Old 12-01-2003, 09:43 AM   #4981
Francis M.'s Avatar
jjmudd you can try yokomo usa some time this week. I'm sure
they will have Chris Tosolini's set up as soon as he gets back
from cleveland. He is also answering questions there if you have
any for him. I also heard alot of people taking of thier center brace
But it was for Asphalt aplication I don't know how it will work for
carpet. i'm guessing keeping it for carpet would be the way to
go.
TQ-racing Yokomo BD7 Airtronics
Francis M. is offline   Reply With Quote
Old 12-01-2003, 09:47 AM   #4982
rc-zombies's Avatar
Default Re: SUZUKI KNUCLES
Originally posted by OHBRAD
Hi again,. no stock at speedtech, no stock at speedway hobbies, and one have any ideas, some are saying could be months away for new stock
regards brad p
I might have one to sell...
but may be too costly to ship to Austrialia for a $25.00 part.
Old 12-01-2003, 09:48 AM   #4983
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Originally posted by GeorgePravata
nice paint where can i get some bodys painted up
The guy I use does mostly local stuff, I just hand him the bodies at the track. I'll ask him if he's interested in doing bodies from outside the area.
Old 12-01-2003, 09:56 AM   #4984
rc-zombies's Avatar
let me know how much he charges... I've got a handful of bodies to be painted... I like yours... but in Orange..
Old 12-01-2003, 10:13 AM   #4985
Default Re: Re: SUZUKI KNUCLES
Try SpeedWorld Raceway and Hobbies.
www.speedworldraceway.com
pops is offline   Reply With Quote
Old 12-01-2003, 10:27 AM   #4986
mo
mo's Avatar
Originally posted by jjmudd
Still hope one of you folks will share a good baseline set-up with me.
I have a few on my website. www.mo-net.ws
TLR, Spektrum, Tekin, SMC, MO-GRIP, www.factory-rc.com https://www.shapeways.com/shops/MPP
mo is offline   Reply With Quote
Old 12-01-2003, 10:44 AM   #4987
Registered User
2Tenths's Avatar
I just picked up an SSG-SD and would appreciate some advice on set-up for the car. We are running mod 10 turn limit ,indoors on a 93' X 48' CRC Ozite carpet with foams. Typically plaid fronts and purple rears but a few of the guys at our track are doing well with a Speed Mind 45 front - 40 rear combination. Anyone have a good set-up that they would be willing to share with me??!! Yokomo USA site is ????? Also I was told that a lot of the faster racers are removing the bottom brace on the lower deck and just running the pan with the upperdeck...any truth to this rummor?
John
Here are some tips on setting up the car for carpet w/ foams, which is difficult because the chassis is so flexible and has a long wheelbase:
*Use two top decks: this stiffens the chassis
*No stiffener: It just adds weight, doesn't stiffen the chassis side to side, only front to back
*Soft suspension: 3 hole pistons, 50 wt oil, 20 lbs springs all around (Associated Gold, Xray Light Blue, or Rayspeed Gray)
*Anti squat: 1.5 mm in rear
*Layed down shock positions: this helps keep the car from traction rolling
*Wheelbase: Shift all of the weight forward, arms all the way back (all around)
*Gold front sway bar, silver rear (both in lower position)
*Lower front arm hinge pin position w/ knuckle spacer on top
*Traction additive: something mild like TQ Orange, the chassis already creates a lot of traction
These are some starters, maybe I can post my setup sheet later, except it is for the Rayspeed Chassis
2Tenths is offline   Reply With Quote
Old 12-01-2003, 11:10 AM   #4988
I'll see what he charges, but ya gotta come up with a different scheme... this one's mine
Old 12-01-2003, 11:34 AM   #4989
And the pics of the finished chassis
Old 12-01-2003, 11:35 AM   #4990
Last 1.
Old 12-01-2003, 11:43 AM   #4991
jjmudd's Avatar
rc-zombies, check out a painter we have up here in Edmonton, Canada. www.kmaynespaint.com His stuff is by far the most original and cleanest I have ever seen anywhere including all the cars shot for all the mags. If you have a theme he can do it. Check out the Pepsi car and the X-Ray or the 1/8th buggy crocodile on his site...all hand done including lights grills etc!!!
Thanks Mo and jfw-frani...gives me a place to start!! I run Losi here but just traded a guy a Limited Edition Print for a new Losi and then traded a guy the Losi for the SSG-SD (I've got all the Losi stuff I need to keep me going for a long time but the SSG is just too sharp a car not to have. lol!! Also fun to try something different once in a while!
jjmudd is offline   Reply With Quote
Old 12-01-2003, 12:47 PM   #4992
RBLove's Avatar
Trader Rating: 72 (100%+)
Carpet/foam racers. Tosolini had an awesome car at the Champs....... I will try to get him on here to post a set up. Car was just soooooooo dialed.....
RC America, Xray, Hudy, R1 Wurks, EA Motorsports, ProLevel RC, Ulti Tires America, PROTOform
RBLove is offline   Reply With Quote
Old 12-01-2003, 12:49 PM   #4993
Registered User
Hi-LowBrow's Avatar
Send a message via Yahoo to Hi-LowBrow
Randman, that's very nice color !! I like it ! is that body painted by Robert?? looks like his job.
anyways,,,I have a question for you Randman, I just bought sway bars which are upper type just like Masami uses.
I tried to put them on my RS chassis, but it seems like impossible to put them since front shocks obstructed.
so,Randman,is your chassis all RS?? even shock mount tower? if so, How did you put them on it?? could you please tell me how to put the upper sway bar on RS chassis?
THANKS !!
Hi-LowBrow is offline   Reply With Quote
Old 12-01-2003, 12:55 PM   #4994
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
Randman when do you get to run that Yoke? I'm interested to see how you like it vs. the first one you had.
ST Racing Concepts (STRC)
Old 12-01-2003, 12:56 PM   #4995
Anyone heard how much they might be selling the CGM for in the states or when?
BTW, if I understand right, the chassis is made of the same stuff that the XXX-S G+ chassis is.
wcoyote is offline   Reply With Quote
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
