Yokomo MR-4TC SD
Old 12-17-2003, 01:29 PM
  #5401
Horatio's Avatar
Originally posted by utieh
I had an indoor race, with steel boards everywhere and I need to 'learn to drive', had 2 or 3 big crashes, but nothing broke
I think in the case of SD, graphite parts are stronger than the normal ones, it could explain why Yokomo took so much time to release them.
Big crashes and no breakages? Perhaps there are just bad batches of arms etc so certain areas are plauged with durability issues whilst others enjoy trouble free 'motoring'.
Regarding the 'stronger arms', this would certainly explain why Yokomo took their time releasing them!! Maybe they had lots of dodgey arms to inflict on the UK racers first
Horatio is offline
Old 12-17-2003, 01:53 PM
  #5402
Tommy Bergfeldt's Avatar
Finally got pic of my SD
Tommy Bergfeldt is offline
Old 12-17-2003, 02:08 PM
  #5403
Horatio's Avatar
Thumbs up
Nice shock towers mate!
Horatio is offline
Old 12-17-2003, 02:19 PM
  #5404
Rayspeed!
I dont have the time to build a entire Ryaspeed SD so the towers is everything that sits on it now.. When i get some Ti screws and Performance Bearings i should start building the Rayspeed
BTW. How should the car be tweaked? on my Integy Laser Tweak Board i tweak the car between -5 and 0.. The laser is perfectly centered which it was'nt when it came.. Some modding and it's PERFECT
If i tweak the car straight it torqs to the left but with about -0,25 it tracks perfectly straight even on slick plastic floor..
Looks like that is the way to go
Old 12-17-2003, 03:44 PM
  #5405
vtl1180ny's Avatar
I'm wondering what a good rollout for the SD with a P2K2 on a real tight track... Curious if I'm running in the same ballpark... Due to my work schedule, I'm not getting enough track time with the car... Next year will be all about the car since I'm retiring...
vtl1180ny is offline
Old 12-17-2003, 04:06 PM
  #5406
Registered User
Hi-LowBrow's Avatar
according to YMP(Masami's dad),
Team Yokomo intends to run with CGM chassis for races after it's available.
then, I wonder how the SSG, Black, Rayspeed chassis are going ??
Hi-LowBrow is offline
Old 12-17-2003, 04:09 PM
  #5407
Blakesrc's Avatar
Trader Rating: 15 (100%+)
Vtl1180,
what surface are you running on and what tires will you be using? I have been running a 31 pinion and 94 spur on rubber tires with my p2k2's, i think a 33 pinion with a monster stock.
Blake
Blakesrc is offline
Old 12-17-2003, 06:11 PM
  #5408
vtl1180ny's Avatar
Sorry... Indoor, ozite carpet... I'm still using the stock 70 tooth gear...
Old 12-17-2003, 06:24 PM
  #5409
Regional Moderator
daniz24's Avatar
Does anyone has part number for MR-4TCSP's SSG battery plate?
It will look very very cool on my SD
daniz24 is offline
Old 12-17-2003, 06:29 PM
  #5410
Regional Moderator
daniz24's Avatar
Hey, don't race with it !!! (The car with cool shock towers)
First thing first... better put your rear drive shaft to it's place LOL
daniz24 is offline
Old 12-17-2003, 08:20 PM
  #5411
Registered User
2Tenths's Avatar
Interesting....... I heard earlier that Masami's dad thought the chassis wouldn't be for serious racing. This was probably when they were making the plastic prototypes, though, not the graphite. A plastic tub might not have worked well, but graphite should be race-approved.
As to the SSG, Black, and Rayspeed chassis's, mine might be going on eBay or the For Sale thread
2Tenths is offline
Old 12-17-2003, 08:47 PM
  #5412
Joel Lagace's Avatar
I run my SD in stock rubber and 19T foam.
For stock i run a 23 -24 tooth on my p2k2 with 70 spur. Our track is 80x36 and can be really tight when we dont build a track using a 80ft straight.
basically i have been running high 6's and low 7's in the final gear ratio.
Joel Lagace is offline
Old 12-18-2003, 01:39 AM
  #5413
Lonestar's Avatar
Originally posted by Coyote
Hi Paul,
Yes, we saw each other on your last race (we were in the same final), I'm Gabriel, don't know if you remember
Don't have a picture of my car's body, but I was the only one with an Alfa 2.0 metallic red and metallic blue.
See you
Of course I do remember you, Gabriel! We shook hands at the end of the day. It was nice to meet you and it's cool to see you here!
Later,
Paul
Lonestar is offline
Old 12-18-2003, 02:54 AM
  #5414
Rayspeed!
I dont really understand what you mean here...? Are u saying the laser tweak is off or your car...?
shortygy is offline
Old 12-18-2003, 03:45 AM
  #5415
Originally posted by Randman
Try using an insert with a little less air gap, or drilling 4 4mm holes into the rim. Both of these things will make it so the tire wont heat up as much, and you will get traction all the way through the run.
I have no problems of overheating at all, the tyres just need 1 lap to be fast but then they're consistant.
I have the same tyres/inserts/wheel setup as the top drivers so I just need a slightly better setup.
Cobra81li200 is offline
