Old 11-27-2003, 10:32 PM   #4906
Matt Howard's Avatar
Originally posted by MattSSG
So if I wanted to lighten up my drivetrain the parts i would have to buy are:
Tobee Craft aluminum ft and rear imput shaft.
Hardened steel universal axles.
would anybody recommend anything else?
The hardened universals aren't going to lighten anything up they will be more durable. The tobee center shaft and CVD bones are also available and lighter than the stock peices.
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 11-27-2003, 11:11 PM   #4907
Suspended
Trader Rating: 28 (100%+)
Matt is correct.Just finished installing the lite input shafts center shaft annd rear cvds.There is a big difference in rotating mass with the new parts. Cant wait to see how it does in Stock at the Regionals.
racenut123 is offline   Reply With Quote
Old 11-27-2003, 11:16 PM   #4908
Registered User
Hi-LowBrow's Avatar
Send a message via Yahoo to Hi-LowBrow
I recommend you that you get Shooter's Alum. Inner Camber Link Mount !! this allow you that can adjust the upper rod position with using sims. Team Suzuki has similar stuff but a lot better than that I think. price a lot cheaper as well.
take a look the pic!!
Hi-LowBrow is offline   Reply With Quote
Old 11-27-2003, 11:33 PM   #4909
NightKidZ's Avatar
Send a message via ICQ to NightKidZ
Alternatively, you can try the following parts :
1) Square titanium front and rear input shafts
2) Square titanium front and rear snub axles
3) Square titanium dogbones
4) Tobee Craft lightened aluminium prop shaft
Tobee Craft aluminium dog bones should work ok in the rear, but I wouldn't recomend you use them in front, esp if you are using a one way... my stock steel bones were very badly twisted when I replaced them.
Cheers
NightKidZ is offline   Reply With Quote
Old 11-28-2003, 02:55 AM   #4910
johnbull's Avatar
Can anyone give me an address for those top plate mounts. They are like the Tamiya B 03 units.
Regards
Joe from sunny Malta.
johnbull is offline   Reply With Quote
Old 11-28-2003, 03:14 AM   #4911
utieh's Avatar
Default shooter's top link mounts
available at:
http://www.precisionrc.com/
shooter
utieh is offline   Reply With Quote
Old 11-28-2003, 05:24 AM   #4912
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Those top link mounts do look very nice, I may have to order a couple pair and try them out, adjustable rollcenter is always a +
Old 11-28-2003, 10:57 AM   #4913
Registered User
2Tenths's Avatar
Originally posted by utieh
available at:
shooter
I've been running those top deck mounts for a while now, and where they really help is in the front. You'll notice that, when running the front suspension shimmed all the way back, the camberlink is not straight across, but actually angled to mount on the shock tower. When you use the Shooter's mount, you can mount the camberlink on it, instead of the shock tower so it goes straight across.
Here's a pic:
2Tenths is offline   Reply With Quote
Old 11-28-2003, 11:31 AM   #4914
Suspended
Those are sweet.I loved my Tamiya EVO3S for that one reason.Easy rollcenter adjustments.I am ordering these asap.Now I havethe reliability of my Rayspeed sd and the ease of adjustability of the camber links of the Evo3S.Cant wait!Thanks for the Pic!
Old 11-28-2003, 11:41 AM   #4915
Registered User
2Tenths's Avatar
No problem.
I translated the Yokomo Japan: New Products site. Here are some SD things coming in December:
*MR4TC-SD CGM Special Kit: 32,800 yen
*CGM Conversion Kit: 12800 yen
*Graphite front hub carrier (4 degree): 900 yen
*Graphite battery strap and mount set: 1380 yen
*Molded Shock Tower: 680 yen
*Graphite Molded Shock Tower: 1350 yen
Also, for November:
*Team Suzuki light-weight drive cups: 2360 yen
(These are lighter than the Team Suzuki regular ones)
Here's a pic of the Lightweight Drive Cups:
Old 11-28-2003, 06:55 PM   #4916
Originally posted by 2Tenths
Also, for November:
Well I guess my Suzuki drive cups already lost their BLING...
Old 11-28-2003, 08:36 PM   #4917
JimmyMac's Avatar
Be very careful when using the Shooters Upper Deck Mount. If you get T-Boned.. check to make sure they aren't bent. Happened to mine in the rear. They are nice, but a tad too thin IMO.
JimmyMac is offline   Reply With Quote
Old 11-28-2003, 08:41 PM   #4918
Wow, I figured they would be stronger than the stock plastic, that's pretty wierd.
Old 11-28-2003, 08:52 PM   #4919
JimmyMac's Avatar
They will handle normal wear and tear. But a T-Bone will bend them easy. They aren't thick like Evo3 Deck mounts. If they were, I'd still have them on my car. The part that bends is the thin Camber link mounts. Also when using them in the rear.. it makes for getting to the top motor screw a pain sometimes. But that's just me. I'm sure plenty of people haven't had any trouble with them at all.
Old 11-28-2003, 08:55 PM   #4920
OHBRAD's Avatar
Trader Rating: 16 (100%+)
Send a message via Yahoo to OHBRAD
Default SUZUKI KNUCKLES
Team Suzuki Aluminum front steering knuckles for MR-4TCSD
SPEEDTECH HAVE NO STOCK OF THIS PRODUCT, DOES ANY HERE NO WHERE ELSE I CAN GET THEM IN URGENT SHORT NOTICE
REGARDS BRAD P
Yokomo BD818 | Sanwa | HW | Zombie | Team Yokomo | Meakin Park | Bayside | Hearns Hobbie | SpeedyRC
OHBRAD is offline   Reply With Quote
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
