Old 01-28-2004, 03:07 AM   #6286
Send a message via ICQ to Cobra81li200
Paul : I don't have a one way, true. But I did suffer from flat spots (I assume you mean on the pins on the outdrive side) only after months of use.
It's normal if you're not using any lubricant. Besides, the increased contact surface means now they will wear slower.
I'm using the Tamiya anti wear grease since the begining on my dogbones, on both connections of the dogbones and as you can see, it works very very well.
Cobra81li200 is offline   Reply With Quote
Old 01-28-2004, 05:30 AM   #6287
Horatio's Avatar
Cobra81li200:
Doesn't using grease just attract dirt? In the past when I've used grease on driveshaft joints, the grease just turns into a sort of grinding paste and creates more problems. How do you get around that?
Horatio is offline   Reply With Quote
Old 01-28-2004, 05:49 AM   #6288
Lonestar's Avatar
Originally posted by Horatio
Cobra81li200:
cobra: same question here...
I'll have to give a shot to graphite lube, though... Wear can't get any worse than it's now, I guess... Anybody tried to adapt schum/XRay blades on their Yokes?
Paul
When the flag drops, the BS stops.
The train stops at the train station. The bus stops at the bus station. In my office I have a workstation.
Lonestar is offline   Reply With Quote
Old 01-28-2004, 08:06 AM   #6289
Registered User
2Tenths's Avatar
Alch: SSSSSSWWWWWEEEEEEEEEETTTTTTTTT!!!!!!!
It looks like the CGM is all graphite. Does it come with graphite gearboxes, arms, hubs, hub carriers etc. etc.?
Randman: If you get the CGM, are you planning to anodize it like your Rayspeed?
(By the way, I know I've seen that motor mount somewhere, but what car was it on? )
2Tenths is offline   Reply With Quote
Old 01-28-2004, 08:27 AM   #6290
Try the Tamiya Anti Wear Grease that's all I can say...
2tenth : it's been a while since we know it comes with all graphite parts...
Old 01-28-2004, 09:11 AM   #6291
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Originally posted by alch
Motor mount... Very cool, i like it!!
That motor mount kicks the hell out of the TC3 mount, I think it is very smart not to clamp down onto the graphite and warp the chassis..
Old 01-28-2004, 09:18 AM   #6292
I dont know if I'll do it right off the bat, but yes, it will be a red CGM.
Not getting much interest in the RS car except lowballers and traders, but I might have to keep it and just convert it..
Old 01-28-2004, 09:38 AM   #6293
mo
mo's Avatar
You should keep the RS car for asphalt, especially low traction surfaces. The added flex compared to the CGM will give it better traction.
TLR, Spektrum, Tekin, SMC, MO-GRIP, www.factory-rc.com https://www.shapeways.com/shops/MPP
mo is offline   Reply With Quote
Old 01-28-2004, 10:08 AM   #6294
SpeedTech's Avatar
Hi Guys,
We started the pre-order for the CGM Special Chassis kit and the CGM Special Conversion kit are available. These items should be available by early/mid next week. I will keep you all updated
Steve Wang
>>>www.SpeedtechHobbies.com<<<
SpeedTech is offline   Reply With Quote
Old 01-28-2004, 11:02 AM   #6295
John Fontaine's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to John Fontaine
Steve - looks nice. I might be interested, though I need to take the difs apart to find out whats wrong so I would order more parts along with this. One question though, this new conversion kit doesn't use an upper deck?
Xray and Serpent....very dusty!
John Fontaine is offline   Reply With Quote
Old 01-28-2004, 11:27 AM   #6296
I actually plan on building 2 CGM's, I'm planning on milling out some of the bracing on my asphault car though.
Old 01-28-2004, 11:29 AM   #6297
I just found out that the CGM does not include the graphite arms and hubs. Those are still separate. Now whether they are of the same nylon remains to be seen.
wcoyote is offline   Reply With Quote
Old 01-28-2004, 11:42 AM   #6298
I heard that it does include those items in graphite... Where did you hear that from?
Old 01-28-2004, 11:59 AM   #6299
Fire's Avatar
isn't that the CGM kit includes all those in graphite and the CGM conversion for SSG or black SD comes without graphite arms, hubs, gear boxs?
Fire is offline   Reply With Quote
Old 01-28-2004, 12:00 PM   #6300
forty6's Avatar
Well, we will find out for sure next week.
forty6 is offline   Reply With Quote
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
