Old 01-04-2004, 03:29 PM   #5701
vtl1180ny's Avatar
R/C Tech Charter Subscriber
What are good parts to keep in hand for spare? Most commonly worn or broke parts for SD?
C Hubs
Steering Knuckles
Dogbones
Arms
Wheel bearings
Diff screws
I've only broken one stock plastic arm and it was in the street and I hit myself... I was going through steering hubs and knuckles constantly till I managed to find and upgrade to a set of Suzuki knuckles... Haven't broken one since... I've heard of a few broken rear hubs but have yet to break one myself... One of the main reasons the knuckles are breaking is because the kingpin backs itself out... Broke 2 diff screws, guess I run the diff's kinda tight... I also modified a NTC3 fRPM front bumper to fit the car... Haven't broken anything in weeks...
vtl1180ny is offline   Reply With Quote
Old 01-04-2004, 03:56 PM   #5702
Registered User
2Tenths's Avatar
Recently I've been breaking a lot of diff screws (3 in the last two race days!!!). Has anyone else noticed how weak the screws are? I've been running foams with tight diffs, puting a lot of strain on them. Is there anyway, besides loosening the diffs, to help the problem? Has anyone found an aftermarket or different brand of diff screw that fits and is stronger?
Just to add: If want to have spare parts around, besides diff screws, I would recommend buying extra thrust balls, diff balls, knuckles (if you don't have the aluminum ones), dogbones, stub axles (tobee's are good), and ring/pinion gears.
2Tenths is offline   Reply With Quote
Old 01-04-2004, 04:06 PM   #5703
sosidge's Avatar
Are you running plenty of grease all around the thrust assembly (spring, washers, balls, screw, the lot)? Another thing to watch out for is that you're not buying the older-style non-stepped diff screws, which would be a little weaker.
Old 01-04-2004, 05:40 PM   #5704
if the screw is braking then it is to tight. It does not to be that tight..
Chris Tosolini is offline   Reply With Quote
Old 01-04-2004, 06:02 PM   #5705
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Originally posted by STLNLST
Randman- See you next weekend and good luck to you.
Definately. Looks like I'll be putting together a new chassis for the race, my car got pretty messed up yesterday from practice..
Old 01-04-2004, 06:04 PM   #5706
I ran a fairly tight front diff yesterday to try it in practice, didn't have a problem with it though.
Chris - Thanks for the C Hubs yesterday!
Old 01-04-2004, 06:17 PM   #5707
Matt Howard's Avatar
I was cleaning my car tonight and I noticed something. Yokomo made an update sometime to the castor blocks, the newer ones have more material in the hole where the driveshaft goes through. I noticed it when I was putting the castor blocks back on my car and one looked different than the other.
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 01-04-2004, 06:23 PM   #5708
That's a good thing, I broke a caster block yesterday, not sure if it's the new or old though.
Old 01-04-2004, 06:34 PM   #5709
Registered User
Yokomo have 2 Hop-Ups for Front Hub Carrier.
SD-4134G and SD-4134H
I think G is lighter and H is stronger.
Aku-Man is offline   Reply With Quote
Old 01-04-2004, 06:38 PM   #5710
G is the graphite one, I've only got the regular plastic ones so it must be the H that is beefed up
RCTech #361
Old 01-04-2004, 06:52 PM   #5711
H is just a hard material block, dont think the mold is different.
Old 01-04-2004, 07:05 PM   #5712
vtl1180ny's Avatar
I know on the first diff screw I broke, it was too tight, the second one just snapped on me... Both times it snapped right in the middle...
The thing that drives me nuts is the battery coming out after a hard hit... During practice yesterday I lost it a few times... I ground the chassis out more and put a velcro strap around the outside of the battery and lasted me through some pretty wild crashes racing today...
Anyone know of any place that has the suzuki knuckles in stock? Not for me, I already have them....
Old 01-04-2004, 07:10 PM   #5713
Registered User
I bought my suzuki parts at hobbymania. I think they have the best price for Suzuki Alu. Upper Deck Support Mount.
Old 01-04-2004, 07:41 PM   #5714
Try the Tobee Craft cell seperators...
Old 01-04-2004, 10:34 PM   #5715
Registered User
2Tenths's Avatar
Thanks for the help. I do run a lot of AE black grease in the thrust bearing, but not on the spring, I should try that. I was running the older (?) style of diff screw with the threads all the way to the top (and it broke), and have now switched to the other style. As to the diff tightness, I had thought I saw that Chris Tosolini ran the diffs on foams: full tightness on the front, and one-quarter loosened on the rear, and this is where I was running them. From now on I'll run them a bit more loose than this and see how it goes.
Any advice on proper diff break-in? Do people just run diffs to break them in or do anything else?
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
