Yokomo MR-4TC SD
#6406
For I, an asphalt racer has no benifit from this chassis.
#6407
Randman,
I'll probably get there around 2:00-2:30PM, so you have about 4 hours before hand to slap it on and get a few packs in
Robert Itoh from Yokomo will be there too, and he'll be trying out the CGM as well. SoCal is a high-bite asphalt, so I can find out from Randman and Robert what their impression are on the CGM compare to the SSG.
Also, in case some of you guys are interested, we will be getting a small batch of Yokomo GP3300 in stock next week. Should be some good numbers out of these.
Steve Wang
Steve Wang
#6408
Registered User
Can CGM Steering system use on RS?
Steve, when are you getting the rear bumper brace in stock?
#6409
Horatio. Greetings from Malta.
You ask about where I get my Corally bits from.
If you look in the Corally website you will see:
Importers for UK. Model Tech. That's Mike Smith.
Importers for Malta. John Bull. That's me.
I know Mike. Very knowledgeable. But I buy direct from the factory. However, when we race in UK Mike always offers to help us with any Corally stuff we may not have with us.
Both my son and I run Corally motors and cells exclusively in our cars.
Regards
Joe from sunny Malta.
Regards
#6410
mr4tc sp
hey guys i need help for me car...bought it off someone for quite a resonable deal...anyways i was rebuilding the rear diffs but come to installing it back i was confused that one part of the manual says the adjusment screw has to be on the left but another says it has to be on the right...which is which...i really dont want to screw up the thing if i installed it in the wrong side...hope someone can help me wit this..thx..
#6411
One of the diff halves is moulded with a hexagonal shape for the diff nut to go in, another is moulded smooth, that's where the thrust and diff screw go.
The diff will only fit physically in the car in one direction.
#6412
I'm afraid it won't. It fits both sides as I found out.
Took the front diff out and put it back in wrong way round by mistake.
Result: rear wheels turn forward - front wheels turn back.
Doesn't go very well that way.
regards
#6413
John, we're talking about a MR4TC SP here, not SD... It's really unlikely that the belts will go the wrong way...
#6414
But what I want to know is whether you found this out on the test-bench... or on the track? Maybe at the start of the final? That would be a sight to match the old "backwards-wired motor trick" I would think!
#6415
so should the diff adj screw be on the left or right side of the car..
#6416
Originally posted by SpeedTech
Randman,
Steve Wang
Randman,
Steve Wang
#6417
Help needed
I'm just building my new Yokomo SD Black special and with the kit I bought the ceramic ball bearings. Looking at the ceramic kit there are 2 (5mm x 8mm) bearings in the kit and I need 4, these are for the diffs as I am sure everybody is aware. I have looked at the Yokomo website and all the bearing kits come with only 2 (5mm x 8mm) bearings.
Clearly I'm missing something, but I'm not sure what. Am I supposed to use 1 ceramic and 1 standard bearing per diff, or 1 diff with ceramic bearings and 1 with standard bearings, either way, it kind of defeats the purpose of having ceramic bearings. I'm sure it's something really simple and I am just being a dumbass, so any help would be greatly appreciated.
#6419
Re: Help needed
#6420
Thanks for the help guys
