Old 01-14-2004, 02:04 PM   #5911
rc-zombies's Avatar
Originally posted by Randman
I have heard a lot of people that think of the CGM as a downgrade, yes it will be cheaper for Yokomo to manufacture, but I dont think of it as a downgrade at all... The tub chassis works great for the TC3, and it has worked great on all of the previous Yokomo cars as well, so why not adapt it to the SD as well.
I could see a tub chassis coming for the Pro4 as well....
Old 01-14-2004, 02:07 PM   #5912
I figure it this way, the Yok was designed to be more adjustable than the TC3, so if you add that plus the tub chassis for less flex, wouldn't you have the best of both worlds for a high traction car?
I know flex adjustability helps on loose track, but on high traction, to much tortional twist is not the thing to have if you want to be consistant. The tub addresses that.
wcoyote is offline   Reply With Quote
Old 01-14-2004, 02:15 PM   #5913
Default Weight question
Hello Chris,
Why don't you use tape to hold your battery instead using a regular battery Holder (which is "heavy")???
Thanks,
Hugo
Hugo is offline   Reply With Quote
Old 01-14-2004, 02:56 PM   #5914
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Well I'm going to have one of those AEast chassis' coming and I'll test it heads up with the CGM car.
Old 01-14-2004, 05:47 PM   #5915
Registered User
2Tenths's Avatar
I was taking a close look at Tosolini's car in the photos from the Novak race. The graphite the chassis is made from doesn't look like the Yokomo graphite. Also, someone on this thread said they saw the car in person, and the chassis was very stiff, which should be impossible when using Yokomo's flexy graphite with just 1 top deck. Does anyone know if his chassis is custom made?
Also, I've recently been trying to get rid of the slop in the steering of my SD. The slop is almost exclusively on the left side (with standard servo placement). I've tried using different brand ball cups, plastic bag pieces between the ball studs and cups, and even attempted to use parts from the RS steering on my standard chassis to get rid of the slop. All of this has helped, but there is still some slop on the left side. Any tips or ideas on how to fix this problem?
2Tenths is offline   Reply With Quote
Old 01-14-2004, 06:22 PM   #5916
vtl1180ny's Avatar
R/C Tech Charter Subscriber
Get another servo saver setup, cut the part off that's supposed to connect to the servo and no more slop... We'll see how the yok does when it gets warm on some asphault...
vtl1180ny is offline   Reply With Quote
Old 01-14-2004, 06:55 PM   #5917
As far as Chris's car goes, he is using a thicker graphite chassis he cut himself. It is not the standard Yokomo black chassis.
Old 01-14-2004, 07:10 PM   #5918
The graphite is also much higher quality than what Yokomo includes in their kit. I know the stuff he has on his 1/12th scale is very stiff at just 2mm.
Old 01-14-2004, 07:30 PM   #5919
OHBRAD's Avatar
Trader Rating: 16 (100%+)
Send a message via Yahoo to OHBRAD
Default ANYONE KNOW WHERE TO GET THESE
hI GUYS ,
ANYONE KNOW WHERE ELSE I CAN GET SOME EXCEL DELFRIN DIFF JOINT OTHER THEN FROM SPEEDTECH
REGARDS BRAD Phttp://64.70.208.72/speedtechrc/296.html
REGARDS BRAD P
Yokomo BD818 | Sanwa | HW | Zombie | Team Yokomo | Meakin Park | Bayside | Hearns Hobbie | SpeedyRC
OHBRAD is offline   Reply With Quote
Old 01-14-2004, 07:36 PM   #5920
Randman you think you know everthing but my 1/12 is2.5mm and my tc is 3mm, Im also trying to get the 1/12 in prodution and no need for the tc chassie because the new one should be realy good..
Chris Tosolini is offline   Reply With Quote
Old 01-14-2004, 10:43 PM   #5921
I could have sworn it was 2mm, must have been the upper pod plate...
Get that 1/12 chassis into production and I'll buy a YRX12, Jason was really fast with the car.
Old 01-14-2004, 10:47 PM   #5922
forty6's Avatar
I was wondering the same thing. From what I can see, it is shiny like the stuff they use on Xrays not the dull black on the SD. Hopefully, Toso can shed light on this.
forty6 is offline   Reply With Quote
Old 01-14-2004, 11:01 PM   #5923
Propably similar stuff to the 1/12 scale. I dont think it's the shiny or dull that matters at all, it's the way the graphite is woven, and the way it is laminated. The graphite on the stock chassis has front/back and side/side weaves, but nothing diagonal which is why it twists as much as it does. If you throw in the diagonal weave, you will get a much more ridgid chassis... Or just buy a CGM chassis and make it easy
Old 01-15-2004, 12:14 AM   #5924
Tek Nickal's Avatar
Yeah, he's right. To get rid of the slop, rotate the servo mounting position, it will also have more steering response that way.
Tek Nickal is offline   Reply With Quote
Old 01-15-2004, 12:14 AM   #5925
Tek Nickal's Avatar
Pic.
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
