Yokomo MR-4TC SD
#6076
Randman..Check this out..http://www.keil-dtm.de/link_k/YokomoK5.html
Just have to order one from germany to get it in red..hehe tempting..
#6077
R/C Tech Elite Member
#6078
Originally posted by Randman
Anyone have a friend in Germany that I can talk to???
#6079
A friend of mine I race with has a brother who just brought his CS chargers back from Germany..I am going to talk with him weds night and see if his brother will be going back SOON..Let ya know..
#6080
Randman: You're right, double topdecks rule!! (for carpet)
wcoyote: The graphite gear boxes are much stiffer (material), and they stiffen the overall chassis also. I've also found that using the standard motor plate rather than the RS one helps stiffness. I'm now using the black chassis (not RS) for the same reason.
#6081
Actually I ran a double top deck this past weekend at the Toys for Tots race, it must have been the bumpiest, lowest grip surface I've ever been on, and I pulled out a win in pro stock. The trick is just go 1 step softer on the springs than you normally would.
#6082
Registered User
Product D released the 2.5 gear ratio for $40. Is it worth?
#6083
HELLLOOOOO-OOOOOO !!!
read the comments a couple of page below.
Answer is:
- if you like shiny fragile blue usueless stuff that costs the same as a practice pack, then yes.
- Else: no.
Paul
#6084
Originally posted by sosidge
Blah, Blah, Blah.
Horatio - you seem like a consumer with very high standards. Clearly the SD is a substandard car.
I suggest you go get the superior TC3 and stop boring us with your conspiracy theories about parts and deliberately keeping stuff out of the UK.
I will continue to use my SD, which, in my experience is a brilliantly engineered car, with excellent parts fit. I've broken it twice in about 8 months (also a car from the first UK batch). Of course, I BUILD my cars, rather than just ASSEMBLE them, which may be why I checked that my driveshafts moved freely.
Oh, and CML have had parts lists for the BC for a long time. I happen to have a copy of one acquired from them on my website. I don't think you'll find one in a kit even now though...
Blah, Blah, Blah.
I will continue to use my Yok SD, which is now considerably better as a result of changing those particular components, information that anyone new to the SD may find particularly helpful - especially if they find their car fragile. Rather than just deny everything and patronise them, something you're particularly good at Sosidge.
You clearly haven't read anyones messages about driveshafts and what happens to them, nor the solution to fix them - and it has nothing to do with with the maintenence side of things or 'building them properly' as you suggest.
The point I was making regarding CML and the BC was that they HAD to provide all the lists for the BC, because Yokomo wouldn't (and still wont for some reason) print the manuals with parts lists in
If I have bored anyone, I'm sorry. I won't discuss this anymore, I promise But what I will say is that this particular subject certainly got everyone talking for quite a while, so clearly everyone was soooo bored they all felt they had to post It certainly kept me busy anyway
#6085
#6086
There are no problems at all with the plastic input gears, so these alloy input gears will add up weight and change the internal ratio for nothing.
NOT WORTH IT
NOT WORTH IT
#6087
Yeah, I really cant imagine anyone on this thread buying that 2.5 internal ratio thing for $40. At least this is one thing we can all agree on
#6088
Hi guys. Greetings from Malta.
I have been following the FRAGILE PARTS saga with interest.
I run 2 SDs, and my son runs a TC3. He has a spare car but has never found it necessary to use it so far.....touch wood!
Graphite parts have their advantages, one of them isn't durability. Since I started using graphite wishbones I have been breaking more, but I don't blame the wishbones for that but my driving. Perhaps I should stick with the more durable plastic ones.
But is the Yoke SD really any weaker, or for that matter is the TC3 any weaker than some of the other cars on the market. I certainly don't think so. I would rather break a wishbone than some of the other things that habitually break with other brands.
But what amazes me most is guys who are known wreckers buying cars for which there are no parts on the market. But that's another matter to do with common sense, so we'll leave it out of the argument.
Enjoy your Yokes as I do.
Regards
Joe from sunny Malta.
Regards
#6089
Regards
Regards
There will always be wreckers that continually smash ANY car that they lay their grubby mits on, but this isn't what I was talking about at all.
Matt Howard summed up what the situation was and how it has been addressed. With the new H and G parts, the Yok SD is certainly a better car regardless of what level racer you are.
However, I couldn't recommend the Yok SD SSG to newcomers to the sport. To be fair, it's not really intended as an entry level racer I suppose.
I have more confidence in the car since fitting these parts and that alone helps me race the car faster. I'm still keen to try the G version of the Carriers - when they turn up in the UK. Same goes for the gearboxes.
#6090
Randman: YGPM
