Old 12-13-2003, 07:37 PM   #5311
STLNLST's Avatar
Trader Rating: 21 (100%+)
I'll have to get back to you on that one.
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 12-13-2003, 07:47 PM   #5312
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Cool, if you can, please PM me once you know... be sure to get it that way.
Old 12-13-2003, 07:49 PM   #5313
Registered User
2Tenths's Avatar
Originally posted by Randman
The RS motor mount does mount differently than stock, but I didn't know that the reason behind it was to reduce twist...
I think the RS motor mount is designed to allow the chassis to flex more for asphalt. It only mounts in the center of the chassis, rather than across like the kit motor mount. This is why I've stuck with the kit motor mount on my RS chassis for carpet; it stiffens the car.
I finished converting my setup so that it's close to Tosolini's. I used AE Purple and Copper springs, SSS shocks, rear shock tower up front. I was not able to use his stood up rear shock position though (Outside top mount, and 2nd arm mount from the inside). I think because the AE springs are too long. So instead, I put the Atheena rear shock tower on to stand up the shocks. We'll see how this setup works.
2Tenths is offline   Reply With Quote
Old 12-13-2003, 08:03 PM   #5314
JimmyMac's Avatar
I haven't had any trouble running the RS Chassis with 2 upper decks on carpet with foams. But then again, I only run Stock. There's less than a handfull of people that have cracked the 9 second barrier at our track and I'm one of them.
Anyways, I ran the GT350 body today. I didn't get much time with the car as I only made it in time for 1 qualifier and the mains. So far... to me... I think this body has more steering than the Alfa 2.0. But that's just me. I just need more time with it I guess. I also switched springs on the last run to AE White Springs front and AE Purple rears. But I didn't like it. Gonna go back to my original setup.
VTL1180NY, what setup did you use? Was it on carpet? I haven't had any trouble with batteries flying out. Did you sand out the battery slots enough? I'd do what Matt said and get those Tobee Craft cell separaters to keep them from flying out. I have some, just too lazy to trim them down to fit hehe.
2Tenths, that's a good question about the shocks. I think they went with the SS Shock setup on the RS chassis/towers is because the piston will stay more of in the center of the body without the possiblity of ramming up against the bladders. But then again, if you use bump stops, this shouldn't matter anyways. Hmmmm just a guess... hehe...
JimmyMac is online now   Reply With Quote
Old 12-13-2003, 10:24 PM   #5315
STLNLST's Avatar
will do. I should hopefully have that info to you no later than wednesday.
Old 12-14-2003, 04:42 AM   #5316
Good deal, thanks for your help
Old 12-14-2003, 05:41 AM   #5317
vtl1180ny's Avatar
R/C Tech Charter Subscriber
I did file the slots down, maybe I need to file them some more... I also tried foam between the strp and the battery and t would still slide out... Does anyone have a picture of those Tobee cell seperators, I want to see if I can maybe make something myself, there just isn't a hell of a lot of room...
I was having a lot of troubles with my setup, it was just not stiff enough for carpet. I changed to the knuckles at the same time as a drastic setup change so I don't really know if I can give an accurate thought on the knuckles by themselves...
2tenths, I ended up laying the rear shock down one hole to get the ride height below 6mm...
vtl1180ny is offline   Reply With Quote
Old 12-14-2003, 06:56 AM   #5318
Sleighty's Avatar
Anybody seen this chassis b4?
take a look at this chassis, i think its from Kai or somebody? looks pretty sweet tho,
here
Sleighty
A1-RC.com
Team Scream
Xray
Sleighty is offline   Reply With Quote
Old 12-14-2003, 07:46 AM   #5319
Macky's Avatar
Send a message via AIM to Macky Send a message via Yahoo to Macky
I've also cut the ends off of some ball ends and used that.
Macky is offline   Reply With Quote
Old 12-14-2003, 08:14 AM   #5320
vtl1180ny's Avatar
The ball ends sound like a good idea.. I finally snapped a ball end yesterday that was on its way out and picked up the RMP one's that I'm installing sometime this week so I'm going to have a bunch of the stock one's and nothng to do with them...
Old 12-14-2003, 08:45 AM   #5321
lonestar1127's Avatar
RPM Nuts works too
lonestar1127 is offline   Reply With Quote
Old 12-14-2003, 11:02 AM   #5322
Registered User
2Tenths's Avatar
Default Re: Anybody seen this chassis b4?
here
Sleighty
Yes, I've seen this picture before, though I haven't seen the car in person. It's a conversion made by Kai, I believe it uses the SD drivetrain with Tamiya suspension. It's supposed to be really expensive. My friend's friend has this car, and says it works well.
Old 12-14-2003, 11:37 AM   #5323
Tommy Bergfeldt's Avatar
Send a message via ICQ to Tommy Bergfeldt
Jst got home from the race.. No foams because noone was running them so i ran with Sorex 28Rs.. The car is pretty dialed now with th sorex tires. The only real problem i had was the balance. It oversteered like hell and by put tire traction on just the rear tires it ran pretty good.
I finished 7th in the Mod A-Main with racers i regularly position in 3~4 with the Xray.. But 26th-28th December it's one more race where i hope i'm going to find the best balance..
I will try to post my setup l8r!
BTW, i ran with SSG Chassies with Rayspeed Shock towers
Tommy Bergfeldt is offline   Reply With Quote
Old 12-14-2003, 11:52 AM   #5324
STLNLST's Avatar
no need to thank me. If I didn't respond Mo or Matt would have taken care of you. It will be some good fun and hopefully you won't laugh too hard when I'm announcing....LOL I get a chuckle or two out of most racers
Old 12-14-2003, 12:43 PM   #5325
Intermision's Avatar
Send a message via AIM to Intermision Send a message via Yahoo to Intermision
Default Cleaning out the bearings
What is the best way to get the stock lube out of the bearings, and what is the best oil to put in them after you clean them.
Intermision is offline   Reply With Quote
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
