Old 11-15-2003, 07:48 PM   #4621
Randy Caster's Avatar
Trader Rating: 46 (100%+)
I would try the center stiffener if I were you... Also, I just ordered all of the graphite parts avalible at SpeedtechRC and the new transmission cases should make it less prone to tweaking... I've still gotta wait to get my parts back from the anodizer before I build the car, but I'll be sure to give an update when it's done...
Old 11-15-2003, 08:02 PM   #4622
rcfiend's Avatar
Trader Rating: 30 (100%+)
Randman what's new about the transmission cases. Running the center will that eliminate the torque steer\tweek???
rcfiend is offline   Reply With Quote
Old 11-15-2003, 09:53 PM   #4623
They are graphite material = less flex... Also the center stiffener should help a little bit in eliminating flex which in turn becomes tweak in this car...
Old 11-16-2003, 05:40 AM   #4624
Trader Rating: 74 (100%+)
Default Yok 4 sale
Anyone intersted, I am selling my Yok., possibly getting out of electric racing all toghether. Take a look at items for sale.
Team and Sales Manager for USRC Imports, home of Sworkz! Looking for drivers for 2017-2018, KingMax Servos www.kingmaxhobby.com Gens Ace www.gensace.com, MIP www.miponline.com,Schelle , WWW. Schelleracing.com, Slavich Designs, GARCIA GRAPHIX
CHECK OUT GARCIA GRAPHIX ON FACEBOOK -LOOKING FOR 2017 TEAM DRIVER'S!
Raul Garcia is offline   Reply With Quote
Old 11-16-2003, 06:22 AM   #4625
Send a message via ICQ to Cobra81li200
RcFriend,
I've had some torque steer on high grip carpet, but with a proper setup it's really possible do deal with it.
I ran the car on wooden floor yesterday. Needless to say it's even more slippery than a parking lot when your tyres are brand new, and didn't have any torque steer problems.
I think that your car might have a problem or your setup is not good enough.
As for tweak, I did not took the center brace, been racing 3 weeks in a row without checking the tweak, because I don't have any problem. Had some crashes, didn't broke anything (the new graphite arms seems to be ok). I did not broke anything since 2 months on the car and did had some big crashes.
Cobra81li200 is offline   Reply With Quote
Old 11-16-2003, 06:30 AM   #4626
Originally posted by SpeedTech
I believe the Tobee ones are stronger than the Yokom ones because they are thicker bone towards the joint pin ends (where as the yokomo ones actually gets slightly thinner) and that's where it usually shears about for the Yokomo ones. Plus, you get two Tobee bones for less than the price of one Yokomo one Can't really beat that in my opinion...the Tobee stuff should be on their way, and we should get them end of next week.
Steve Wang
Hum,
The Tobee bones might be thicker, they are also made of a poor quality aluminium. They wear very fast on the front (I've tried both yok and tobee front and rear, both wear fast on the front but the yoke are better) and they twists, thing that the yoke ones don't do.
I've never broke any Yokomo Shaft, either bend one. I did with Tamiya ones, but their cross section area is lower. I suggest your car had another problem which lead the shaft to break (pin gone out locking the wheel axle while you accelerate maybe).
Old 11-16-2003, 08:49 AM   #4627
rcfiend's Avatar
Originally Posted By Cobra81li200
RcFriend,
Cobra what would you consider a good setup. The car works pretty good, but I just can't get the tweek\torque steer under controll. How did you address the torque steer and tweek. Honestly, will the RS kit help????
Old 11-16-2003, 10:37 AM   #4628
If you feel the torque steer, it just means that you don't have enough on power grip on the rear. Try using a bigger anti roll bar on rear, it will give you more on power grip, but also mask torque steer.
As I said earlier in this thread, since my mass balance has been optimized, I don't feel any tweak in the car. I actually have a difference of less than 18g between my FL and FR wheel. So I don't feel any need in the RS conversion kit, and I don't think it will help you.
Have you done the servo Mod ? If no DO IT, if yes, then fix your transponder beside it like on a TC3 (I use a Square TB3 servo mount), it helps a lot. Also, use a large Spur (110T) to offset the motor.
I did not remove the center brace but the way I did my servo mod, I had to cut it, so I only have 3 posts to fix it (the 2 on the front are not in as the bar it cut). Maybe that's why I don't have tweak issues using it. Try removing the 2 posts on the front of the centre stiffener and run the car like that.
Old 11-16-2003, 10:50 AM   #4629
rcfiend's Avatar
Ok I get everything you're saying and I will try the servo\Center stiffner. But I'm somewhat confused about your application of a larger rear sway-bar. I don't see how adding a stiffer swaybar will produce on power steering, if anything the car will become looser. I run modifeid and going from looser to looser doesn't help. Maybe I'm missing something here. By the way, thanks for your help. I really like the Yokomo, but I'm just frustated as you can probably tell.
Old 11-16-2003, 11:15 AM   #4630
What do you usually do to get more on power grip on the rear ? I put harder springs and anti roll bars on rear.
Old 11-16-2003, 11:41 AM   #4631
One more thought would be to go with a little thicker shock oil, that will allow the car to transfer weight a bit slower...
Old 11-16-2003, 11:42 AM   #4632
rcfiend's Avatar
I normally adjust the front droop.
Old 11-16-2003, 01:00 PM   #4633
danjoy25's Avatar
R/C Tech Charter Subscriber
Trader Rating: 37 (100%+)
Universal coupler
Anyone know if other universal coupler brand would fit the std unis. I lost one last race meeting as I forgot to use locktite and is having problems sourcing the original part here in Oz.
Regards,
danjoy25 is offline   Reply With Quote
Old 11-16-2003, 04:21 PM   #4634
sosidge's Avatar
Cobra currently believes stiffer settings increase grip. I, and most other people, disagree.
I've found that a softer rear setting will actually decrease the torque steer effect, the back end gets better traction, and stops the car's back end sliding all over when you put the power down.
I'm also having big torque steer problems at the moment, although they have been hardly noticeable until recently - I run on slippy surfaces all the time. A good tweak setting can help, either through adjustment of the shock collars on the bench to get even tweak, or by messing around with the shock collars on the track. I'm going over the car with a fine comb before the next meeting, searching for a damaged or worn part.
Old 11-16-2003, 05:11 PM   #4635
JimmyMac's Avatar
I don't know what the big deal is with torque steer. It's the common trait with all shaft cars. I've had it with the TC3... the Evo3.. and even my friends R2.... And I have it with my SD. It's just more noticable in Mod than Stock. Just learn to throttle up correctly instead of "gagging it." If it's that much of a pet peeve... switch to a belted car.. hehe... But seriously, I hardly notice torque steer anymore. Alot of it is throttle control and stock class...
So any word yet on the release of the tub version? Looking for a 2nd car...... again.... hehe...
JimmyMac is offline   Reply With Quote
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
