Old 11-27-2003, 12:53 AM   #4861
Lonestar's Avatar
Originally posted by Hi-LowBrow
it's going to be cheep plastic mold chassis.....tub chassis is not for serious raceres. Masami's dad said it before.
Er.... ever heard about the TC3?
Raced the SD for the first time last WE... Great car, average driver. One thing I dislike about the car is that it memorizes tweak so bad... If you hit hard (which did happen a few times in the raceday) you really have to un-tweak it ASAP, else the car clearly runs funny. It's a pain sometimes.
Drivetrain is still not as free as I'd like, the car now has 1hr break-in on the stand + 25 batteries... I'm beginning to wonder wth is going on here... I was the only one dumping in the A (23turn class, 8-min race, Japan style) ... Ok, I had the smallest batteries of the bunch, but still...
There's still some work to be done.
Later,
Paul
When the flag drops, the BS stops.
The train stops at the train station. The bus stops at the bus station. In my office I have a workstation.
Lonestar is offline   Reply With Quote
Old 11-27-2003, 01:01 AM   #4862
Kenneth Tan's Avatar
MR-4TC Pro/SP were tubs as well...
Kenneth Tan is offline   Reply With Quote
Old 11-27-2003, 01:40 AM   #4863
utieh's Avatar
there will also a conversion kit for the SSG and Black special and that won't be "cheap":
MR - For 4TC SD
CGM conversion kit
December 18th sale schedule
< 052660 > < SD-CGM > \12,800
The kit itself is cheaper than the SSG/BLACK kits but it will be pretty well equipped (threaded shocks, antiroll bars.....
utieh is offline   Reply With Quote
Old 11-27-2003, 01:42 AM   #4864
Randy Caster's Avatar
Trader Rating: 46 (100%+)
That kinda sucks, but I have heard there will be a carbon tub out as well, that's what I'm lookin for...
Old 11-27-2003, 01:44 AM   #4865
I also recieved all of my red aluminum stuff back today, and I've almost finished the SD. Just need to build the RS steering, and sand/seal the upper deck, and I'll be set. The car looks awesome, and should perform the same
Old 11-27-2003, 02:39 AM   #4866
sigmund's Avatar
Default CGM Version
Observe the steering bellcranks and rear shock tower. They're plastic copies of what we've seen on the Rayspeed Ultimate Kit. Seems like there is a servo saver/horn combo, as the bellcranks are quite slim.
To me SSG/Black Version vs. CGM is just like X-ray Evo2 vs. Raycer. Bringing a moulded version of a previosly machined product to the market is something every company (not spesific to RC) has to do to make decent money when the production volumes are rising. This is because the production cost of a tub is probably less than 1/5 the cost of a machined carbon fiber plate. (Just a guessed figure based on experience) But the investments in tooling are way higher on the moulded version.
If the serious racers prefer the tub version, that's just more money in Yokomo's pockets.
Tweak vs. not, carbon vs. tub, I prefer the Bling!!
Sigmund the Engineer
sigmund is offline   Reply With Quote
Old 11-27-2003, 05:46 AM   #4867
Send a message via ICQ to Cobra81li200
Originally posted by MattSSG
Wouldn't running the arms all the way back move some of the weight of the car to the rear. So you gain some rear traction while sacrificing some forward bite.
Nope it moves weight forward.
Cobra81li200 is offline   Reply With Quote
Old 11-27-2003, 09:59 AM   #4868
Registered User
2Tenths's Avatar
Randman - Where did you hear about a graphite tub? Any idea when it's coming? Will there be a graphite tub conversion kit w/ everything?
2Tenths is offline   Reply With Quote
Old 11-27-2003, 10:04 AM   #4869
utieh's Avatar
It is just a matter of time until Yokomo releases a graphite tub chassis since they already made graphite molded shock towers.
Old 11-27-2003, 10:33 AM   #4870
They have already made the shock towers??? Where are those avalible?
Old 11-27-2003, 10:51 AM   #4871
forty6's Avatar
Default CGM Special
Isn't it what CGM stands for? Carbon Graphite Material or Composite Graphite Material? Their previous tub chassis weren't bad.
forty6 is offline   Reply With Quote
Old 11-27-2003, 12:11 PM   #4872
Suspended
Trader Rating: 28 (100%+)
Hey has anyone used the Tobee craft aluminum parts such as the dog bones,drive shaft and input shafts? Are they considerably lighter? And are they pretty durable?I have them in hand and want to know what others think.I will run them in 19turn and stock.
racenut123 is offline   Reply With Quote
Old 11-27-2003, 12:28 PM   #4873
GeorgePravata's Avatar
Trader Rating: 108 (100%+)
The tobee parts are awesome i run them in mod. and 19t and stock. You will see in stock the car has more punch out of the corners with the tobee bones and input shaft...
GeorgePravata is offline   Reply With Quote
Old 11-27-2003, 12:30 PM   #4874
Racenut-I think they are pretty good quality. Lighter than the original parts on the car. The input shafts will make a difference. I broke a dogbone somehow, but I think it was a defect in the aluminum because it snapped off clean. But for only 8 dollars a pair I can afford to replace them. The middle shaft is way lighter than the stock one and stronger than the Yok graphite one.
James Nguyen is offline   Reply With Quote
Old 11-27-2003, 01:00 PM   #4875
Matt Howard's Avatar
I've been running the tobee input shafts, center shaft, and rear dogbones since the summer running both mod and 19T and they've held up great and really reduce the weight of the drivetrain.
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
