Old 01-06-2004, 06:42 AM   #5761
Horatio's Avatar
Default Re: hub pins missing
Originally posted by danjoy25
I keep on losing those silver pins that goes inside the drive cups.
I've seen some examples where the rubber o-ring doesn't seem to quite cover the pin enough to hold it in place. It maybe an inconsistency with the moulded plastic drive cups. It has never been a problem with my particular SD. Solution? Buy new cups OR use a band of heat shrink that is slightly wider than the o-ring.
I've said it before and I'm going to say it again - while you're at it put some batt wire size heat shrink around the CVD's where the pins are in the joint. It prevents the pins from sliding out during racing. The pins cause ALOT of damage if they slide out of position - you'll say goodbye to a steering arm if it happens at the front, or a hub if it happens at the rear - the pin will cut them in half like a hot knife through butter!!! Loosing the pin just adds insult to injury
Horatio is offline   Reply With Quote
Old 01-06-2004, 07:05 AM   #5762
Default axle's
I have been using the hardened axle's from the old car and they have given me no problem's. I think it was mid-summer when I put them in, and I average 2-3 meet's per month with 4 round's and the main. As far as speed goes I have consistantly been getting faster all along from our outdoor track, now to our new indoor track, car has been very consistant for me. Anyway's, just some info on what's working for me, as long as my ssg-sd keep's running like it is now I won't change much on it.
Bye..............
Oh yeah, my car has the al. drive cup's with o-ring's on them, and have'nt lost a pin yet. [knock on wood!]
HENRYJ is offline   Reply With Quote
Old 01-06-2004, 07:14 AM   #5763
Horatio's Avatar
Talking
The alloy drive cups look nicer too
Old 01-06-2004, 08:48 AM   #5764
kt racing's Avatar
Send a message via AIM to kt racing
I actually went and got some automotive orings and I'm using them. they are alot thicker and they cover the whole drive cup. Plus they were34cents a piece.
kt racing is offline   Reply With Quote
Old 01-06-2004, 08:50 AM   #5765
Originally posted by Randman
Those should fit no problem, I see everyone switching to the steel ones..
I think those bones are for the old YR-4?
pops is offline   Reply With Quote
Old 01-06-2004, 09:06 AM   #5766
kt racing's Avatar
There actually for the mr4tc special.
Old 01-06-2004, 10:57 AM   #5767
Intermision's Avatar
Send a message via AIM to Intermision Send a message via Yahoo to Intermision
Is there a trick to getting the diffs out without taking the whole front end apart?
Intermision is offline   Reply With Quote
Old 01-06-2004, 11:11 AM   #5768
pheyhoe's Avatar
R/C Tech Charter Subscriber
i am having problems with the pins coming out in my main shaft on mt sd, the rubber o ring that is supposed to hold them in is no good.the o ring keeps goin in the indent in the drive cup to make it easier to get the pin out. and the pin flys out during racing etc
[SIZE=1][COLOR=navy]Paul Heyhoe[/COLOR][/SIZE]
pheyhoe is offline   Reply With Quote
Old 01-06-2004, 11:14 AM   #5769
pheyhoe's Avatar
Default Corrected
i am having problems with the pins coming out in my main shaft on mt sd, the rubber o ring that is supposed to hold them in is no good. The o ring keeps pushing into the indent in the drive cup. and the pin flys out during racing etc
Old 01-06-2004, 11:15 AM   #5770
rc-zombies's Avatar
Default Re: Corrected
put a dab of shoe goo in the pin to hold it place.
Old 01-06-2004, 12:27 PM   #5771
Matt Howard's Avatar
You only have to take the bumper off then the two screws holding the cover for the front, for the rear it's just two screws. Are you talking about the SD or the older MR4TC belt drive car? the old car would take you about an hour to change a diff
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 01-06-2004, 12:37 PM   #5772
Horatio's Avatar
Great Idea!! Plentiful and cheap so therefore very easy to replace. Would they fit on the wheel hex's too?
Old 01-06-2004, 12:46 PM   #5773
Horatio's Avatar
Check my earlier post regarding use of heat shrink on CVD's and Drive Cups and also KT Racing's solution with the automotive sourced o rings. In my opinion both of these solutions will do the best job of securing the pins.
Old 01-06-2004, 12:56 PM   #5774
Horatio's Avatar
It's just a 5 minute job to take the diffs out of the SD. Easier than any other car I've worked on. If you are finding it difficult, maybe you have webbed fingers or something!!!
Old 01-06-2004, 12:57 PM   #5775
Randy Caster's Avatar
Trader Rating: 46 (100%+)
And are a TON stronger...
Although I think there may be a lighter weight solution to the strength problem, I just gotta buy some aluminum to try
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
