Old 12-08-2003, 07:56 PM   #5161
Jeff Werner's Avatar
Trader Rating: 15 (100%+)
Send a message via Yahoo to Jeff Werner
What is the abbrv. for your tires on that setup sheet Kilruf? Are you running the 28mm tires...if so you ahve to cut the fronts to get them to fit correct??
I maybe running some carpet soon and would love to get Chris's Carpet Setup as well!
I know we would love to have Chris back at an event at Tulsa. Met him there and when we drove at an invite race...the reason I made the switch to the SD after seeing his SD...gave up my losi...lol
Good to see you on Tech.
Jeff Werner
Jeff Werner is offline   Reply With Quote
Old 12-08-2003, 09:11 PM   #5162
Send a message via AIM to BlackFlagRacing
Thanks for posting that set-up. I think I need to order a few things so I can get my car right. rob
BlackFlagRacing is offline   Reply With Quote
Old 12-08-2003, 09:11 PM   #5163
The abbreviation says Jaco Foams Purple/Orange (Plaid) front and Purple rear.
James Nguyen is offline   Reply With Quote
Old 12-08-2003, 09:29 PM   #5164
Hey everyone, I just ran my car today with a one-way I just installed. I broke 2 axles from the one-way. I know there are hop-ups but I don't have any means of getting them. Is any one else have problems with breaking axles from a one-way. I also tried tightening the front diff to be like a fixed diff and I still got more cornor speed, but those are showing signs of bad wear. Has any one tried that with success.
magerz24 is offline   Reply With Quote
Old 12-08-2003, 09:35 PM   #5165
Matt Howard's Avatar
I've run a spool in the past and the wear didn't seem that bad. Even if they do wear out in a couple weeks new diff halves are only a couple bucks
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 12-08-2003, 09:41 PM   #5166
Thanks for the reply, I probly will use the diff as a solid diff, but my hobby store dosn't carry any yok parts.
Old 12-08-2003, 10:47 PM   #5167
Randy Caster's Avatar
Trader Rating: 46 (100%+)
1 ways and spools can be hard on dogbones, the key is to stay off the boards, especially on power... If you are a fairly new driver, a diff will be a lot easier on you.
Old 12-08-2003, 11:31 PM   #5168
JimmyMac's Avatar
Jeff, like what James said... Purple/Orange Fronts with Purple Rears. And they are 28mm. You have 3 options to run them up front I think... 1. Trim the 28mm down to like 27mm or so til they clear. 2. Trim the steering knuckle arm til it clears (I think MO does that too.) or... 3. Shim the wheel out a tad til it clears (only problem with that is it might get out of the legal 190mm width and also be too wide for some bodies.)
On my setup, I run 1° toe-in the rear. But I use the Aluminium R0+2 rear block with 1° rear hubs reversed to get my 1° toe-in.
I might try running some copper or gold sway bars next week to see how they do. Plus I'd like to try some different pistons as well. Maybe some #3's.
JimmyMac is offline   Reply With Quote
Old 12-09-2003, 12:00 AM   #5169
Default Re: Yokomo MR-4TC SD
Originally posted by Cat
It just look like tb evo 3.
Does it have the same problem with tb evo 3???
http://www.teamyokomo.com/japan/newp...o/mrtc-sd1.jpg
what problen? you meen gears? yokomo gears are very good
Chris Tosolini is offline   Reply With Quote
Old 12-09-2003, 12:02 AM   #5170
Jeff Werner
just shave alittle of the steering block
Old 12-09-2003, 12:05 AM   #5171
Would going to a trailing knuckle solve the rubbing issue without removing material from the rim or block?
Old 12-09-2003, 01:42 AM   #5172
Lonestar's Avatar
thanks for the input, kentech!
Paul
When the flag drops, the BS stops.
The train stops at the train station. The bus stops at the bus station. In my office I have a workstation.
Lonestar is offline   Reply With Quote
Old 12-09-2003, 02:53 AM   #5173
Send a message via ICQ to Cobra81li200
Yes the one way is hard on the axles, you should try to get the Square Ti or Tobee reinforced ones. I think speed tech rc has got them, ask Steve on this forum.
Cobra81li200 is offline   Reply With Quote
Old 12-09-2003, 06:19 AM   #5174
Default KEIL-DTM Masami's win
Here is a Video from the KEIL Race last weekend in Germany
Masami win with Yokomo SD - Champion Race
www.rcweb.de
Fred-von-Jupite is offline   Reply With Quote
Old 12-09-2003, 08:13 AM   #5175
Lonestar's Avatar
Cobra, vous ici ??? A l'abri des quolibets de Cyril?
a+
Paul
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
