Old 11-24-2003, 12:00 PM   #4816
John Fontaine's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to John Fontaine
Originally posted by Randman
It's normal to have to do that John, did you happen to lightly sand the faces of the gears before you assembled the gearbox? The shims make the gear mesh adjustable, I usually set the gear mesh like I would on a 48 pitch car. That's a bit tight, but that is also for modified, if you run stock, you can put a little more play in it, and it'll free up the transmission a bit. I got very lucky on my graphite gearboxes, the mold was perfect, and the stock shimming was perfect as well, once I break in the drivetrain for a few hours, it should be very free
Randy, I forgot that tip that you told me. Luckily I'm not too far into the build so I can still do that. Thanks for reminding me.
John
Xray and Serpent....very dusty!
John Fontaine is offline   Reply With Quote
Old 11-24-2003, 12:01 PM   #4817
Francis M.'s Avatar
anymore updates on the warm up race at cleveland.
TQ-racing Yokomo BD7 Airtronics
Francis M. is offline   Reply With Quote
Old 11-24-2003, 12:14 PM   #4818
Jeff Werner's Avatar
Trader Rating: 15 (100%+)
Send a message via Yahoo to Jeff Werner
On the topic of shimming...has anyone ran just one shim behind the input? I ran the 3 shims for about 10 race days and the car was more free after each weekend. A local sponsored racer stated that he felt like it was ok to subtract shims...just wanted to check with this thread on the experiences you may have had with shim and gear life.
Jeff
Jeff Werner is offline   Reply With Quote
Old 11-24-2003, 12:19 PM   #4819
Randy Caster's Avatar
Trader Rating: 46 (100%+)
John
It will help the breakin quite a bit, just dont take off too much material, the real goal is just to slightly round the faces of the teeth...
Old 11-24-2003, 12:48 PM   #4820
Do these ever strip out being plastic? I thought alum would of been provided.
Old 11-24-2003, 04:05 PM   #4821
Send a message via ICQ to Cobra81li200
Jeff
It's ok as long as you keep an eye on the play, because once the gears breaks in the play will increase and if it increases too much it can cause stripping gears.
Cobra81li200 is offline   Reply With Quote
Old 11-24-2003, 04:13 PM   #4822
They shouldn't strip easilly, you'll hear about Evo 3's going through gears, but that's because the gear doesnt have proper support...
Old 11-25-2003, 12:48 AM   #4823
danjoy25's Avatar
Trader Rating: 37 (100%+)
Thumbs up shims
Jeff
I run all 3 in the front and 2 in the rears. I tried running 2 in the front as well but the gears didn't look good after a few runs.
danjoy25 is offline   Reply With Quote
Old 11-25-2003, 09:07 AM   #4824
Regional Moderator
Darkseid's Avatar
I run all three in the rear and 2 up front.
TLR 22...Tamiya F104...
Old 11-25-2003, 10:46 AM   #4825
The reason that everyone seems to be running slightly different shimming is because the gearboxes are molded, and most likely have slight imperfections from one to the next...
Old 11-25-2003, 10:51 AM   #4826
Suspended
Trader Rating: 28 (100%+)
Default gear sanding
So I am lead to believe some are sanding the oneway gears teeth?Is this for clearance and break in reaons?I have had 2 oneway gears go bad and need to know if this will help.Also I ran 2 shims in the front when I toasted those gears.Help! Otherwise the drivetrain is butter.
racenut123 is offline   Reply With Quote
Old 11-25-2003, 11:00 AM   #4827
Francis M.'s Avatar
i would not recomend sanding it down steve from speedtech
posted a way to break in the gears. wich is basically shimming
as tight as possible without binding then using a slave motor
to run at low rpm for a few hours. this will seat the gears together
and this should apply to most shaft driven cars not just the
sd.
Old 11-25-2003, 11:04 AM   #4828
I do sand my gears lightly, just to barely round the edges of the teeth. I've done this on just about every shaft car I've owned, and they all have had extremely free spinning drivetrains...
Old 11-25-2003, 12:45 PM   #4829
Interesting posts guys. I'll be building more of my car tomorrow cause I have the day off
I also get to pick up my 03 accord which got hit and has been in the shop for a month now...boy I miss that car, I don't enjoy my rental camry except for beating it Yay!
Old 11-25-2003, 12:48 PM   #4830
Rental cars = e-brake slides & rally cars
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
