Yokomo MR-4TC SD
Old 02-02-2004, 10:57 AM
  #6481
rc-zombies's Avatar
Originally posted by Randman
I'll try a couple different electronics setups and see if anything works.
Ramon - Did you bulk order those Ferrite things, you could propably get some good money for them I'd think.
One more problem, I'm trying to find a place with MIP CVD's in stock for the car, but having some bad luck, anyone know who stocks em?
yea...bought them in bulk... very cheap...I'll pm you the link and info...
I had a set of the MIPs... but sold it..... Stormer might have it.
rc-zombies is offline
Old 02-02-2004, 11:37 AM
  #6482
mo
mo's Avatar
Just finished making an interactive setup sheet for the CGM. It is now up on my website. www.mo-net.ws . Enjoy.
mo is offline
Old 02-02-2004, 11:50 AM
  #6483
Randman : place your receiver on the side so that the XTal is horizontal, it helps a lot...
Cobra81li200 is offline
Old 02-02-2004, 12:15 PM
  #6484
Matt Howard's Avatar
busy at work I see
Matt Howard is offline
Old 02-02-2004, 01:01 PM
  #6485
mo
mo's Avatar
Originally posted by Matt Howard
busy at work I see
Allways. LOL Hopefully the car will be here tomorrow.
mo is offline
Old 02-02-2004, 01:05 PM
  #6486
mo
mo's Avatar
Wow, the setup sheet has been on there for a little over 1 hour and my daily 1gb of bandwidth has already been used up. LOL
mo is offline
Old 02-02-2004, 01:53 PM
  #6487
Can you post it here?
Headbanger is offline
Old 02-02-2004, 02:17 PM
  #6488
Registered User
Default Help with dog bones.
I have 3 pairs of Square Ti dogbones before. The coupler could not fit in them. I thought they are defected. So, I bought 4 brand new Yokomo Alumn. dogbones and they all have same problem. What should I do? Are they defected? Anybody have this problem?
Aku-Man is offline
Old 02-02-2004, 03:08 PM
  #6489
Randy Caster's Avatar
Trader Rating: 47 (100%+)
Mo - I talked to Robert Itoh and he said I'd actually have to buy 3 pairs of the Yokomo MR4TC universals because the front universals are too short, or too long or something, but they need the rear bone. Did you get a direct fit, or did you have to do the same thing. I want to try a CVD (which I cant find) or a MR4TC universal...
Randy Caster is offline
Old 02-02-2004, 03:24 PM
  #6490
mo
mo's Avatar
Randman, all you have to do to the universals is grind down "ball" on the end of the bone so that it is almost down to the pin. I posted a picture some time ago. I'll have to see if I can find it.
Headbanger, it's a 1mb .pdf file, so it's too big to upload to here, I believe.
mo is offline
Old 02-02-2004, 03:25 PM
  #6491
So you do only need 2 pairs then correct?
Old 02-02-2004, 03:31 PM
  #6492
mo
mo's Avatar
I found the picture. http://www.rctech.net/forum/attachme...&postid=559775
Yes, you only need 2 pair. ZS-010FH & ZS-010RH I believe are the numbers.
mo is offline
Old 02-02-2004, 03:34 PM
  #6493
Sweet, thank you for the help there. I just talked to Steve at Speedtech, and he explained what I had to do as well. But anyway I got a couple pairs ordered for me, so I'll start using them, hope they are as good as you guys say
Old 02-02-2004, 03:38 PM
  #6494
mo
mo's Avatar
They work great. I've been running the ones in my car now for about 4 months.
mo is offline
Old 02-02-2004, 03:52 PM
  #6495
Cool, I'm sure I'll like em. Do you use the o-ring in the 1 way drive cup with them?
