Old 12-09-2003, 08:19 AM   #5176
Send a message via ICQ to Cobra81li200
Originally posted by Lonestar
Cobra, vous ici ??? A l'abri des quolibets de Cyril?
a+
Paul
Cobra81li200 is offline   Reply With Quote
Old 12-09-2003, 09:02 AM   #5177
IH
IH's Avatar
Matt Howard - Yesterday I have tried your Stockton Rayspeed setup that you posted some pages ago. It worked very well and I think it is a great base setup for carpet racing with rubber tires!
But I am wondering how you managed to use the long shock ends
on front. When I installed them ride height was bizarre. I just could not get less than 7mm ride height! Therefore I went with the short ones. Do you remember the shock length on front. Did you use RS or Yokomo retainers?
Thanks,
ingo
IH is offline   Reply With Quote
Old 12-09-2003, 09:04 AM   #5178
Suspended
Trader Rating: 28 (100%+)
If I am not mistaken he uses the rayspeed retainers.I run his setup also.
racenut123 is offline   Reply With Quote
Old 12-09-2003, 09:06 AM   #5179
Matt Howard's Avatar
Thanks,
ingo
RS retainers front and rear with the long shock ends, glad you liked it
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 12-09-2003, 09:20 AM   #5180
Randy Caster's Avatar
Trader Rating: 46 (100%+)
I need to get some RS retainers, hopefully SoCal will have some today...
Old 12-09-2003, 09:22 AM   #5181
utieh's Avatar
Thanks,
ingo
When was it? can't find the page where you've posted this set-up.
Have a carpet/rubber race next sunday...
utieh is offline   Reply With Quote
Old 12-09-2003, 09:26 AM   #5182
IH
IH's Avatar
Thatsīs weird!! Long (Yokomo) shock ends+ rs retainers?
The RS retainers compress the sprigs even more, donīt they?
I have also tried them but i had way too much ride height with them.
Old 12-09-2003, 09:28 AM   #5183
IH
IH's Avatar
utieh- it was around p.140
Old 12-09-2003, 09:37 AM   #5184
utieh's Avatar
thanks
Old 12-09-2003, 09:37 AM   #5185
rc-zombies's Avatar
I've got (2) N.I.B. I was going to use on the R2... but don't need any longer.
Old 12-09-2003, 09:38 AM   #5186
Damn Ramon... what don't you have
You need any milling work yet?
Old 12-09-2003, 09:51 AM   #5187
C Verano's Avatar
The RS shock retainers should not compress the spring more than the stock plastic one. Maybe you have them installed upside down??
C Verano is offline   Reply With Quote
Old 12-09-2003, 10:00 AM   #5188
Suspended
Hey Matt helped me with that problem also....what wholes are you using on the c-hubs?Bottom or top hinge pin holes? use the bottom holes if you are now using the top hole.I couldnt figure it out for awhile and Matt finally said to check it and sure enough it was the fix for my high ride height problem.If thats not the problem the what are your shock lengths?
Old 12-09-2003, 10:28 AM   #5189
I did just use the short shock ends on the front on my car, but didn't screw them all the way on. This gives me the option to run the upper hole in the caster block.
Old 12-09-2003, 10:33 AM   #5190
Suspended
Thats an idea! But the actual carpet setup requires that you run in the bottom hole.Actually the setup is very close to Adachi's rayspeed asphalt setup also.Cant wait for the tub!
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
