Old 02-02-2004, 10:26 AM   #6466
rc-zombies's Avatar
Originally posted by Randman
Here ya go. The ESC signal wire is touching the chassis bracing, the ESC is touching the RX, and the RX is touching the servo. Not 1mm to spare
Not a whole lot of room in there...
have you tried standing up the RX?
Old 02-02-2004, 10:33 AM   #6467
tc3stocker's Avatar
Send a message via AIM to tc3stocker Send a message via Yahoo to tc3stocker
Looks like a project. Anyone thought of putting the TC3 steering bar in place of those bellcranks. Maybe some chassis milling would do the job. Does that thing come with a top deck? If not looks like another thing to make.
tc3stocker is offline   Reply With Quote
Old 02-02-2004, 10:34 AM   #6468
utieh's Avatar
Randman, where is all the red stuff???
utieh is offline   Reply With Quote
Old 02-02-2004, 10:34 AM   #6469
Horatio's Avatar
Default Re: Blades
Originally posted by tc3stocker
What are the advantages/ disadvantages of running these so-called "blades"? What is the real reason for this extra money?
After a few races, using ordinary bones, the slots in the diff outs on the SD begin to wear - this is to be expected as the diff outs we use are very light and performance oriented.
The advantages of using blades is that this wear is virtually eliminated and the drive train will have less 'snatch' in it - clearly a good thing.
Disadvantages - besides the nominal cost, none as far as I'm aware but I'll reserve judgement until I've tried them out.
Horatio is offline   Reply With Quote
Old 02-02-2004, 10:38 AM   #6470
Randy Caster's Avatar
Trader Rating: 46 (100%+)
I didn't stand up the RX, I dont have any need to because all of my stuff is really small. I have a feeling that a lot of people will be looking for more space though.
Old 02-02-2004, 10:40 AM   #6471
I did think of doing that, and then moving the servo up even more, but I'm going to see how this works for now. I do wish they would have moved the batteries more forward.
Old 02-02-2004, 10:41 AM   #6472
It'll be on there tomorrow, dont worry
Old 02-02-2004, 10:42 AM   #6473
Also, you guys can see that I put foam on the left side of the batteries, they have a bit of slop in the cell slots, so that pushes them all the way right. If anyone else wants to do this, I used Associated T2 Battery Foam.
Old 02-02-2004, 10:59 AM   #6474
Horatio's Avatar
I take it that my old Novak 410mxc won't fit then
Seriously though, that's a pretty tight space to fit all the gear. Bottom line is: if you want to race CGMs, you better have small electronics!
Or a top deck to stick stuff to!
Old 02-02-2004, 11:25 AM   #6475
I just soldered up a battery pack and turned the car on, I seem to be getting some glitching with how the electronics are setup, but I'm really not sure what is causing it, I tried with and without the personal transponder, and it doesnt seem to make a difference. Any ideas?
Old 02-02-2004, 11:30 AM   #6476
rc-zombies's Avatar
Their's a product by TN racing(Japan) it's like a Ferrite sheet you stick on your RX..suppress RFI interference.... or buy some copper sheets or tape from your electronics store and wrap your RX in it..
move the RX on top of the servo...
Old 02-02-2004, 11:38 AM   #6477
I've gotta find some of that Ferrite stuff, I notice that you and Dan have been using it, seems to work, because I havent seen you guys glitch.
Old 02-02-2004, 11:42 AM   #6478
Horatio's Avatar
It could be to do with the orientation of the ESC in relation to the receiver. If you're loathe to put stuff on top of your servo, try putting your speedo on it's side with the power leads uppermost and change the position of the receiver so that its mounted alongside the speedo longitudinally in the chassis, with the Rx Xtal as far away from the motor leads as possible. It should help.
Old 02-02-2004, 11:42 AM   #6479
rc-zombies's Avatar
The one's on the Power Wires?
I gave them to Dan to try out...
I'll send you a set tommorow.....
pm me your address again....
Old 02-02-2004, 11:54 AM   #6480
I'll try a couple different electronics setups and see if anything works.
Ramon - Did you bulk order those Ferrite things, you could propably get some good money for them I'd think.
One more problem, I'm trying to find a place with MIP CVD's in stock for the car, but having some bad luck, anyone know who stocks em?
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
