Old 11-24-2003, 09:48 AM   #4801
Registered User
Default Help~
Which is better shock setup for Rayspeed? Long shock body or short shock body with long shock end? Does it matters?
Aku-Man is offline   Reply With Quote
Old 11-24-2003, 09:50 AM   #4802
Default Re: Help~
Both will work, long shock bodies are recomended.
pops is offline   Reply With Quote
Old 11-24-2003, 09:52 AM   #4803
Registered User
If I use long shock body, do I have to use longer shock shaft? Or they are the same?
Old 11-24-2003, 09:53 AM   #4804
Shock shafts are the same.
Old 11-24-2003, 09:54 AM   #4805
Registered User
Thanks pops.
Old 11-24-2003, 09:56 AM   #4806
I seem to be having a problem with glithcing with my SD. I just got it and used my stuff from one of my other cars, using the Novak xtl-less system, and runnning stock. I first had the receiver mounted to the inside with the speedo to the outside on the lower deck. Was glitching bad. Moved the receiver to the top deck, changed motor, bla bla bla. I could never get the glitch out. I have never had this problem with any of my other cars or electrics. Had the receiver wire in fuel tubing to protect against any rubbing on the graphite.
What are you guys doing to prevent glitching, or is this my own personal issue.
thanks
IMIURU is offline   Reply With Quote
Old 11-24-2003, 10:01 AM   #4807
John Fontaine's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to John Fontaine
I started building the kit and it's going very smoothly. Only thing I had to do so far is take out one of the three shims for the front dif housing cause it was a little too tight and binding the bearings. This normal?
John
Xray and Serpent....very dusty!
John Fontaine is offline   Reply With Quote
Old 11-24-2003, 10:17 AM   #4808
DickemDown's Avatar
Post a quick ?
can someone direct me to the page that shows how to rotate the steering servo? aside from space, will it steer better? i've held off doing this, and i just got a new black chassis, so i thought i'd do the mod while i'm transferring everything over to the new chassis.
thanks,
herb
DickemDown is offline   Reply With Quote
Old 11-24-2003, 10:31 AM   #4809
sosidge's Avatar
lonestar - The Rayspeed steering setup is best used only on the Rayspeed chassis, which has slightly different mounting points. It will probably fit on the SSG, but the geometry will not be as intended.
IMIURU - I too have had glitching problems on the SSG (gut feeling is that all those aluminium strands cause problems). By soldering an extra set of capacitors on my motor (Monster Stock) they're gone - the new Trinity/Epic cap board stinks.
John Fontaine - most people find the standard shimming a bit tight, but it's probably best to break the gears in with the full shimming, before making adjustments. I run 2 shims on the input shaft, but it still turns with 3.
Old 11-24-2003, 10:56 AM   #4810
Send a message via ICQ to Cobra81li200
Default Re: a quick ?
thanks,
herb
You can have good pictures here (in french soon to be translated in english)
And yes it will steer better, mostly in left hand turns.
Cobra81li200 is offline   Reply With Quote
Old 11-24-2003, 11:25 AM   #4811
Ok, I got everything to fit with 3, but it just seems like it's binding. Maybe it will be fine after it breaks in. I'll put the third shim back in. Thanks for the info.
John
Old 11-24-2003, 11:26 AM   #4812
SpeedTech's Avatar
Hi Guys,
Just a quick note, I apologize for the error on the Tobee Craft section. We have more parts in stock than the website originally shown (I updated the webpage just right now) so the page now reflects our inventory status. Sorry about that guys.
Steve Wang
>>>www.SpeedtechHobbies.com<<<
SpeedTech is offline   Reply With Quote
Old 11-24-2003, 11:31 AM   #4813
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Originally posted by lonestar1127
Randma thanx alot....i'm actually looking for pic of RS steering on a SSG kit...hehe ....thanx aniwae
I dont think it will fit because of the bellcrank post positions...
Old 11-24-2003, 11:35 AM   #4814
John
It's normal to have to do that John, did you happen to lightly sand the faces of the gears before you assembled the gearbox? The shims make the gear mesh adjustable, I usually set the gear mesh like I would on a 48 pitch car. That's a bit tight, but that is also for modified, if you run stock, you can put a little more play in it, and it'll free up the transmission a bit. I got very lucky on my graphite gearboxes, the mold was perfect, and the stock shimming was perfect as well, once I break in the drivetrain for a few hours, it should be very free
Old 11-24-2003, 11:37 AM   #4815
Registered User
Steve, when is the graphite transmission box back in stock?
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
