Old 12-12-2003, 11:33 AM   #5266
rc-zombies's Avatar
Originally posted by asimo
Just wondering, how many A-arms have you guys broken on your SD?
I've snapped like 8 over 4 months! They are really fragile!
I thought by changing to the graphite arms would make it stronger but snapped on a very light hit.
Anyone else experience this?
That's why they are nicknamed "Brokomo's"
Old 12-12-2003, 11:34 AM   #5267
jarkkom's Avatar
Send a message via MSN to jarkkom
SPRING RATES
From Softest to Hardest
Electric Cars
YS-1360 Pro Spring, Black
YS-1355 Pro Spring, Blue
YS-1465 Pro Spring, White
YS-1460 Pro Spring, Flourescent Yellow
YS-14525 Pro Spring, Stainless
YS-14575 Pro Spring, Flourescent Pink
YS-1455 Pro Spring, Flourescent Green
YS-1560 GT-4 Shock Spring Set, Dark Green
YS-1450 Pro Spring, Flourescent Orange
Nitro Cars
YS-1660 GT-4 Pro Spring, Red
YS-1655 GT-4 Pro Spring, Yellow
YS-1650 GT-4 Pro Spring, Green
YS-1760 GT-4 Shock Spring Set, Polished Silver
YS-1755 GT-4 Pro Spring, Grey
YS-1750 GT-4 Pro Spring, Brown
from yokomousa.com
jarkkom is offline   Reply With Quote
Old 12-12-2003, 11:36 AM   #5268
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Dont jinx me, the car holds up fine so far
Got to work on building the GT4 last night, the fit on the parts on that car is perfect, there is absolutely no slop, and no bind at the same time, it's awesome
Old 12-12-2003, 12:13 PM   #5269
Jeff Werner's Avatar
Trader Rating: 15 (100%+)
Send a message via Yahoo to Jeff Werner
To get the -1 kickup (antidive) I would use the Alum 0 Kick front mount and put 1mm shim under the rear hinge pin mount. The stock Kickup Mount is +1 so if you put 1mm shim under rear would take you to 0 kick......
Just my thoughts.
Jeff
Jeff Werner is offline   Reply With Quote
Old 12-12-2003, 12:20 PM   #5270
vtl1180ny's Avatar
R/C Tech Charter Subscriber
Hmmmm... I wonder what 2 shims under the rear would do???
vtl1180ny is offline   Reply With Quote
Old 12-12-2003, 12:22 PM   #5271
Propably give some pretty good turnin.
Old 12-12-2003, 12:31 PM   #5272
vtl1180ny's Avatar
I think I'm going to knock it down to zero and try it out...
Old 12-12-2003, 12:42 PM   #5273
The only problem I can forsee at least with my RS steering is the ballcups would propably hit the pivot block.
Old 12-12-2003, 03:24 PM   #5274
rcfiend's Avatar
Trader Rating: 30 (100%+)
Anyone have this problem...I installed the rear shock tower on the front and I can't get the ride height below 6mm. I'm running the stock shock bodies, do you have to run the long shock bodies???
rcfiend is offline   Reply With Quote
Old 12-12-2003, 03:28 PM   #5275
Try the short shock ends.
Old 12-12-2003, 03:42 PM   #5276
rcfiend's Avatar
Randman - that's what I have on the car now. I didn't change anything from stock except for putting the rear shock tower in the front.
Old 12-12-2003, 03:48 PM   #5277
JusBox's Avatar
Try the long shock ends then.
JusBox is offline   Reply With Quote
Old 12-12-2003, 03:57 PM   #5278
rcfiend's Avatar
OK which one is it....long or short. Does the hole on the shock tower has anything to do with it?? I have it all the way out on the shock tower.
Old 12-12-2003, 04:30 PM   #5279
Go with the RS spring retainers with the short ends, they will give you another 3-4mm of room.
Old 12-12-2003, 04:35 PM   #5280
Any of you Stockton racers know if there is a set date for the 2 day event yet?
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
