Old 12-12-2003, 04:48 PM   #5281
Matt Howard's Avatar
Originally posted by Randman
Any of you Stockton racers know if there is a set date for the 2 day event yet?
haven't heard anything yet
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 12-12-2003, 05:07 PM   #5282
JimmyMac's Avatar
If you use the rear shock tower up front... you need to go with the upper holes on the tower. Not the lower ones.
JimmyMac is offline   Reply With Quote
Old 12-12-2003, 05:20 PM   #5283
Suspended
Trader Rating: 28 (100%+)
Default Randman
Middle of January is what I was told,something like 2 0r 3 weeks before snowbirds.
racenut123 is offline   Reply With Quote
Old 12-12-2003, 09:25 PM   #5284
rcfiend's Avatar
Trader Rating: 30 (100%+)
Randman - I already have the rayspeed retainers and short ends.
Kilruf - I tried using the upper holes and it was a little better, but I still couldn't get the ride height below 5mm. I just decided to go back with the original front shock tower.
Here's another one, I performed the 90 degree servo mod and now the servo tie rod is rubbing on the shaft....any suggestions???
rcfiend is offline   Reply With Quote
Old 12-12-2003, 09:42 PM   #5285
Send a message via ICQ to Cobra81li200
2mm spacer under the steering turnbuckle ballcup on the servo saver side should solve your problem.
Cobra81li200 is offline   Reply With Quote
Old 12-12-2003, 09:45 PM   #5286
[QUOTE]Originally posted by rcfiend
[B]Randman - I already have the rayspeed retainers and short ends.
Make sure the hinge pin is in the lower hole of the caster block. I you have it in the top hole given shock lengths your ride height will be to high,
pops is offline   Reply With Quote
Old 12-12-2003, 10:10 PM   #5287
rcfiend's Avatar
Cobra81li200 - I'll give that a shot.
pops - I'll check but I believe the hinge pin is in the right location.
What benefit do you get when using the rear shock tower in the front??
Old 12-12-2003, 11:02 PM   #5288
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Dang, I'd like to attend that one, but need to plan ahead for it.
Old 12-12-2003, 11:04 PM   #5289
Default Re: Randman
Good deal, Jason Erthracter (sp?) said he heard the 10-11th, but I just want to know a set date...
Old 12-12-2003, 11:05 PM   #5290
Using the rear tower up front gives you more shock mounting options, outward more will stiffen the feel of the shock, and make the steering feel a little more twitchy.
Old 12-12-2003, 11:26 PM   #5291
Intermision's Avatar
Send a message via AIM to Intermision Send a message via Yahoo to Intermision
Does the rear tower just bolt onto the front?
Intermision is offline   Reply With Quote
Old 12-13-2003, 01:35 AM   #5292
IH
IH's Avatar
IH is offline   Reply With Quote
Old 12-13-2003, 04:32 AM   #5293
Tommy Bergfeldt's Avatar
Send a message via ICQ to Tommy Bergfeldt
Just got 2 SD's with the mail yester-yesterday
VERY nice car, easy to build and wrench on. As good as my Xray i must say
I have a Rayspeed Conversion for one of them too, what benefits has the Rayspeed-chassies besides the updated steering?
The premiere-run with my SSG will be tomorow with Foam-tires. Very exciting!!
Tommy Bergfeldt is offline   Reply With Quote
Old 12-13-2003, 06:25 AM   #5294
Yeah, you just need to cut off the body mount part to fit under the body.
Old 12-13-2003, 06:26 AM   #5295
Congrats on the buy The RS chassis has the battery slots moved forward from what everyone has told me, so it'll have a more aggressive steering feel. If I were you, I'd run the RS car on carpet, and the SSG on asphault.
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
