Old 11-12-2003, 03:18 PM   #4546
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
Nice. Can't wait to see it. I know you take great care in building a nice looking car. I have seen pics of your other cars and they look great.
ST Racing Concepts (STRC)
Old 11-12-2003, 03:39 PM   #4547
i am planning on geting the yokomo sd and i was wondring how good the rayspeed conversion works is it better then the stock set-up
pro3user is offline   Reply With Quote
Old 11-12-2003, 03:51 PM   #4548
Registered User
Hi-LowBrow's Avatar
Send a message via Yahoo to Hi-LowBrow
yes,RaySpeed conversion chassis is much better than stock one. RaySpeed's has more steering and easy to control.
most fast racer who in japan use RaySpeed's with SS shocks.
must Item.... !!especially for asphalt .
Hi-LowBrow is offline   Reply With Quote
Old 11-12-2003, 05:02 PM   #4549
JimmyMac's Avatar
Randman, the shocks are as far out as they can go with the upper sway bar in the pic.
Maybe I'll get to test my setup with Mod this weekend. We'll see.
Anyways, still waiting on the SpeedTech Spool.... dum dee doo.... hehe....
JimmyMac is offline   Reply With Quote
Old 11-12-2003, 05:10 PM   #4550
I was asking a question yesterday regarding the servo horn position that no one response to it. May I ask the same question again.
If I mount the servo horizontally on my SSG SD, shall the servo horn mount at 12 o'clock position or 2 to 3 deg. off set just like the TC3 / Rayspeed?
MARKANO is offline   Reply With Quote
Old 11-12-2003, 05:33 PM   #4551
Send a message via ICQ to Cobra81li200
not like TC3 / Rayspeed. The reason for those kits is that the steering linkage is lower on the servo saver side than on the servo side, thus a 12 clock horn position will not give the same L/R feeling.
If you're using the standard steering just turning the servo, just keep the horn to a 12 lock neutral position.
Cobra81li200 is offline   Reply With Quote
Old 11-13-2003, 12:09 AM   #4552
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Yeah, this one should be one of a kind, I basically tried to build the "dream car"
Old 11-13-2003, 12:13 AM   #4553
I guess Yokomo will be recieving more G350GT bodies soon since they have just posted it on the US website.
James Nguyen is offline   Reply With Quote
Old 11-13-2003, 12:24 AM   #4554
Arent those the ChevronModel bodies?
Old 11-13-2003, 12:32 AM   #4555
Randman - Sure are. Steve at Speedtech has had them for a little while I believe...
Just remember, nothing is free.
ultragraffics is offline   Reply With Quote
Old 11-13-2003, 12:51 AM   #4556
Yeah, I thought that looked a bit familiar
Old 11-13-2003, 02:49 AM   #4557
YOKOMOSHO's Avatar
Default Re: PISSED OFF
Originally posted by OHBRAD
Hi guys need some advice, have finished building the SD and i can't seem to get the ride heights i want, i have followed the book which suggest building the shocks at 60mm. I ended up using the long piece that screws on the end for the front shocks, and even still when wound fully down i still can't get a 6mm ride height, it is 7mm now.
Have you guys found the right length to make them, that works, i just don't see how i can make it work with out tring to make them more than 60mm, and then making it to much longer will weaken it.
why does the kits have two end but tell you to use the one, which doesn't seems to work
also i have never come accross such a hard car to install the motor, the screws are so hard to get into.
please help want tp take iot for a run this weekend, and the way it it looking, the bin is looking better
regards brad p
Brad, if you need any advice at the track on your Yokomo, just let me know. They are a great car, albeit with a few little oddities. I reckon I have a pretty good handle on most things to do with the SD, so don't hesitate to come and see me at any race meeting if you need a hand.
Keith M.
YOKOMOSHO is offline   Reply With Quote
Old 11-13-2003, 05:08 AM   #4558
Joel Lagace's Avatar
OHBRAD: Ignor the 60mm length build them to 64mm and your ride height will be there
"Without Rules its just Backyard Bashing!"
www.rcottawa.com
Joel Lagace is offline   Reply With Quote
Old 11-13-2003, 07:21 AM   #4559
johnbull's Avatar
Hi friends. greetings from Malta.
RANDMAN.
It's simple. Put the shaft in a lathe. Machine down one end - about 1 centimetre (half an inch) till the end with the pin drops out. You are machining just the thickness of the hollow graphite shaft. Now trim it to length and epoxy or superglue the end back in.
It's dead simple.
SOMEONE.
Someone kindly suggested someone who makes a lightweight alloy spool for the SD. Can you give me a website, e-mail address or contact address.
Regards
Joe from sunny Malta.
johnbull is offline   Reply With Quote
Old 11-13-2003, 09:53 AM   #4560
Suspended
Trader Rating: 28 (100%+)
Default ok
I need to find out the difference between the stock trailing steering knuckles and the option non trailing knuckles.Whats the physical differnce,what does it do and what are the majority of you guys running.Thanks
racenut123 is offline   Reply With Quote
yokomo or yokomo parts yokomo7 R/C Items: Wanted to Buy 4 12-19-2009 08:45 PM
Yokomo is coming out with a new version of the bd : Yokomo BD 2 roadrashracing Electric On-Road 12 12-19-2007 07:08 AM
yokomo Aluminum Steering Bellcrank Posts and other yokomo spares hurley081182 R/C Items: Wanted to Buy 2 02-27-2006 06:07 PM
Lots FS: CRC 3.2 & Yokomo YRX-12, Yokomo TC Tires, JR Receivers, New Motors, more TurboFC3S R/C Items: For Sale/Trade 15 09-22-2005 09:38 PM
WTB Yokomo 1/12 Mini...Trade for 1/10 Yokomo dynamic_e R/C Items: For Sale/Trade 0 07-12-2003 05:58 AM
