Old 01-31-2004, 10:21 AM   #6421
Jeff Werner's Avatar
Trader Rating: 15 (100%+)
Send a message via Yahoo to Jeff Werner
Really interested in the race report from the CGM this weekend! I am running the SSG currently and liked it on pavement last summer. Will be attending the Nats in Portland this summer and am starting to plan for what I am going to run. The CGM looks like a great kit and if it is anything like the tc3 will be great on all surfaces I bet.
Can't wait for thoughts on the car...lol
Jeff
Jeff Werner is offline   Reply With Quote
Old 01-31-2004, 12:34 PM   #6422
Registered User
2Tenths's Avatar
I'm also going to the Nats in Portland, probably to run Stock or 19T. I think the big question is what chassis to run. Supposedly the CGM will be used for the 2004 Worlds, and so should (hopefully ) work well outdoors. At the Region 11 race I ran the SSG and it worked well, so who knows? What I'm most looking forward to from the CGM is no more of tweak problems! At the Region 11 race, literally every run I had to de-tweak the car. There was plenty of time to do so, but it's still a hassle. I sure hope they decide to use a spec tire for the Nats.
Does anyone know if the parts in the CGM conversion will be sold separately (example: just the tub, or just the steering) to purchase as spares?
2Tenths is offline   Reply With Quote
Old 01-31-2004, 02:30 PM   #6423
Horatio's Avatar
Default Corally/RC Lab
Originally posted by Lonestar
folks, where do you actually buy RCLab parts?
Paul
http://www.rclab.co.uk
http://www.modeltech.co.uk
Hope this helps
Horatio is offline   Reply With Quote
Old 01-31-2004, 02:32 PM   #6424
Horatio's Avatar
Default Re: Re: Blades for Yok!!!
Originally posted by danjoy25
Please send me pics when youre done with this, I am interested to see what it is.
Regards,
I'll do my best, but my photography is even worse than my racing etiquette
Old 01-31-2004, 02:36 PM   #6425
Matt Howard's Avatar
I can't see why they wouldn't offer everything seperately, you might have to wait a couple weeks for all the parts to be available though
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 01-31-2004, 02:45 PM   #6426
Horatio's Avatar
Originally posted by johnbull
Horatio. Greetings from Malta.
You ask about where I get my Corally bits from.
If you look in the Corally website you will see:
Importers for UK. Model Tech. That's Mike Smith.
Importers for Malta. John Bull. That's me.
I know Mike. Very knowledgeable. But I buy direct from the factory. However, when we race in UK Mike always offers to help us with any Corally stuff we may not have with us.
Both my son and I run Corally motors and cells exclusively in our cars.
Regards
Joe from sunny Malta.
My apologies - I had no idea you were a distributor for Corally.
Old 01-31-2004, 08:32 PM   #6427
eeyan's Avatar
Send a message via AIM to eeyan Send a message via Yahoo to eeyan
I just got an SD and have ran it for a few packs. Mine is pretty much bonestock, and I noticed that the main shaft is not running straight at all. Was there ever an issue with the original main shaft not running true? Will changing to the Aluminum Suzuki drives solve this?
TAOB Racing Team (1999 - 2011)
eeyan is offline   Reply With Quote
Old 01-31-2004, 09:07 PM   #6428
wow, this is the first I've heard of someone having a bent main shaft. The suzuki drive cups won't stop you from bending a shaft, maybe your stock ones aren't seated properly?
RCTech #361
Old 01-31-2004, 11:44 PM   #6429
eeyan's Avatar
I'm sure the shaft aren't bent; and the cups are seated right. I actually tried rebuilding and moving things around and it still wobbles about 1mm when you look at it top view. I also changed the input shafts with the Tobee ones and it still does not look right when it rotates. Although I don't think the wobbling will affect handling in stock... I'm just curious if other SD owners are experiencing this?!? This is my first car with a 3 piece shaft... my EvoIII looks straight from the start probably because it uses a 1 pc shaft design.
Old 02-01-2004, 01:25 AM   #6430
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Got my CGM today, but didn't have time to build it, there are a few things that I'm going to "fix" on my mill before I run it. The parts fit is definately great, everything basically snaps together it seems like, then the screws just keep it in place.
If any CGM owners have a problem with their steering linkage binding, send me a PM, it did it on 3 of the 4 CGM's at the track today, and I found the fix for the problem, did it successfully on 2 cars.
Old 02-01-2004, 01:30 AM   #6431
Lonestar's Avatar
Sounds very weird... Are you using the O-rings in the cups?
Paul
When the flag drops, the BS stops.
The train stops at the train station. The bus stops at the bus station. In my office I have a workstation.
Lonestar is offline   Reply With Quote
Old 02-01-2004, 03:42 AM   #6432
sosidge's Avatar
I've had a wobbly shaft from time to time.
I'm not 100% sure what the cause is.
One possible problem is chassis tweak - if there's a bend in the chassis, the shaft wobble looks worse. So I would check that the chassis is dead straight.
I also think I may have a slightly off moulding in one of my joint cups.
Old 02-01-2004, 06:33 AM   #6433
eeyan's Avatar
Yeah, the O-rings are all there... I'll be racing today and see if the car just needs more break in. But I really doubt it if the wobble will affect the handling. Hopefully not...
Old 02-01-2004, 10:39 AM   #6434
We had a little wobble caused by running o'rings in both cups. I removed the rear O'ring and no wobble. We also stopped breaking rear cups, because the shaft was now deeper into the rear cup.
pops is offline   Reply With Quote
Old 02-01-2004, 11:08 AM   #6435
SpeedTech's Avatar
Hi Guys,
Just a note on the CGM car kits, it is full graphite components (suspension and chassis). While the conversion kit is graphite on the conversion components (chassis, braces, shock towers).
Steve Wang
>>>www.SpeedtechHobbies.com<<<
SpeedTech is offline   Reply With Quote
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
