Old 01-26-2004, 11:08 PM   #6241
alch's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to alch
Originally posted by NightKidZ
Alch : Please weigh your CGM chassis once you've finished building it. I am curious to know how much it weighs coz the Yokomo Japan site lists it at "about 1580g fully loaded" vs "about 1500g fully loaded" for the SSG and Black.
http://www.teamyokomo.com/japan/prod..._sd/index.html
Will do.. I will post when i am done.. either tonight or tomorrow..
alch is offline   Reply With Quote
Old 01-27-2004, 01:51 AM   #6242
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Default Re: Sorry guys
Originally posted by Jimmy Fukuyama
Sorry guys, Chris Tosolini was using my computer earlier hanging out at office and forgot to log off my system and used my handle to post. Again, sorry bout that.
Hey rc-zombie and Randman, Doing good and hopefully be promoting for my girl. Learning how music production is done correctly.
Happy Racing
Jimmy
Good luck with that Jimmy, hopefully I'll finally meet you sometime in Feb, I'll come up to visit the office when John Fontain is in town.
Old 01-27-2004, 01:52 AM   #6243
Hurry up!
Just kidding, take your time and get it right, but I am anxious to see it.
Old 01-27-2004, 02:07 AM   #6244
johnbull's Avatar
Hi friends. Greetings from Malta.
BEARINGS. From what I have been reading and hearing, there seem to be 2 schools of thought.
One the one side you have guys that will shell out for the most expensive - because they are the most expensive, so they must be best!!!!!!!!!!! A mistaken assumption in my opinion.
One the other side there are those that run the cheapest bearings but change them regularly. One of Britain's top - world class - racers confided to me that this is what he does. And his cars do alot of winning.
So, which is best. Put some dust in a ceramic bearing and it's shot. Put some dust in a cheap bearing and it's shot. I don't know what to say.
DIFFS. Do you guys run your SD diff crown wheels lubricated or dry?
Regards
Joe from sunny Malta.
johnbull is offline   Reply With Quote
Old 01-27-2004, 03:22 AM   #6245
Lonestar's Avatar
Mo, thanks for your advice. Won't a front roll bar actually rob spme initial turn-in?
Joe, I run them dry. It's my understanding that this gears's material is self-lubricating stuff. Extra lubricate would centrifugate anyway.
Still accepting setup tips from yall!
Thanks,
Paul
When the flag drops, the BS stops.
The train stops at the train station. The bus stops at the bus station. In my office I have a workstation.
Lonestar is offline   Reply With Quote
Old 01-27-2004, 04:36 AM   #6246
Send a message via ICQ to Cobra81li200
MO : I've broken one of these integrated balls for the sway bars, so I can't run it on the rear. Now my car was dialed with the bar on, but now I'm lacking initial turn in and having some on power oversteering.
How can I solve that ?
John : I run them dry, the delrin is self lubricated.
Cobra81li200 is offline   Reply With Quote
Old 01-27-2004, 06:12 AM   #6247
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
Regards
John I use the Paragon Luquid graphite on all my gears in my Yoke and now my TC3. It dries in like a minute or less. I run my car about 10 packs and stuff is still on. No extra friction with it and no mess. Dirt don't attact to it.
ST Racing Concepts (STRC)
Old 01-27-2004, 08:39 AM   #6248
mo
mo's Avatar
Cobra, try standing up your rear shocks or going to a harder rear spring. Also you can add some rear anti-squat. All of these things will give less side bite and more forward bite (more off-power steering and less on-power steering). Hope that helps.
TLR, Spektrum, Tekin, SMC, MO-GRIP, www.factory-rc.com https://www.shapeways.com/shops/MPP
mo is offline   Reply With Quote
Old 01-27-2004, 09:04 AM   #6249
Mo : I can't make them stand up more, I was thinking about the anti squat, as it's a setting I've not tried yet on that car... I'll also try the pink springs instead of yellow.
Old 01-27-2004, 09:27 AM   #6250
SpeedTech's Avatar
Hi Guys,
I got some estimated price on the CGM kit and the CGM conversion. The CGM kit will be around $259.99 and the conversion kit will be less than $100 I believe. We should have them in stock next week, and pre-order will be setup today on our website
Steve Wang
>>>www.SpeedtechHobbies.com<<<
SpeedTech is offline   Reply With Quote
Old 01-27-2004, 10:41 AM   #6251
forty6's Avatar
Steve,
Any word on the spool?
forty6 is offline   Reply With Quote
Old 01-27-2004, 11:25 AM   #6252
Steve : I sent you an e-mail about 1 week ago about the Barracuda VS MR4TC dogbones but still have no answer. I would need the information to place my order pretty soon, can you answer me ?
By the way, will you have some of the missing bits (EZ wheel hubs, tamiya suspension blocks balls, Sorex 28R) soon ?
Cheers
Fabien
Old 01-27-2004, 11:32 AM   #6253
rc-zombies's Avatar
Cheers
Fabien
I've had both cars...
'Cuda and SD dog bones are different size..not compatible..
the only parts that are compatible are the axles..same front and rear for both cars... hope this helps...
Old 01-27-2004, 12:26 PM   #6254
Nope my question was about the length of the dogbones. I need longer than the SD ones, the "old" TC front dogbones could work, but some slightly longer would be even better, so as on the cuda I saw they seemed to be very long, I wondered what was the difference in length between them (I need steel ones).
Old 01-27-2004, 12:30 PM   #6255
rc-zombies's Avatar
I'm at work...so I couldn't measure the 'cuda bones for you...but you may want to go to the 'Cuda R2 - R3 thread and ask there... you'll definately get a response...
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
