Old 01-04-2004, 12:34 AM   #5686
Well I'm just a Joe Average driver. I could only wish I was right off the local fast guy Mike D.! If he ran 19T class 21 laps would probably be TQ.
wilsonproperties1.com
Isaac is offline   Reply With Quote
Old 01-04-2004, 04:20 AM   #5687
sosidge's Avatar
Default Re: Servo horn
Originally posted by Intermision
What is a good aftermarket servo horn?
For what servo? I run KO servos and use KO's own horn, much stiffer and snugger fitting than the Yokomo part.
Old 01-04-2004, 08:26 AM   #5688
Intermision's Avatar
Send a message via AIM to Intermision Send a message via Yahoo to Intermision
Sosidge- Airtronics
Intermision is offline   Reply With Quote
Old 01-04-2004, 09:20 AM   #5689
sosidge's Avatar
Not a brand I've ever bought parts for, but I see GS (or was it OFNA?) do some servo horns that look very substantial and similar in design to the KO items I use - no first hand experience though.
Old 01-04-2004, 09:57 AM   #5690
Hi Fellow Yokomos!
Randman - jus curious as to , on yr earlier post regarding Springs
you mention that orange springs are not needed hence you did not include it in yr spring rate chart,any reason? Thanks
*Help* my car is louder than most shaft cars including SDs on the track any suggestions?
(Ive check the pinion spur meshing with several guys)
Much appreciated !!
marzin is offline   Reply With Quote
Old 01-04-2004, 10:43 AM   #5691
Can anybody tell me do you measure droop with the shocks on or off the lower arms ?
thanks guys
mark turner is offline   Reply With Quote
Old 01-04-2004, 10:47 AM   #5692
utieh's Avatar
thanks guys
First I set the droop with th shocks OFF, then I put them and check if I need to change their lenght (if the droop changed when I put them on).
utieh is offline   Reply With Quote
Old 01-04-2004, 10:47 AM   #5693
thanks guys
With the shocks on, if you checked the droop with them off, and the shocks were too short it would change your droop.
pops is offline   Reply With Quote
Old 01-04-2004, 10:50 AM   #5694
Sosidge- Airtronics
Never had a problem with the Yokomo servo arms for KO or Airtronics. They should be the same size.
Old 01-04-2004, 11:50 AM   #5695
Registered User
2Tenths's Avatar
Originally posted by marzin
Hi Fellow Yokomos!
Much appreciated !!
I've found that, when the car is louder than normal, it usually means there is some binding in the drivetrain. You may want to take the motor out of gear and rotate the drivetrain very slowly by hand, feeling for any sticky spots. If you find one, take the center shaft out so you can tell whether the problem is in the front or rear diff case. Once you know, redo the shimming until the problem is fixed. Also, if you do not find a sticky spot, twist the diffs and try again. The diffs are not perfectly round, and so, in a certain position they may bind more than normal. This happened on my car, and I had to simply loosen the shimming.
2Tenths is offline   Reply With Quote
Old 01-04-2004, 12:06 PM   #5696
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Where do you race?
Old 01-04-2004, 12:07 PM   #5697
Hi Fellow Yokomos!
Much appreciated !!
I bought the springs for the GT4 as well, the orange overlap with a rate for the gas car, so I really dont think they are necissary...
Old 01-04-2004, 12:40 PM   #5698
STLNLST's Avatar
Trader Rating: 21 (100%+)
Randman- See you next weekend and good luck to you.
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 01-04-2004, 01:16 PM   #5699
Originally posted by Randman
Where do you race?
Well I live in MD and race at the following places.
http://www.dougshobby.com
Doug's Hobby Shop outdoor gas and electric.
http://www.rctrack.com/images/facility/track1.jpg
http://www.rctrack.com/images/facility/track2.jpg
http://www.rctrack.com/images/facility/track3.jpg
http://www.rctrack.com/Galleries/galleries.htm
This is the carpet track that I raced yesterday. Different layout though.
http://www.fastlanerc.com - all gas mostly 1/8 scale
http://www.sandjhobbies.com - fifth scale, gas touring, 1/8 scale
http://www.hobbyworks.com - electric touring and TCS racing
outdoors
and where WYD races http://www.rcohobbies.com/ - kind of far but plan on being there soon.
Where we talk trash - http://www.rctech.net/forum/showthre...s=&threadid=66
Local fast guys: Mike Dunnigan (SMC, Jaco), Craig Xavier (Trinity, Losi), Andrew Gray (Losi, Team Orion), Todd Lewis (Fantom, Losi, SMC I think), Bob VanWagner (Team CRC) and I have to mention my friend who loaned me the 1.18 3300's Mark Unrath (SMC). These guys mostly run only at The Track on the rug again where I was yesterday. That's it Randman and probably enough.
Old 01-04-2004, 02:13 PM   #5700
Registered User
What are good parts to keep in hand for spare? Most commonly worn or broke parts for SD?
Aku-Man is offline   Reply With Quote
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
