same issue. I just used a small file and an exacto knife and got the bearing to sit flush with the top. The steering has not had any binding and is much better than the older version (less slop and freer). Overall, I'm excited to try the new chassis. It's stiffer than the plate, but I still think it flexs more than a TC3.
One issue I had, and I'd like to know if others have too, is when the rear shock tower was attached, I had trouble getting the gear box cover on. I had to loosen the tower to get the gear box closed fully, and never had this issue on the plate car.
The other weird thing: The graphite battery strap's holes were too big for the battery posts, and so it didn't fit well. Anyone else noticed this? Also, the batteries sit so deep I had to put a spacer between the strap and the c-clip holding it down to keep the batt from moving around!
2Tenths is offline   Reply With Quote
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
