Old 11-23-2003, 04:46 PM   #4786
THeGame's Avatar
Send a message via AIM to THeGame
Default Top 4
Info on the warm up race for Cleveland.. Top 3 cars are Losi's, But the Yok SD is holding 4th in the hands of Chris T.....
1 Mike Dumas
2 Paul L
3 Andrew Gray
4 Chris T
After the mains are over I will give an update of the top ten..
THeGame is offline   Reply With Quote
Old 11-23-2003, 07:24 PM   #4787
lonestar1127's Avatar
Originally posted by Randman
There are pics on the Yokomo USA site...
can u post a link to it....i can't seems to find it thanx
lonestar1127 is offline   Reply With Quote
Old 11-23-2003, 10:23 PM   #4788
Randy Caster's Avatar
Trader Rating: 46 (100%+)
I'll do you one better...
Old 11-23-2003, 10:51 PM   #4789
Registered User
2Tenths's Avatar
Default Re: Top 4
1 Mike Dumas
2 Paul L
3 Andrew Gray
4 Chris T
Is that the mod sedan/foam class? Is Chris' setup available anywhere?
2Tenths is offline   Reply With Quote
Old 11-23-2003, 11:55 PM   #4790
JimmyMac's Avatar
I must be out of it... when did Mike Dumas switch to Losi? Anyhow, gonna be interesting. THeGame, are you out there in Cleveland?
JimmyMac is offline   Reply With Quote
Old 11-24-2003, 01:41 AM   #4791
FUK_WRX's Avatar
Send a message via ICQ to FUK_WRX Send a message via AIM to FUK_WRX Send a message via MSN to FUK_WRX Send a message via Yahoo to FUK_WRX
another way to fit RS steering
Is this rayspeed steering assembly come complete like the pics above or do i still require to buy the plastic bits etc..
Many thanks,
-Luie
FUK_WRX is offline   Reply With Quote
Old 11-24-2003, 05:06 AM   #4792
Send a message via ICQ to Cobra81li200
Actually these are pictures of my car...
I mounted the RS steering plate in the same way as on a TB3 because my servo mod did not allow me to do it the RS way...
Do not need any parts other than the stock steering and RS plate. You just need to cut one part off the plastic as the picture above shows.
And the RS steering comes just with the plate/bearings/balls, so if you want to mount it like on the RS conversion kit you need to buy another plastic part / servo saver.
There is much less play than stock but I can't say compared to a RS one as I've never seen
any...
Cobra81li200 is offline   Reply With Quote
Old 11-24-2003, 05:21 AM   #4793
Send a message via ICQ to JesseT
What' sthe advantage of the RS steering compared to just turning it with the standard parts. I just can't see the point. With the RS steering one can't even use the center brace.
JesseT is offline   Reply With Quote
Old 11-24-2003, 06:48 AM   #4794
sigmund's Avatar
Default RS vs. Stock steering assy
With the stock steering setup there is a lot of steering slop on the left side. The reason for this is that the distance between the bearings in the left bellcrank is not very great. Just a tiny bit of slop in these bearings causes the bellcrank to tilt sideways, resulting in steering slop on the left side. Even with the "precision" bearings there is quite a bit of slop. This is not the case on the right side, where the bearings are relatively far appart.
With the RS steering you add another servo-saver, and thus weight, but gain steering precision on the left side.
sigmund is offline   Reply With Quote
Old 11-24-2003, 06:49 AM   #4795
sosidge's Avatar
The Rayspeed steering (when fitted correctly, as in the Yokomo USA pics), makes the steering response even in bothe directions. With the stock steering, the play in the ackerman link means that one wheel is sloppier than the other when you steer.
Old 11-24-2003, 06:51 AM   #4796
FUK_WRX's Avatar
any...
Since you used this in the TB3, that means it should mount on my 414 with out no probs. Like i said i was using the MR4TC steering bell crank then reverted back to tamiya but the TRF ones is slopping too much compared to the MR4TC.
So this Ray speed is the same ?? Correct ?? What parts do i need ?? Is that blue post optional ??
Thanks,
-Luie
Old 11-24-2003, 07:06 AM   #4797
sosidge's Avatar
The Rayspeed steering uses the same plastic parts, the same servo savers and the same posts as the normal car. The only different part is the carbon link and the hardware it attaches to.
Old 11-24-2003, 07:21 AM   #4798
FUK_WRX's Avatar
Default thanks a bunch
Thanks heaps for your help
Old 11-24-2003, 07:51 AM   #4799
Thanks,
-Luie
I did not use it on a TB3. Read better I wrote that I mounted my RS steering link like it is on a TB3 (TB3 uses a carbon steering link).
It will not mount on a 414. If you want to reduce play in your 414 steering, use glue in the holes of the 414 steering link (like it is used to prevent carbon from delaminate but not for the same purpose).
Old 11-24-2003, 09:13 AM   #4800
Randma thanx alot....i'm actually looking for pic of RS steering on a SSG kit...hehe ....thanx aniwae
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
