Old 12-13-2003, 08:04 AM   #5296
Tommy Bergfeldt's Avatar
Send a message via ICQ to Tommy Bergfeldt
Yep, they're more forwarded on the RS.
I've been told that the motormount is updated on the RS for less twist in the chassie when accelerating.
I can't wait for tomorrow!
Tommy Bergfeldt is offline   Reply With Quote
Old 12-13-2003, 08:47 AM   #5297
Sleighty's Avatar
im sure this question has been answered further back in this thread but i cant find it, How many shims do u guys run on the front and rear input drives? ive heard from somebody to run all 3 in the rear and 1 in the front? is this correct? Also what effect will it have?
Sleighty
A1-RC.com
Team Scream
Xray
Sleighty is offline   Reply With Quote
Old 12-13-2003, 08:53 AM   #5298
Regional Moderator
Darkseid's Avatar
I run 2 up front and all 3 in the rear. The 'effect' is that you want the drivetrain to be as free as possible without having too much play or chipping diff gear teeth.
TLR 22...Tamiya F104...
Old 12-13-2003, 09:02 AM   #5299
Intermision's Avatar
Send a message via AIM to Intermision Send a message via Yahoo to Intermision
I wish christmas was ealier. My car is here but I can't even touch it. until Christmas eve. The only time I saw it was when I opened the package to make sure everything was there.
Intermision is offline   Reply With Quote
Old 12-13-2003, 10:19 AM   #5300
utieh's Avatar
Sleighty
I think it depends on the mold of the gearcase itself, for example for mine in the rear, with 3 shims, it's really tight, with two it's perfect, perhaps it would be better with just one but I don' want to have too much play
I kept all the 3 in the front.
You have to make different try to find the good shimming
utieh is offline   Reply With Quote
Old 12-13-2003, 12:40 PM   #5301
Registered User
2Tenths's Avatar
Originally posted by Randman
Congrats on the buy The RS chassis has the battery slots moved forward from what everyone has told me, so it'll have a more aggressive steering feel. If I were you, I'd run the RS car on carpet, and the SSG on asphault.
Just wanted to add that the RS chassis is extremely flexible. I would NOT run it on carpet with foam tires, I've tried and tried, and the car just isn't as fast as the competition (Xray, Losi etc.). Even the black chassis with double top decks, which is fairly stiff, had problems. However, with rubber tires and two top decks, I believe the RS should work great indoors. The RS chassis is really designed for rubber tires on asphalt, and this is where it should work the best. If you want to run foams, you should wait for the tub chassis, which will hopefully stiffen the car.
Speaking of foam setups, I haven't quite given up yet!! I just wanted to ask my question again, which is, if anyone knows: What is the difference, on carpet, between running the RS shock towers with long shocks (SS) versus running the old shock towers (rear and rear) with short shocks (SSS)?
2Tenths is offline   Reply With Quote
Old 12-13-2003, 01:12 PM   #5302
utieh's Avatar
graphite gearboxes help a lot.
have less lateral flex since I installed them with the RS chassis
Old 12-13-2003, 01:53 PM   #5303
OK! Knowledge about the SD just flows into my head
The thing is, here in Sweden we only race on rubber tirres in the big cups and championships. But we have a series in the area where i live in which we are allowed to run whatever tires we want.
Felxible cars is real good for the Schumacher White tires we race in the serie i race..
By the way, what is the internal ratio on the SD? In the setup sheets it says 2.35:1
Is that true?
Old 12-13-2003, 04:18 PM   #5304
vtl1180ny's Avatar
R/C Tech Charter Subscriber
Wow... Just got back from running my SD today and what a difference... I switched tp the Suzuki knuckles (think I got the last pair), a modified nitro TC3 bumper and no more broken C Hubs today... I did snap a rear diff screw, have no idea how and a stock ballcup that was already on its way out...
How the heck is everyone keeping their batteries from sliding out??? If someone wacked me or I hit a board just right the battery went flying...
As for the set-up sheet posted a few posts back... With AE yellow fronts and copper rears it worked beautifully... I did use a shim under the front. rear suspension mount, effectively giving the car 0 deg antidive... But otherwise I set the car up almost exactly...
vtl1180ny is offline   Reply With Quote
Old 12-13-2003, 04:34 PM   #5305
Matt Howard's Avatar
Tobee makes some neat little plastic pieces that mount on the side of the chassis to keep your batteries from ejecting themselves in a hard wreck. You can also go to a crafts store and get some thin foam strips and glue them on the sides of the battery slots. Either way will work but I use both just to make sure
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 12-13-2003, 04:56 PM   #5306
Randy Caster's Avatar
Trader Rating: 46 (100%+)
The RS motor mount does mount differently than stock, but I didn't know that the reason behind it was to reduce twist...
Old 12-13-2003, 04:58 PM   #5307
Ouch man, that sucks. My Xmas present was a GT4W2, it's already opened and the aluminum is at the anodizer
Old 12-13-2003, 05:00 PM   #5308
Did you notice a difference by going from the stock knuckles to the Suzuki knuckles performance wise?
Old 12-13-2003, 06:54 PM   #5309
STLNLST's Avatar
Trader Rating: 21 (100%+)
Originally posted by Matt Howard
haven't heard anything yet
I think that it's the weekend of Jan 10th.........
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 12-13-2003, 06:59 PM   #5310
Cool, I'll see if I can get that off, know if they will have practice during the week?
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
