Old 11-20-2003, 10:40 PM   #4741
Fire's Avatar
will derlin work?
Fire is offline   Reply With Quote
Old 11-20-2003, 10:52 PM   #4742
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Originally posted by Fire
will derlin work?
I think delrin would break fairly easy if used for a spool... There is a lot of stress put on that piece.
Old 11-20-2003, 11:52 PM   #4743
JimmyMac's Avatar
I vote Steel. An Aluminium one would remind me of using an IRS TC3 one without pin cushions..... would only last one run.
JimmyMac is offline   Reply With Quote
Old 11-21-2003, 12:01 AM   #4744
That's why I suggest steel outdrives, and an aluminum base...
Old 11-21-2003, 08:06 AM   #4745
Jeff Werner's Avatar
Trader Rating: 15 (100%+)
Send a message via Yahoo to Jeff Werner
When I raced with Baker at the Tulsa Invite I believe he was running a steel spool in his car...he said it has lasted forever and worked great.
Thanks for the update...keep up the good work!
Jeff
Jeff Werner is offline   Reply With Quote
Old 11-21-2003, 09:40 AM   #4746
Default novak brushless
Hi,
Anyone got a pic of a SD with novak brushless mounted ?
Need reference on the mounting. SD is very tight on
electronics space.
ongbenghui is offline   Reply With Quote
Old 11-21-2003, 10:25 AM   #4747
Default Re: novak brushless
Originally posted by ongbenghui
Hi,
electronics space.
I havent seen it done on a SD, but I did it on a R2. Basically just mount the reciever on top of the servo, and you'll be fine with space. It's easy to figure out once you put the parts together...
Old 11-21-2003, 11:08 AM   #4748
Macky's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Macky Send a message via Yahoo to Macky
Hi,
electronics space.
Kilruf had the brushless setup on one of his SD's. Check out around page 108.
Macky is offline   Reply With Quote
Old 11-21-2003, 05:01 PM   #4749
JimmyMac's Avatar
Here is it again...... my old setup.....
Old 11-21-2003, 07:45 PM   #4750
Hey, that car look's familiar! HeHe
It's a bird,it's a plane, nnooooo!!! It's SUPERMAN
See ya tommorrow Kilruf!
HENRYJ is offline   Reply With Quote
Old 11-21-2003, 09:42 PM   #4751
Default suspension help
Ok, heres's the problem.....i just finished building my SD with the RS ultimate conversion and can't get the ride height set. i'm not understand what's happening here. on the setup for the RS chasis it says to use the SS shocks and make the front 64mm and the rear 66mm using the short shock end. i can;t seem to make a shock that long using the short shock ends. if i do it's only hanging on by a couple of turns on the treads. So anyway i end up with a car that sits at 6mm in the front and 5.5mm in the rear. so what's the difference between the SS and SSS shocks?
tricklosi is offline   Reply With Quote
Old 11-21-2003, 09:51 PM   #4752
JimmyMac's Avatar
Hey Hank! Catch ya tomorrow!
Trick... SS are longer than SSS. SSS are the ones that come with the kit. RS Chassis setups use SS shock bodies. If you want to use SSS shock bodies you need to use the long shock ends. Here is a pic of the difference in size of SS and SSS.
Old 11-21-2003, 09:54 PM   #4753
ok i see thanks Kilruf, so i need to use the long all the way around then...?
Old 11-21-2003, 11:08 PM   #4754
Wow, you got everything to lay on the chassis flat... impressive...
Old 11-22-2003, 12:11 AM   #4755
Smile
Also check to make sure you are running the hinge pin in the lower hole of the castor blocks.
pops is offline   Reply With Quote
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
