Old 11-13-2003, 11:21 AM   #4561
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Originally posted by johnbull
Hi friends. greetings from Malta.
RANDMAN.
It's simple. Put the shaft in a lathe. Machine down one end - about 1 centimetre (half an inch) till the end with the pin drops out. You are machining just the thickness of the hollow graphite shaft. Now trim it to length and epoxy or superglue the end back in.
It's dead simple.
SOMEONE.
Someone kindly suggested someone who makes a lightweight alloy spool for the SD. Can you give me a website, e-mail address or contact address.
Regards
Joe from sunny Malta.
Cool, I would have never thought of that, thanks for the instruction
Old 11-13-2003, 11:32 AM   #4562
Matt Howard's Avatar
Default Re: ok
Originally posted by racenut123
I need to find out the difference between the stock trailing steering knuckles and the option non trailing knuckles.Whats the physical differnce,what does it do and what are the majority of you guys running.Thanks
The optional zero offset steering knuckles will make the steering more sensitive, the suzuki aluminum ones are .5mm trailing making them inbetween the yokomo plastic versions. I'm running the suzuki knuckles for durability issues and I honestly can't feel a difference in the .5mm between the stock ones and these. If I were to change from the stock ones to the inline ones I might be able to feel it though, just haven't tried the inline ones yet.
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 11-13-2003, 12:06 PM   #4563
mo
mo's Avatar
For those who haven't been there in a while, Chris Tossolini is now on-line everyday in the forums at www.yokomousa.com .
TLR, Spektrum, Tekin, SMC, MO-GRIP, www.factory-rc.com https://www.shapeways.com/shops/MPP
mo is offline   Reply With Quote
Old 11-13-2003, 12:11 PM   #4564
rc-zombies's Avatar
Also want to add that Chris is now using Fukuyama Racing Cells...
the cells are awesome!
Old 11-13-2003, 12:41 PM   #4565
kentech's Avatar
Arrow Atheena Projects Carpet Chassis and Upper Deck
The Carpet Chassis and Upper Deck will be available at the end of the month. If you're interested in the parts, email Atheena Projects. [email protected]
The prices are 32 euros for the upper deck and 80 euros for the main chassis.
More information and pictures have been posted at http://www.atheenaprojects.com .
The material used for both the Carpet Main Chassis and Carpet Upper Deck is the highest grade carbon fibre anywhere in RC Car racing. The percentage of carbon is much higher compared to the normal carbon fibre used in RC cars. Both the main chassis and upper deck are so much stiffer compared to the original parts that you won't believe it. Perfect for high-grip carpet racing!
kentech.wordpress.com
kentech is offline   Reply With Quote
Old 11-13-2003, 12:44 PM   #4566
Hey Mo,
Do you have any RS #2 pistons? i need some but Billy isn't open. If you have some can I buy them from you on Saturday.
James Nguyen is offline   Reply With Quote
Old 11-13-2003, 02:08 PM   #4567
I may pick up one of the atheena project chassis' to see how it works, I'd propably mill mine down a bit and shave some grams
Old 11-13-2003, 02:18 PM   #4568
John Fontaine's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to John Fontaine
Kentech - that looks nice. I might have to try that out...I guess first I should get the kit? But yeah, i'm buying the yok SD
Xray and Serpent....very dusty!
John Fontaine is offline   Reply With Quote
Old 11-13-2003, 02:30 PM   #4569
Originally posted by James Nguyen
Hey Mo,
I have some blank ones you can drill out if you can't get anything else
RCTech #361
Old 11-13-2003, 02:36 PM   #4570
I have some RS #1s in my car right now, I might drill them out to 1.1. I think 1.1 is like a 57 right?
Old 11-13-2003, 02:49 PM   #4571
mo
mo's Avatar
James, I don't have any extras, just ones in a set of shocks. Right now, I'm actually running 3 hole #56 pistons though.
Old 11-13-2003, 02:50 PM   #4572
does the piston fit on the shaft perfectly?
Old 11-13-2003, 03:23 PM   #4573
You know you can always hit me up with questions John, always glad to help ya out
Old 11-13-2003, 03:25 PM   #4574
Guys, just so you know, Speedtech RC SHOULD (not will, but should) have the graphite stuff in stock tomorrow I'm sure Steve doesnt know exactly what he's getting in the shipment, but hit him up tomorrow if ya want the graphite goodies!
Old 11-14-2003, 07:40 AM   #4575
rcfiend's Avatar
Trader Rating: 30 (100%+)
For those of you who race mod, how loose do you set your diff??
rcfiend is offline   Reply With Quote
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
