Old 01-26-2004, 01:04 PM   #6226
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
Johnbull very nice looking Yoke.
ST Racing Concepts (STRC)
Old 01-26-2004, 01:22 PM   #6227
Horatio's Avatar
Originally posted by johnbull
It just seems to do everything so much better.
Certainly tweek is a thing of the past.
Oh. One thing you will not have noticed is the prop shaft. This is a shortened TC3 carbon one. Very easy, very light and totally effective. Haven't had any trouble with it at all.
Regards
Joe from sunny Malta.
Can you still get hold of the Carbon TC3 centre drive shaft? I've heard people say that AE have stopped doing them.
Horatio is offline   Reply With Quote
Old 01-26-2004, 03:41 PM   #6228
Jimmy Fukuyama's Avatar
Originally posted by icon
Does anyone know if the car will include molded graphite pieces for the rest of the car or regular composite?
yes it will be out of graffite..
Jimmy Fukuyama is offline   Reply With Quote
Old 01-26-2004, 03:45 PM   #6229
Hey Jimmy Just wanted to say hi..
See ya sometime latter, Chris Tosolini.
Old 01-26-2004, 03:53 PM   #6230
R/C Tech Founder
R/C Tech Charter Subscriber
Uh oh, Jimmy's talking to himself... that's never a good sign.
Visit my store: www.ampdraw.com
futureal is offline   Reply With Quote
Old 01-26-2004, 04:10 PM   #6231
rc-zombies's Avatar
Hey Jimmy..
waz up dude...
Dan told me you're no longer racing and have taken up Rapping in Japan.. I say what!...
Old 01-26-2004, 04:16 PM   #6232
Lonestar's Avatar
Howdy folks,
Johnbull: Very nice car! btw, still waiting for a PM back from you about my buddy's SD...
All: some misc. comments:
- I disassembled most of my yoke this WE... Square Ti bones are completely worn out... I switched back to the original steel bones... never again...
- Front one way "spur" (sorry, I don't know how to say it in english, but I'm sure you understand what I mean) was chewed up... I guess I should have heard the noise... and used some more shims on the one-way
- removed the grease and oiled most bearings... Car has a pretty nice free-wheel now... if it weren't for two messed-up front wheel bearings. I guess I'll try another brand that yokomo's. They are crap... I'll try acer's teflasonic, they're fine on my 8th scaler.
- Practiced tonight (it's GMT+1 here)... here's a copy of a post I made on Toso's thread... maybe you guys can advise too?
Thanks!
Later,
Paul
Hey Chris,
Paul from switzerland here... I'm looking for some advice on setting up the SD... I'd appreciate if maybe you could help.
I'm running the car on carpet with rubbers, in the 12turn class.
Basically I'd been fighting the car for a while to get more initial turn in. I had always run the rear tower up front, the car was always easy, but kinda slow in the technical sections. I figured out I'd try the stock front shock tower... and then, suddenly, the car has agressive turn-in! cool, I think... The problem is, the initial turn in response is awsome and allows me to position the car very nicely into the turns (tight indoor track), but in the apex the car has a strong tendency to "dive", ie the front tires suddenly bite really hard, and, ultimately, spin-off if I let the gas off a little too much.... It is also unstable in the chicanes, towards the end. In both circonstances, I gotta be *very* careful in carrying speed if I don't want it the become *very* loose...
On power behaviour is just fine, the car has plenty of steering, just like I wanted.
I've tried several things to tame down the car mid-turn... reducing rear droop, reducing front camber intake, increasing rear camber intake... I'd like not to loose the initial turn in response. Can you please help?
Current setup: 35 oil ll and #2 pistons all around, stock springs front, second hole from inside on A-arm, rayspeed yellow rear, outside hole on a-arm, front shock tower, one way, short wheelbase, front droop 5mm (underC-hub), rear droop 6mm, long front camber link bottom lower hole, rear camber link bottom lower hole. Stock ssg chassis, no lower ssg plate.
Thanks much!
Regards,
Paul
When the flag drops, the BS stops.
The train stops at the train station. The bus stops at the bus station. In my office I have a workstation.
Lonestar is offline   Reply With Quote
Old 01-26-2004, 04:30 PM   #6233
mo
mo's Avatar
Lonestar, try putting the silver or copper front sway bar on. This should take away that mid corner hook.
TLR, Spektrum, Tekin, SMC, MO-GRIP, www.factory-rc.com https://www.shapeways.com/shops/MPP
mo is offline   Reply With Quote
Old 01-26-2004, 06:12 PM   #6234
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Originally posted by rc-zombies
Hey Jimmy..
waz up dude...
I heard the same thing! So when are you gonna cut your first CD man?
Old 01-26-2004, 06:52 PM   #6235
Default Sorry guys
Sorry guys, Chris Tosolini was using my computer earlier hanging out at office and forgot to log off my system and used my handle to post. Again, sorry bout that.
Hey rc-zombie and Randman, Doing good and hopefully be promoting for my girl. Learning how music production is done correctly.
Happy Racing
Jimmy
Old 01-26-2004, 07:54 PM   #6236
Matt Howard's Avatar
Default Re: Sorry guys
Happy Racing
Jimmy
sure Chris, we're not gonna fall for that one again LOL
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 01-26-2004, 08:29 PM   #6237
OHBRAD's Avatar
Trader Rating: 16 (100%+)
Send a message via Yahoo to OHBRAD
Default Re: CERAMIC BEARINGS
Originally posted by OHBRAD
hI Guys,
I am considering by the complete ceramic ball bearing set for the SD, if anyone can answer the following questions it would be much appreciated:
a) Are they worth getting in comparison to the original if so why?
b) With the old set i take the seals off and clean regulary, do you have to d othe same thing with ceramic bearings.
Regards Brad p
Yokomo BD818 | Sanwa | HW | Zombie | Team Yokomo | Meakin Park | Bayside | Hearns Hobbie | SpeedyRC
OHBRAD is offline   Reply With Quote
Old 01-26-2004, 08:39 PM   #6238
Send a message via Yahoo to nitro_tacklebox
Question regarding the overseas version of the SSG-SD in comparison to the US version.
All I see different is the overseas version has the one way included. Am I correct in thinking that is the only difference in the kits?
Im really interested to know. Also, should I go for the Rayspeed Chassis Kit or wait till the CGM upgrade for the SSG-SD comes available.
Thanks!
nitro_tacklebox is offline   Reply With Quote
Old 01-26-2004, 10:27 PM   #6239
Fire's Avatar
Thanks!
a LHS called yokomo usa and got a reply saying that they will ship out the CGM conversion kit as well as chassis kit anytime this week, maybe you can wait a while to see if the CGM is good for you b4 you make the move
Fire is offline   Reply With Quote
Old 01-26-2004, 11:06 PM   #6240
alch's Avatar
Send a message via ICQ to alch
Originally posted by 2Tenths
Alch: How stiff is the CGM chassis compared to the Black graphite one?
As Randman pointed out, it is much stiffer than the black chassis/upper deck..
alch is offline   Reply With Quote
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
