Yokomo MR-4TC SD
#6016
Noisy diffs
does anyone else's diffs make noise? i just noticed that mine are smooth but noisy.....is this normal or wrong? i really can't see putting much diff grease in there seeing how most of it ends up getting flung out...any comments on this?
#6017
My diffs are smooth and very quiet. It could be that your diffs aren't tight enough and are 'slipping' when you apply the throttle.
It's difficult to say really unless you are more specific as regards when it happens and what it sounds like.
#6018
well it sounds like a rattling sound....but i checked them and they don't slip. But if yours are quite then i guess theres something wrong with mine. hmmmmmm
#6019
Re: Noisy diffs
#6020
check the gears, maybe a tooth is chipped.
#6021
done that too....everything looks like it's in working order, the car is fast and smooth....just noisy...
#6022
Also does anyone know of a front spool for the SD?
#6023
Coyote, it was nice to race with you again... you were very unlucky indeed, but did a wonderful free style manoeuver when you flew above the chicane 7s after the start tone! I think breaking only a rear A-arms actually shows the car is pretty strong... when I broke mine it was also totally normal.
but from what I saw, racing mod fits your style just fine, you did great And thanks for sharing your steering mod with me, I think I'll very soon do it on my car, although it does add a few grams on the car, it is critical in mod, mine seem to be "floating" at neutral indeed. Thanks again!
Horatio and cobra, well thanks for conforting me... I thought I was missing something *really* obvious with that stoopid internal gear ration change... kinda reminds me of the BK pitch idiosyncracies...
Later folks,
Paul
Later folks,
Paul
#6025
#6026
Originally posted by 2Tenths
....The sand paper diff is a good idea, but I'd worry that in 19T or mod the spool might slip.
so i just bit-the-bullet and bought extra diff parts, some old bushings for the internals and gave it a CA sealing...
it held up good for a few months of hard racing... till open practice one day and one of the 'inexperienced' lost control of their car...
will be building another..
#6028
R/C Tech Elite Member
I haven't tried this myself, but I think Tosoline made a spool by taking a one-way and epoxying the outdrives so they couldn't spin. I'd like to try it, but $35 to make a spool is a little expensive. The sand paper diff is a good idea, but I'd worry that in 19T or mod the spool might slip.
#6029
C Carriers 4134H
Guys,
I have checked my old Hub Carriers (4134) side by side with the newer 4134H Hub Carriers and there is a marked difference in the thickness between the 2 types. I'll try and get a photo posted. I'd say between 25 - 30 % thicker!!
It's my hunch that as us Brits always seem to get everything AFTER everyone else, perhaps kits in the US were getting the H version of the Carriers and Arms as standard before UK racers. To the best of my knowledge, all new UK SD kits are getting the new H parts as standard from now on.
End of mystery
End of mystery
#6030
You really are paranoid about Yokomo aren't you?
First off you think that Britain gets faulty driveshafts.
Now you think they hold back updated parts from British cars.
The fact is that when Yokomo make a part - they make a part.
And when Yokomo update a mould - they update a mould.
When they're picking parts in the packing line, they don't care one bit about which nation the car is going to (except for the ball diff/one-way and instruction manuals).
So when the kits get shipped to the US and UK - they're the same.
